jarmchairpilot Samba Member
Joined: March 04, 2013 Posts: 459 Location: GALWAY,IRELAND
Posted: Thu Nov 27, 2014 6:44 am Post subject: battery draining power? |
Having electrical gremlins.Last week after a night time drive of 20 miles,I arrived at my destination and switched lights and ignition off.1 minute later I went out to move the bug a few yards,only to hear the starter struggle to make even 1 turn and the two red(ignition and gen)lights came on dimmly for a second and faded out.I brought my battery(6 month old,seems fine) to a nearby garage and had it charged overnight.The next day with charged battery,the bug fired up no problem.
The problem is I dont know what went wrong in the first place.
I noticed while driving at night the headlights seemed at times to kind of pulse,I mean they would seem to get stronger for a few minutes then drop power.
How can I tell if the problem is something causing a drain on the battery,or if the charging circuit is at fault.My generator is only a year old,same as my starter motor and both are expensive Bosch quality items.
My bug is a 72 Standard 1200.Thanks. |
Luft kühl Samba Member
Joined: January 21, 2009 Posts: 1178 Location: Allentown, PA
Posted: Thu Nov 27, 2014 7:13 am Post subject: |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Thu Nov 27, 2014 9:04 am Post subject: battery drain |
I tested for battery drain,did,nt find any. |
Posted: Thu Nov 27, 2014 9:22 am Post subject: |
There are two other things that you can try.
Have the battery load tested.
Test the charging system. http://www.speedyjim.net/htm/gen.htm |
Cusser Samba Member
Posted: Thu Nov 27, 2014 9:53 am Post subject: |
Test for charging system actually operating.
Disconnect battery overnight or a few days, see if it starts. A good battery will be fine to start a vehicle after several months (like in my 2004 Frontier). _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
dirtkeeper Samba Member
Joined: February 19, 2008 Posts: 3200 Location: Left of everywhere
Posted: Thu Nov 27, 2014 11:08 am Post subject: |
Cusser wrote: |
Dimming lights would indicate this. New or not , my guess is charging system |
Posted: Wed Dec 10, 2014 7:06 am Post subject: battery drain |
I found a dodgy connection at the voltage regulator on the thin red wire that comes from the battery,this was causing my battery to stop charging while driving.I still have a problem that is causing the battery to drain after the bug is parked up.My no.1 fuse is blown,this is the one that should provide power to the two small front parking lights. |
Posted: Wed Dec 10, 2014 8:37 am Post subject: |
In addition to the two gray wires for the front parking lights, there should also be a red/gray wire connected to fuse #1 that powers the license plate light.
Disconnect all three wires from the fuse, switch the parking lights on, and reconnect the wires one at a time until the fuse blows. You will now know which circuit has the problem. |
Posted: Wed Sep 09, 2015 8:08 am Post subject: battery draining |
I had to replace the voltage generator,I guess the original lasted 40 years,so I hope the stock Bosch replacement is as good!At least my battery has survived in good condition. |
