luvtheeluvbug Samba Member
Joined: January 06, 2013 Posts: 288 Location: Sonora, Ca
Posted: Sun Nov 23, 2014 11:32 pm Post subject: CV Grease |
I'm rebuilding my CV joints and the manual says to use CV grease. Well, the manual was published 40 years ago so, does it even exist? If it does, can I simply use wheel bearing grease? It seems that they would be very similar.
By the way, who still has their original CV joints? I was surprised to see that all four of mine were the originals and even better, they are in really good condition; three of them are practically in brand new shape and only the fourth one is getting thrown out because the boot failed and caused pitting. _________________ Fahrvergnugen/ far-fair-gnu-ghen/ Description of a pleasurable sensation experienced when a car and it's driver are in mutual harmony; A unique driving experience; Pleasure; Satisfaction; A feeling experienced by Volkswagen drivers. |
Joined: June 02, 2011 Posts: 1593 Location: Louisville, ky
Posted: Mon Nov 24, 2014 12:41 am Post subject: |
It's HP (High Pressure) grease these days. It is not the same as axel grease. Axel grease relies on fast moving bearings. The CV joint is almost motionless with lots of load. |
Harleyelf Samba Member
Joined: April 23, 2009 Posts: 1572 Location: Appleton, WI
Posted: Mon Nov 24, 2014 12:53 am Post subject: |
Many boots come with new bolts and grease. Ask to see what's in the box. |
Aussiebug Samba Member
Joined: June 03, 2002 Posts: 2162 Location: Adelaide Australia
Posted: Mon Nov 24, 2014 3:27 am Post subject: |
The correct grease is a molybdenum disulfide grease. It's always black in colour due to the Moly in it, and is usually called HP (high pressure) or EP (extreme pressure) grease.
Castrol LMM is one version, but most oil companies will have a suitable grease.
As ptjjb says above, it works best in the CV joints which just rock the balls back and forwards a little as the suspension works; unlike wheel bearings which need a Lithium bearing grease which suits and rolling motion of the balls/rollers. _________________ Rob
Rob and Dave's aircooled VW pages
Repairs and maintenance for the home mechanic
http://www.vw-resource.com |
gargamel Samba Member
Joined: December 20, 2011 Posts: 693 Location: Orange Grove, Texas
Posted: Mon Nov 24, 2014 8:29 am Post subject: |
Good to know when I need new grease. Just wondering:
Not that I am looking for another (dirty) task to do but, I had loosened one side of my cv assembly (while re-indexing the rear). There was still ample grease there but it seemed that the grease dried just a but as it was more like mud than the it would be straight from the tube.. Not sure how long it has been serviced but it seems like an original and they run well. Is this ok or should I look into repacking with new grease?
I thought I ask here on a related topic vs. starting a new one. |
Randy in Maine Samba Member
Posted: Mon Nov 24, 2014 8:34 am Post subject: |
They are actually to be clenaqed and repacked about ever 30K miles. I use this stuff but any parts store or NAPA can get CV joiunt grease for you. I keep a tube of it in my tool box for whenever I need a little lube on something.
http://www.redlineoil.com/product.aspx?pid=82 |
Posted: Mon Nov 24, 2014 8:42 am Post subject: |
So it is safe to assume I need to service them based on the appearance alone? I guess I will be spending some quality time getting to know my cv joints much more then I was hoping for. |
Posted: Mon Nov 24, 2014 9:02 am Post subject: |
I would so that you will know that they have been properly serviced uner your ownership. I just buy a "re-pack kit" from Bus Depot x 4 of them. About $60 and takes me basically a day to do all 4.
Been here?
http://www.type2.com/bartnik/cvjoints.htm |
Donnie strickland Samba Member
Joined: December 21, 2009 Posts: 2403 Location: Moody, AL
Posted: Mon Nov 24, 2014 9:07 am Post subject: |
I use Valvoline Dura Blend grease, as it's appropriate for both wheel bearings and CV joints. Been using it for 20 years with no problems.
_________________ 71 Elm Green FI A/T Squareback |
Juanito84 Samba Member
Joined: March 17, 2012 Posts: 2436 Location: Colorado Mountains
Posted: Mon Nov 24, 2014 10:32 am Post subject: |
Any parts store has CV joint grease. Just ask for some. Yes, the manual is 40 years old. But you still use engine oil in the engine, gear oil in the gear box, wheel bearing grease in the wheel bearings, and CV joint grease in the CV joints. Gasoline still goes in the gasoline tank if you were wondering.
Personnally I'd be weary about those multi-purpose greases. Bearings need an entirely different kind of lubrication than CV joints do. You wouldn't put the same oil in your engine as in your transmission would you?
You really can't get any better grease than good ol' CV joint molybdenum disulfied grease. I've never seen a CV joint go out unless it either didn't have enough grease or dirt got into it. Once packed with the correct amount of grease, simply checking the boots for tears periodically and regreasing and replacing when they tear is the best insurance for your CV joints. _________________ If a water cooled engine cools its water with air, isn't it just an overcomplicated air cooled engine? |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Mon Nov 24, 2014 8:33 pm Post subject: |
I just buy Sta-Lube Black Moly.
The name says it all
Tim |
Posted: Mon Nov 24, 2014 8:36 pm Post subject: |
If I've already packed one with bearing grease, can I just pack in the CV grease or should I take it apart and start over? _________________ Fahrvergnugen/ far-fair-gnu-ghen/ Description of a pleasurable sensation experienced when a car and it's driver are in mutual harmony; A unique driving experience; Pleasure; Satisfaction; A feeling experienced by Volkswagen drivers. |
Posted: Mon Nov 24, 2014 8:50 pm Post subject: |
luvtheeluvbug wrote: |
If I've already packed one with bearing grease, can I just pack in the CV grease or should I take it apart and start over? |
It's your car. I just hope I am not the next owner. |
Posted: Mon Nov 24, 2014 9:54 pm Post subject: |
What would you do if you had accidentally put gear oil in the engine or engine oil in the gear box?
Bearings are like wheels. For the most part they roll really fast. The ones that support the most weight are cylindrical and therefore spread the pressure along the length of each roller pin. Ball bearings focus the weight on a much smaller surface area but usually don't support as much weight.
How pressure is distributed over cylindrical rollers:
CV joints are more like ice skates. They have balls that don't really roll, but more or less rub back and forth. Since they are balls, the pressure exerted on them can focus on a much smaller surface area than on a cylindrical roller. For ice skates to work they need ice. For CV joint balls to work they need molybdenum disulfide.
How molybdenum disulfide lubricates:
It's obvious that the two have very different lubrication needs. Hence the reason they require different types of grease. _________________ If a water cooled engine cools its water with air, isn't it just an overcomplicated air cooled engine? |
Posted: Mon Nov 24, 2014 11:22 pm Post subject: |
That reply was much appreciated. Because I'm younger, people tend to assume that I don't know what I'm talking about or than I can't learn what they know. Thanks for sharing your knowledge. It was great to get a true technical response that explains the reason rather than "I've done it that way for 40 years" or something smart like:
bnam Samba Member
Joined: July 02, 2006 Posts: 2936 Location: El Dorado Hills CA/ Bangalore, India
Posted: Mon Nov 24, 2014 11:51 pm Post subject: |
If the wheel bearing grease you used contains Moly di-sulphide, you should be ok. |
Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Tue Nov 25, 2014 6:29 am Post subject: |
Any EP-2 grease with a moly additive will do. Same grease used on universal joints. _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
Posted: Tue Nov 25, 2014 8:04 am Post subject: |
DP _________________ 71 Elm Green FI A/T Squareback
Last edited by Donnie strickland on Tue Nov 25, 2014 8:08 am; edited 1 time in total |
Posted: Tue Nov 25, 2014 8:05 am Post subject: |
Your point is well-stated. In my earlier response, I didn't have time to go into specifics, but Juanito84's response explains it well (as well as Joey and bnam). It really is possible to formulate a grease that works for both purposes, which is why I've used the Valvoline for 20 years, and it works very well. _________________ 71 Elm Green FI A/T Squareback |
Posted: Tue Nov 25, 2014 8:41 am Post subject: |
I see myself heading over to my FLAPS and getting some Valvoline DureBlend grease, as pictured above.
Realistically, what are the odds that my CV joints are still good-to-go? They have not made any noise. IF they are the original ones, I guess I will clean the grease and open up a pandora's box (AKA my wallet) to find wear. |
