joeherb53 Samba Member
Joined: March 07, 2005 Posts: 41 Location: hernando mississippi
Posted: Fri Nov 28, 2014 4:38 pm Post subject: Heater box restoration |
I have a 1962 bug and will be running a 1776 or larger engine and will be keeping the heater boxes. I have a pair and they are a bit dirty, rusty and at some point a squirrel was storing nuts in one of them. What is involved to take these apart and restore? |
gt1953 Samba Member
Posted: Fri Nov 28, 2014 7:21 pm Post subject: |
They may be dissassembled and reassessembled. Check the classified here you may located some non rusted ones in good shape. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51144 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Nov 28, 2014 7:52 pm Post subject: |
Are we discussing OG stale air boxes or later fresh air heat exchangers?
Either way a little careful prying on the folded seams and drilling the occasional spot weld gets them open for sandblasting and rustmort then paint treatment. The outer shells don't need high heat paint, I've put Tremclad/Rustoleum on dozens over the years with no burning or peeling (assuming your fresh air hoses are hooked up), the inner pipe could use some header paint or even ceramic coating though if you want a deluxe job. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Nov 28, 2014 9:21 pm Post subject: |
They are the fresh air heater style. I can take things apart, putting back together could be the tricky part |
gt1953 Samba Member
Posted: Sat Nov 29, 2014 7:19 am Post subject: |
Take them apart ONE AT A TIME clean paint or what ever then assemble.
Remember an oil covered heater box in the classifieds is not rusted for sure. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Posted: Sat Nov 29, 2014 10:51 am Post subject: |
They aren't bad, one is kind of rusted where it attaches to the muffler, the outer housing that fits directly over the j-tube. I could post pictures later |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Sat Nov 29, 2014 12:48 pm Post subject: |
Have the rust/fit repaired at a Muffler Shop & then heat paint them. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
