vwsplitvan Samba Member
Posted: Mon Nov 24, 2014 3:28 pm Post subject: Best way to fix fuel gauge ? |
After some advice on how to fix the connections tabs on the back of the fuel gauge? Thought I would ask rather than mess it up any more.
I was swapping out my cracked dash for a nice one, and managed to break 2 of the tabs on the rear of the fuel gauge when removing the wire connections. Broke away on the riveted bit.
Would solder be strong enough and work or better to use a small screw to re-connect?
What have others done (other than not break the tabs in the first place)
pics of back of gauge
Dash fitted and screen back in tomorrow, just need to fix the gauge
_________________ SBS #20 UK
RHD 62 Ragtop Beetle Beryl Green
LHD 69 Squareback Peru Green
LHD 63 Splitscreen Highroof Pearl White |
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Mon Nov 24, 2014 4:14 pm Post subject: |
I've simply swapped out the back plastic bit for another non-broken one.
The tabs are riveted in place, IIRC, so if you don't have another one, you could fix it. |
VWporscheGT3 Samba Member
Joined: September 01, 2006 Posts: 2076 Location: Gardnerville, NV
Posted: Mon Nov 24, 2014 4:21 pm Post subject: |
I've soldered on a new pig tail off the connection there before... wish i would have taken a pic of it _________________ Schnell, SCHNELL!
I like being wrong, Because, it is another opportunity to learn. If you stop learning from your mistakes than what is the point?
If you have any questions about Forged ICON 4032 VW pistons just shoot me a line. |
Posted: Tue Nov 25, 2014 3:38 pm Post subject: |
thanks
Will try and repair with a small screw or maybe try to solder.
Failing that then I will look out for a replacement back. _________________ SBS #20 UK
