Northof49 Samba Member
Joined: July 22, 2013 Posts: 1759 Location: Winnipeg, Manitoba, Canada
Posted: Sat Nov 29, 2014 3:25 pm Post subject: depth of camshaft clearancing |
Any idea to what depth I will need to notch an Engle cam to clear I beam rods on an 82mm crank? What's the maximum safe amount I can notch it? It would be a lot less work to simply mark where to notch it, then notch it to the safe maximum then check for ample clearance. _________________ 1958 Karmann Ghia owner |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4343 Location: Los Angeles, CA 90016
Posted: Sat Nov 29, 2014 3:51 pm Post subject: |
Just mocked up a client's 82 SCAT with VW journal SCAT rods. I only need to remove about 1mm off the four spots on the cam, but will remove about 2mm to be safe. It really depends on what parts you're using. To be safe, you can copy a cast in clearanced cam's depth. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Sat Nov 29, 2014 3:54 pm Post subject: |
You need to mock it up and measure. You need at least .040" clearance. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Sat Nov 29, 2014 4:04 pm Post subject: |
vwracerdave wrote: |
You need to mock it up and measure. You need at least .040" clearance. |
Dumb question, but how do I possibly pre-measure the required clearance from a present situation of interference? _________________ 1958 Karmann Ghia owner |
Posted: Sat Nov 29, 2014 4:05 pm Post subject: |
bugguy1967 wrote: |
Just mocked up a client's 82 SCAT with VW journal SCAT rods. I only need to remove about 1mm off the four spots on the cam, but will remove about 2mm to be safe. It really depends on what parts you're using. To be safe, you can copy a cast in clearanced cam's depth. |
I am also using scat rods. Are your I beam or h beam? Mine are I beam vw journal scats. _________________ 1958 Karmann Ghia owner |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3446 Location: San Diego
Posted: Sat Nov 29, 2014 4:20 pm Post subject: |
Quote: |
but how do I possibly pre-measure the required clearance from a present situation of interference? |
He means you need to remove material until you have a min of .040" of clearance. Just go slow and take you time, if doing yourself |
Quokka42 Samba Member
Joined: December 02, 2010 Posts: 3117 Location: Melbourne, Australia
Posted: Sat Nov 29, 2014 5:11 pm Post subject: |
Northof49 wrote: |
Dumb question, but how do I possibly pre-measure the required clearance from a present situation of interference? |
You need to put gears on the crank and cam, fit a rod either with a P&C or rubber bands through the studs to centre the little end. Rotate in one direction until it hits the cam and scribe a mark, rotate in the other direction and scribe another mark. Grind between the two marks, then mock it up again and check. Don't get the cam too hot when grinding, you don't want to change it's properties. _________________ There has only ever been one man who was perfect, and they nailed Him to a cross. |
Posted: Sat Nov 29, 2014 5:19 pm Post subject: |
H Beam. Just measured a pre-clearanced casted in cam, and the narrow areas are 4mm smaller than the non-clearanced, so if you didn't have the parts to mock-up, 2mm per relief would be adequate.
The measurements were approx 23mms on the non-clearanced areas, and 19mms on the clearanced areas.
The best way is to mock up though, and remove only what is needed _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
Posted: Sat Nov 29, 2014 6:06 pm Post subject: |
So the pre-clearanced cams have the reliefs cast in ,not machined? Why don't thet make them all on preclearanced blanks then?
I am considering offsetting it in the lathe by the desired clearance and cutting the reliefs that way. That way it's only cut on one side. _________________ 1958 Karmann Ghia owner |
Posted: Sat Nov 29, 2014 6:12 pm Post subject: |
Northof49 wrote: |
Why don't thet make them all on preclearanced blanks then? |
They could and they should but VW people are cheap assed bastards and many people would shit their pants because people that do not need a pre-clearance cam would have to spend $15 more then they need to spend. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Sat Nov 29, 2014 6:16 pm Post subject: |
Aha, well said. _________________ 1958 Karmann Ghia owner |
Posted: Sat Nov 29, 2014 7:12 pm Post subject: |
Mmm, maybe not. I don't see how it'd cost more for the pre-clearanced blanks. They're less material, and all blanks come from one, or a couple of places. I think companies charge more for them because they can. They COULD be exactly the same price, and the old casting could be eliminated. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
Posted: Sat Nov 29, 2014 7:16 pm Post subject: |
I'll be milling a camshaft possibly this week, because I think my machine shop grinds the cam, which is kind of scary to me because of the heat.
A 3/4" end mill for cutting steel with rounded ends is what I'll use. I have a SCAT cam to use as reference. The oil pump drive lines up with two of the spots that need clearancing. I'ma go reeeeal slow and use a bunch of coolant. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
neil68 Samba Member
Joined: March 17, 2007 Posts: 3440 Location: Calgary, Canada
Posted: Sat Nov 29, 2014 7:32 pm Post subject: cam clearancing |
I've clearanced an Engle FK8 trying to remove as little material as possible. It took several mock-ups...to complete the work.
Since then I've always purchased notched or turned cams. I currently use a Raptor cam that was nicely turned (with proper edge radius) by JPM. Here's a good thread on the subject:
http://ultimateaircooled.com/engines/8629-clearancing-cam.html _________________ Neil.
Der Kleiner Rennwagens
68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 107 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo |
jfats808 Samba Member
Joined: December 10, 2007 Posts: 5022 Location: oahu hawaii
Posted: Sat Nov 29, 2014 9:32 pm Post subject: |
I mark the cam areas that need clearancing and hit it with an acorn steel carbide bit. Ive had to remove quite a bit on the last 2110 I did. Even in the back side of the cam collar. My first k8 cam on the 2276 had no clearancing required on the cam. With the web 86c 8 had to do crank and cam. Wait till you have no choice and have to grind the crank c/w throws! That kinda sucks. Even if you have web or another shop preclearance a cam for you and then nitride it, doesnt mean everythings going to fit. Sucks but its the name of the game. Gotta look see. _________________ 2276 IDA's 86C 11-1 DD !
2017 48 Trijet DRLA's W125
Rockstar Suzuki wrote: |
You might as well put 10 year build in your bullshit sig, as it will NEVER run. Also your a dick |
You can always learn something new, even from a fool.
Check your oil levels routinely! |
mark tucker Samba Member
Posted: Sat Nov 29, 2014 10:21 pm Post subject: |
diferent rods and journol sizes and stroke will dictate the amount needed to be removed if any.pauter said it's better to remove it by turning the cam down,it might be I dont realy know,Ive done it both ways.my hyd roller is on a preclearanced blank but will probably need more clearancing for the 3/8 rods&86 stroke. Ill do what it needs. and remember the rod needs to be in the correct location when it is done, not just dangling. |
Posted: Sat Nov 29, 2014 10:25 pm Post subject: Re: cam clearancing |
neil68 wrote: |
http://ultimateaircooled.com/engines/8629-clearancing-cam.html |
Thanks Neil! You just scared me into turning this Engle cam instead of milling, or notching it. Seems easier to do too. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
Posted: Sun Nov 30, 2014 8:46 am Post subject: |
I took some measurements of my engle cam, and it is between .890 and .910 in diameter between the lobes. According to Don Pauter, minimum turned diameter is 0.800
There isn't a lot of interference between my rod (caps) and the cam on this 82mm crank, but until I remove material and can gain clearance, I have no measurable parameter. _________________ 1958 Karmann Ghia owner |
Posted: Sun Nov 30, 2014 11:05 am Post subject: |
my thinking is thicker is stronger....but a flat can easyer to bend than a round...but..Ive never tested it on a clamshaft. |
AlteWagen Troll
