ctdukefan Samba Member
Posted: Mon Nov 24, 2014 7:20 pm Post subject: dual idf 40's exhaust questions |
I've just added dual idf 40's to my freshly built 1641. Was doing a little reading and saw some comments that you can't run dual exhaust with dual carbs. Is this true? I have chrome empi dual exhaust with baffles. Can I keep it or need an exhaust with more back pressure? Any help is appreciated, thanks |
jsturtlebuggy Samba Member
Posted: Mon Nov 24, 2014 7:51 pm Post subject: |
Some times the dual exhaust will interfere with the intake manifolds or carbs. They usually sit closer to the heads.
I have no idea which work and which ones do not.
The only way to really know is to mock it up to see it there is any interference.
I switch to a 4 into 1 systems back in the early 1970s. Duals do not make as much power as a 4 into 1 system.
Yes some people like them for the sound and they way they look. Just know you are giving away power you may need. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76945 Location: Sneaking up behind you
Posted: Mon Nov 24, 2014 7:59 pm Post subject: |
Are you talking about this type of exhaust, if so it's just about the worst system you can use, from a performance point of view.
_________________ Glenn
Member #1009
#BlueSquare |
Posted: Mon Nov 24, 2014 8:05 pm Post subject: |
Yes, I have similar dual exhaust, carbs dont interfere at all. Its all together and almost ready to put engine back in. Do I need to worry about lsck of back pressure? |
Glenn Mr. 010
Posted: Mon Nov 24, 2014 8:07 pm Post subject: |
ctdukefan wrote: |
You do.
You'll notice a lack of bottom end torque due to the lack of back pressure. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Mon Nov 24, 2014 9:44 pm Post subject: |
Not really will you notice anything at lower RPM, as compared to a stock muffler.
When my Dad built our first street legal fiberglass buggy back in 1970, we installed a set of chrome glass pack ones.
My Dad called them "A Cop Calling Stereo System". They were not quiet by any means. My Mother was followed home several times by law officers. When they seen who was driving, they would just drive pass the house. It was not until a year later when started playing with sand buggies that we discovered a four into one system helped with power through the whole RPM range. _________________ Joseph
Elrod Motorsports
manxdavid Samba Member
Joined: November 24, 2003 Posts: 1841 Location: David Jones, Anglesey, North Wales, UK. Manxclub #678.
Posted: Mon Nov 24, 2014 11:13 pm Post subject: |
It's not 'back pressure' that you want, it's some semblance of tuned pipe length along with the scavenging affect that a 4 into 1 collector gives. IMO fit what you've got (if indeed they do fit) and see if you're happy with the performance they give. As long as you've not gone too wild cam-wise (cam overlap adds a lot of noise and cackle to an engine) it shouldn't be too loud (depending on how you drive of course).
BTW those dual 40's will need careful jetting and setting up preferably on a rolling road as they're a little big for a 1641 unit. 36's would have been a better choice IMHO. |
jrailer Samba Member
Posted: Mon Nov 24, 2014 11:19 pm Post subject: |
I would be more worried about over carburetion |
jspbtown Samba Member
Posted: Tue Nov 25, 2014 7:32 am Post subject: |
There are two designs of those style exhaust. One fits dual carbs one does not. |
Posted: Tue Nov 25, 2014 7:52 am Post subject: |
Any jetting recomendations? This is new to me. Love the lookn gonna make it work[/img] |
Dale M. Samba Member
Posted: Tue Nov 25, 2014 8:20 am Post subject: |
If comment you were reading were generalized, it is wrong.... There are many different dual carburetor systems and a hundred or more exhaust systems that will work, trick is to get best combination.... Generally small engines use smaller diameter pipe (1-1/4 to 1-3/8 in.) exhaust systems and large engine use larger diameter pipes(1-1/2 in. or more ) ... Exhaust system system which have equal length pips are more efficient as length of pipes help scavenging effect (not tuned like cone mufflers on 2 strokes) when merging 4 into 1, and then you have choices of muffler types (quiet to loud) or cone shaped stinger....
Although dual cannons look cool and you can run them, but as others mentioned there is "some" power loss, and they sound like a pair of out of tune Harleys running side by side... And what you get for mufflers is what you get...
