LEE 64 Samba Member
Posted: Tue Nov 25, 2014 1:08 pm Post subject: When battery weakens Bus stops? |
1970 1600 engine Hi what would cause this when my battery is fully charged bus runs fine when battery weakens bus stops ??does a 1970 have an alternator or generator?thanks |
richparker Samba Member
Joined: November 24, 2011 Posts: 6982 Location: Durango, CO
Posted: Tue Nov 25, 2014 1:15 pm Post subject: |
A stock engine would have a generator, it may have been danger to an alt. need to see a pic to know for sure. Use a volt meter to check the out out of power with the engine is running. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Tcash Samba Member
Posted: Tue Nov 25, 2014 9:10 pm Post subject: |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Wed Nov 26, 2014 8:24 pm Post subject: |
Do you still need help? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
LEE 64 Samba Member
Posted: Wed Nov 26, 2014 9:24 pm Post subject: yes |
yes |
LEE 64 Samba Member
Posted: Wed Nov 26, 2014 9:27 pm Post subject: . |
Its still doing the same thing battery charged it runs fine then as it weakens it doesn't run as good |
timvw7476 Samba Member
Posted: Wed Nov 26, 2014 11:37 pm Post subject: When battery weakens Bus stops? |
If you have a generator, one or both of the brushes that ride the commutator
may have shortened to the point that the charge circuit is "broken". i.e. open
If you have a modern alternator it is two brushes as well, riding on two
"slip rings", they too are perishable items and fail(shorten) eventually.
This causes open charge circuit, the battery discharges running the ignition
and all other electrical load demands, til it signs off, and bus "dies". |
1967250s Samba Member
Posted: Thu Nov 27, 2014 3:03 am Post subject: |
Umm, is the charge light coming on? Does it work when key is first turned to ON position? How old is battery? I just had to add water to mine. _________________ '72 Elm Green Deluxe |
morymob Samba Member
Posted: Thu Nov 27, 2014 4:17 am Post subject: |
Orig is a gen & dont need chg lite to work. If a gen check output at regulator, term that goes to batt,, when not running should be voltage there all time, if so most likely the reg bad.Meter voltage at this point with eng running, speed up , if voltage dont increase, back to reg. |
Posted: Thu Nov 27, 2014 9:28 am Post subject: |
You should get a charging voltage of somewhere around 14V when the engine is revved. You do have a VOM don't you? IMO an analog meter with a 20v DC scale it the best, but hard to find. Many prefer digital meters, but it is hard to get a reading if the voltage is fluctuating as will happen if you have a mechanical regulator.
If your battery is getting run down, how do you get your engine to start? |
