BMAN130 Samba Member
Joined: December 21, 2010 Posts: 47 Location: Hempstead
Posted: Thu Nov 27, 2014 8:26 pm Post subject: 72 karmann ghia signal wiring |
im rewiring a karmann ghia and i foolishly didnt label where the turning signal wires went to
i tried searching but couldnt findthe wiring for that particular switch like i did for others.
any ideas?
zzhayward Samba Member
Joined: June 01, 2005 Posts: 258 Location: Philomath, Oregon
Posted: Thu Nov 27, 2014 9:49 pm Post subject: wiring |
the ends you show plug into the steering column switches: Turn signals high/low beams and windshield wipers. No brainer at that end. The other end goes to all kinds of places. Get a VW manual with colored wiring schematics and you got a good chance to figure it out. good luck |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13943 Location: Southampton U.K.
Posted: Fri Nov 28, 2014 8:29 am Post subject: |
oh boy
windshield wipers, idc bout so i separated the harness, and i need to connect my turning signal relay/switch.
ill take a look at that diagram tonight. |
Posted: Tue Dec 02, 2014 6:41 pm Post subject: |
The plugs you showed (in your hand) slide into the steering column connectors. They can go into them only one way. All the switches in the column are held captive. Look up into the back side of that large black housing that holds your ignition key and you will see the matching prongs staring back at you. You will need to be on your back looking up. They are toward the driver door side. |
Posted: Thu Jan 22, 2015 1:05 pm Post subject: |
I'm getting lost in that wiring schematic. |
c21darrel Samba Member
Joined: January 22, 2009 Posts: 8206 Location: San Dimas
Posted: Thu Jan 22, 2015 4:42 pm Post subject: |
im not good at electric at all, but i started a project and well.. here we are
i rewired the car, new fuse box , ignition, lights etc
if i figure out where these last couple wires go and i think ill be roadworthy
all i see is lines and little numbers. i wired as close to the schematic as i could, but its not line for line. |
Posted: Thu Jan 29, 2015 10:18 am Post subject: |
anyone? |
Volfandt Samba Member
Joined: March 15, 2012 Posts: 500 Location: Knox County, East TN
Posted: Thu Jan 29, 2015 10:30 am Post subject: |
Quote: |
="c21darrel, Where are you getting lost? |
To repeat, where exactly are you lost? Still on the lights or just the wiring in the trunk? _________________ 1972 Karmann Ghia, the Dragon slayer.... |
-Zodiac- Samba Member
Joined: September 22, 2014 Posts: 782 Location: Pensacola/milton, florida
Posted: Thu Jan 29, 2015 4:17 pm Post subject: |
the schematic has me confused, i believe M5 on the diagram is the harness im working with
i ultimately need to know where the wires in the first post go |
Posted: Thu Jan 29, 2015 4:21 pm Post subject: |
They plug into the column..
_________________ 1973 karmann ghia - current, not the last VW.
1947 Chevy stylemaster - gone, but not forgotten.
1995 Ford F-150 - gone, hatred for it lives. |
Posted: Fri Jan 30, 2015 3:00 pm Post subject: |
and where do all those wires go? |
Posted: Fri Jan 30, 2015 3:23 pm Post subject: |
well mine go to the rats nest.
they go to the fuse box,ground, wiper motor, turnsignals, dimmer relay
look at E/ E2 on the diagram _________________ 1973 karmann ghia - current, not the last VW.
Posted: Tue Feb 03, 2015 8:15 pm Post subject: |
yeah
iwas hoping for an easier diagram |
Posted: Tue Feb 03, 2015 8:32 pm Post subject: |
here is what you do..
write down on a piece of paper what wire colors you have
EXAMPLE ~
Green
green/black
black
black/white
and so on..
then open up this page - zoom in on the diagram and chase them. Or save the image and do the same - you could even open it up in paint and white out all the crap you don't need.
really this procedure shouldn't be as hard as you are making it, wiring on a Volkswagen is pretty straight forward compared to other stuff - figure it out.
as much as I would like to break out my colored pencils and draw it for you, i'm afraid I will not. _________________ 1973 karmann ghia - current, not the last VW.
Posted: Tue Feb 03, 2015 9:59 pm Post subject: |
If you want to half ass it to get yourself roadworthy, and then figure out how to properly do it and read the diagram - here is what you do.
run two wires to the rear
run two wires to the front
connect the wires to the turn-signal bulbs on left and right sides
THEN
get a two prong flasher relay - junkyard or something
run a wire from the fuse-box, off of an ignition(Use a test-light to figure it out)
run the fuse box wire to one side
connect another wire to the other side
run the other wire TO THE 12v PART of a toggle switch
THAT will flash the switch thus causing your lights to flash
NEXT
run your left front and left rear to one side of the switch
run your right front and right rear to the other-side
ground the switch
WOW - fully functioning turn-signals
if that isn't simple than I don't know what is _________________ 1973 karmann ghia - current, not the last VW.
Posted: Sat Feb 14, 2015 11:22 pm Post subject: |
thanks |
Posted: Mon Mar 02, 2015 8:28 pm Post subject: |
maybe if i narrow my question i can get some patience.. its an overwhelming project and i probably bit off more than i could chew, but im almost road worthy
on the harness to the left, are wires to a ground, relay and ?
the black striped ones go to the bulb, i got that much but im not sure which are +/- relay
in person they all seem a little brownish, but im tryin to understand which wire is which
thanks for the help |
