Help with oil sender
bignut
bignut is offline
PostPosted: Thu Dec 04, 2014 1:39 pm    Post subject: Help with oil sender Reply with quote
hi guys,
i am trying to find the correct oil pressure sender for this gauge, where can i get one?
this is what's on the car, what is this sender? oil light? oil temperature?
many thanks!
Tim
Tim Ding
saddlesore1
saddlesore1 is offline
PostPosted: Thu Dec 04, 2014 4:29 pm    Post subject: Reply with quote
That does not look like an original guage. However the sender unit is adjacent to oil filter line. Therfor it it would be the oils presure sending unit. Any Vdo one would work as long as the throw would be 0-70 to match gauge.
gerrymc547
gerrymc547 is offline
PostPosted: Sat Jul 18, 2015 8:15 am    Post subject: Oil pressure guage Reply with quote
No 356 came from the factory with an oil pressure guage, the one illustrated is aftermarket, and it's sender would be a large cylindrical can, about 25mm in diameter, 25 mm tall, with a large flange around it's base, and a single wiire terminal. The sender shown on the engine is for oil temperature, which was electronic, starting with the 356A. Pre-A's used a mechanical guage, opperated by a tube, fill with ether, which expanded, and moved the needle across the dial. Low oil pressure was warned by a simple idiot light. I think that, over the years, the matchup values between guage and sender varied, therefore, you will need some sort of catalog guidelines to buy a matching sender. You would then have a saleable pair.
jay abrams
jay abrams is offline
PostPosted: Sat Jul 18, 2015 5:23 pm    Post subject: Reply with quote
Bignut,
you just received an answer (first post, no less) from one of the most experienced and knowledgeable 356 experts on the planet. Homerun!
welcome Gerrymc547
Jay
water guy
water guy is offline
PostPosted: Thu Jul 23, 2015 7:30 pm    Post subject: Reply with quote
My pre a continental has an 9/55 moto meter oil temp gauge. Previous own cut the sending unit line, which was a capillary tube as stated above. I'm gonna send the gauge down to North Hollywood Speedo, as they can rebuild them back to spec...
'55 Porsche Continental
'63 Firetruck
