warwgn Samba Member
Joined: November 18, 2014 Posts: 260 Location: central Mississippi
Posted: Fri Nov 28, 2014 5:25 pm Post subject: How wide of a trailer? |
Still looking for a bug to baja, and was thinking I might need a trailer to go pick it up and could always use a trailer anyway since I don't have one. I see plenty of 6x12 on Craigslist for cheap and I am sure they are long enough but is that wide enough if I put bigger tires and such? |
WD-40 Samba Member
Posted: Fri Nov 28, 2014 6:03 pm Post subject: |
It all depends on how you build up the car.
You could put it on a super small trailer that barely fits it...
... or you could get something that is overkill for the baja, but allows you to tow other vehicles if you need to.
Being a baja, if it has enough ground clearance, you could even get by with drive-over fenders and have a trailer that isn't any wider than the car. _________________ "The new Volkswagen 1303. We've made so many improvements, they're beginning to show." |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15303 Location: Deep in the 405
Posted: Fri Nov 28, 2014 6:50 pm Post subject: |
If you are going to buy a trailer get one big enough to put a full sized car on. Believe me once you have a tiny trailer just for your VW you will wish like holy hell you would have spent a few hundred more for a bigger trailer.
Get a trailer with brakes on it.
You can always rent a trailer from U-Haul if you only need it once. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51130 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Nov 28, 2014 8:05 pm Post subject: |
X2, a piddly single axle trailer will bite you in the ass and possibly endanger others on the road, step up now and buy a tandem with some sort of brakes and tow with confidence. (also handy to rent to your buddies when they want to move, surge brakes are better for that as they won't be hacking your plug off to attempt to wire it every time). _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Brian Samba Moderator
Posted: Fri Nov 28, 2014 8:33 pm Post subject: |
vwracerdave wrote: |
Get a trailer with brakes on it. |
_________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
warwgn Samba Member
Posted: Fri Nov 28, 2014 9:58 pm Post subject: |
I was more thinking of a tandem axle utility trailer, two 3500 lb axles and should be fine for a bug and will mostly be used for light duty. Firewood, construction material wood for a new fence and a backyard deck, riding mower and lawn clean up type stuff. Don't think I will need brakes on it, my suburban is a 3/4 ton for now and has drum brakes on it that take up the whole inside of a 16.5" wheel, and will soon be upgraded to hydro boost, then 1 ton running gear.
But back on topic, so it sounds like a 6' wide should do just fine but if a 6.5 is found should go for that.
Was thinking this one mainly because of the adjustable bull nose hitch, sure would be handy since my Suburban has a 6" lift and 37" tires.
https://jackson.craigslist.org/grd/4770762049.html
a bug should fit on that right? |
Hnoroian Samba Member
Joined: October 27, 2013 Posts: 535 Location: Bakersfield
Posted: Fri Nov 28, 2014 10:54 pm Post subject: |
I'd prefer 12-16'. 10' seems a little too short and un-square but that's my ocd Kicking in. We have a 6x14 and use every inch of it, wishing it was just a bit longer sometimes too. 2 quads, rhino, and 2 dirt bikes get tight _________________ Stupid people do stupid things. |
WM971252 Samba Member
Joined: September 10, 2004 Posts: 1781 Location: Franklin CT
Posted: Sat Nov 29, 2014 8:05 am Post subject: |
An adjustable drop hitch is much easier to use than one on the trailer. Beat on one for 12 years till I replaced it this year.
As far as size, I would want something longer than 10 foot and wide is always good. My ancient trailer is 68 inches wide by 16 foot, great for a Bug or Bus but a Vanagon will not fit (A3 Golf fits but no room to tie down). I sucks to have to rent a trailer when you have a fleet in the yard. |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Sat Nov 29, 2014 9:37 am Post subject: |
My $400 tow dolly will tow them all & has! _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
crukab Samba Chef
Joined: December 13, 2002 Posts: 6116 Location: Vermont
Posted: Sat Nov 29, 2014 10:41 am Post subject: |
I've hauled a bunch of Buses w/ my 14' x 6' dual axel low-boy, it's supposed to be a tilt trailer, but it is way easier to use ramps. It does have elec. Brakes. I never have to worry about a bad wheel bearing or locked brakes on the car I'm towing, just winch it on, strap it down & go.... _________________ Tom
My Pops:
In the yard right now:
'51 Dodge 5 window truck
'65 Bug
'66 Singlecab
'82 Rabbit Truck Diesel from CALI
'86 Doublecab W/T
'88 Dodge Ram pickup
'11 Jetta Wagon |
Posted: Sun Nov 30, 2014 8:33 am Post subject: |
warwgn wrote: |
You need brakes. Many states require brakes on a tandem axle. Get brakes on it. I don't care if your pulling it with a 10 ton dump truck. Get a trailer with brakes on it. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
notchback Insensitive Jerk
Joined: December 16, 2003 Posts: 7024 Location: Behind the Zion Curtain
Posted: Sun Nov 30, 2014 4:29 pm Post subject: |
Mike Fisher wrote: |
My $400 tow dolly will tow them all & has! |
How much firewood and construction material does it haul? How do you tow the riding mower with it? _________________
zeen wrote: |
Arguing with johnnypan is like mud-wrestling a pig. After a while you realize he just enjoys playing in the mud, winning the contest is not the point. |
FU#3 |
Aussiebug Samba Member
Joined: June 03, 2002 Posts: 2162 Location: Adelaide Australia
Posted: Mon Dec 01, 2014 5:39 am Post subject: |
I don't know what the laws for trailers are in the USA, but I bet they are similar to other parts of the world.
Here in Aus a trailer without brakes is limited to 750kg (1650lb) all up weight (trailer plus load), no matter how big your tow vehicle is. A mid 60s bug weighs 1675lb all by itself, so forget using a trailer without brakes.
From 750kg up to 2 tonnes (4400lb) all up weight (trailer plus load) you must have brakes on all wheels. You can use override (sliding coupling) brakes or electric brakes.
From 2 tonnes up to 4.5 tonnes (9900lbs) you must also have a break-away system so if the trailer comes loose from the towbar then the trailer brakes will engage and will HOLD on for a minimum of 15 minutes, so that means electric brakes with a battery on the trailer, or air brakes with an air bottle on the trailer (sometimes called Maxi-s), or air over hydraulic - same deal.
Trailers over 4.5 tonnes needs a driver's heavy vehicle (truck) licence to tow it.
The car and it's tow-bar must be rated for the load too.
Tiedowns are important too. You must attache BOTH ends of the vehicle to the trailer, so that's a minimum of two straps/chains, one fore and one aft. Four straps are better - one for each corner or if using over-wheel straps, one for each wheel. The straps must be rated to hold 80% of the car's weight stopping it sliding forwards, and 50% in all other directions.
Oh - and tow dollies (which lift two wheels of the towed car off the ground and rely totally on the tow-vehicle for braking) are illegal here in Aus unless you are a licensed toe-operator and driving a registered tow truck, so check your state's requirements before you use one of those.
Whatever you do, make sure you are legal so the cops wont give you a hard time, and your insurance wont knock back a claim if the worst happens. _________________ Rob
Rob and Dave's aircooled VW pages
Repairs and maintenance for the home mechanic
http://www.vw-resource.com |
Posted: Mon Dec 01, 2014 7:54 am Post subject: |
Very different from where I live in Idaho, USA. There really are no regulations on trailers, brakes, etc. Anyone with a drivers license can tow a trailer with their vehicle. There are not laws regarding the weights and who can pull them. Tow dollies do not even need to be registered or licensed. My 17 year old son, who has had his license for less than a year, could pull a 10,000+ pound trailer if he wanted to. _________________
zeen wrote: |
FU#3 |
Posted: Mon Dec 01, 2014 10:36 am Post subject: |
notchback wrote: |
How much firewood and construction material does it haul? How do you tow the riding mower with it? |
My pickup will haul everything the tow dolly isn't designed for.
The same cars headed for Idaho.
turboblue Samba Member
Joined: October 09, 2003 Posts: 4216 Location: Central Indiana
Posted: Mon Dec 01, 2014 11:21 am Post subject: |
This might help with laws regarding brakes, axles etc.
http://towingworld.com/towinglaws.cfm _________________ Gary
Turbo VW Sand Drag Buggy
"If you don't run into the Devil every once in awhile, you must be going in the same direction!" |
Posted: Tue Dec 02, 2014 10:06 pm Post subject: |
notchback wrote: |
Very different from where I live in Idaho, USA. There really are no regulations on trailers, brakes, etc. Anyone with a drivers license can tow a trailer with their vehicle. There are not laws regarding the weights and who can pull them. Tow dollies do not even need to be registered or licensed. My 17 year old son, who has had his license for less than a year, could pull a 10,000+ pound trailer if he wanted to. |
Hmmm - Turboblue's link above indicates that there ARE towing laws in Idaho - for example, brakes required for trailers over 1500lb, and a D licence required (whatever a D licence is)
Fortunately here in Aus we have ALMOST uniform laws across our 6 states and several territories. One state (Victoria) does not require small box trailers (under 500kg) to be registered so long as they display the registration of the towing vehicle, and there are a few differences with heavy vehicles (I drive trucks for a living), but nothing like the variation across the 50 states of the USA. _________________ Rob
Posted: Wed Dec 03, 2014 10:15 am Post subject: |
Aussiebug wrote: |
notchback wrote: |
Fortunately here in Aus we have ALMOST uniform laws across our 6 states and several territories. One state (Victoria) does not require small box trailers (under 500kg) to be registered so long as they display the registration of the towing vehicle, and there are a few differences with heavy vehicles (I drive trucks for a living), but nothing like the variation across the 50 states of the USA. |
I stand corrected. I searched the statutes and didn't find anything, but upon a researching, I found that
Quote: |
Every trailer or semitrailer of an unladen weight of one thousand five hundred (1,500) pounds or more when operated upon a highway shall be equipped with brakes adequate to control the movement of and to stop and hold the vehicle and be designed to be applied by the driver of the towing motor vehicle from its cab. |
http://legislature.idaho.gov/idstat/Title49/T49CH9SECT49-933.htm
It's interesting that most smaller trailers (5,000 lbs or less) that I have seen and used do not have brakes. My trailer is rated for 7,000 lbs and does not have brakes, yet I had no issue registering it. I'm slowing building a heavier trailer (either 10K or 15K) and it will definitely have brakes.
A class D license is a standard drivers license. Classes A, B and C are commercial licenses. _________________
zeen wrote: |
FU#3 |
warwgn Samba Member
Posted: Thu Feb 26, 2015 1:55 pm Post subject: |
well all good thoughts and info, thanks.
I wound up just borrowing a trailer, all went well and only dropped my MPG by 1 MPG.
crukab Samba Chef
Posted: Thu Feb 26, 2015 3:44 pm Post subject: |
warwgn wrote: |
Nice Beastly tow rig !! _________________ Tom
My Pops:
'65 Bug
'66 Singlecab
'86 Doublecab W/T
'11 Jetta Wagon |
