warwgn the 72 baja
Page: Previous  1, 2, 3 ... 5, 6, 7 ... 9, 10, 11  Next
warwgn
warwgn is offline
PostPosted: Sun Feb 08, 2015 2:48 pm    Post subject: Reply with quote
Rear suspension going back together.
can just make out the notch in the spring plates, went 5/8 to go with my 930 cv's.
POR15 is still wet so will get better pics later. Still need to figure out where to set the preload before I bolt it up.
warwgn
warwgn is offline
PostPosted: Mon Feb 09, 2015 10:26 pm    Post subject: Reply with quote
One side bolted up, the other side should go much eaiser tomorrow.
will have half a rolling chassis by tomorrow night, and got the bushing in for the front beam so the other half should get done by the weekend if all goes well.
warwgn
warwgn is offline
PostPosted: Tue Feb 10, 2015 2:11 pm    Post subject: Reply with quote
Well after spending the morning taking my daughter to the doctor for an ear infection igot to work on the other side Iit went almost to easy....
philthy
philthy is offline
PostPosted: Tue Feb 10, 2015 4:06 pm    Post subject: Reply with quote
Might wanna slap on a tranny strap.
74 Baja 1600 Dual ICT
warwgn
warwgn is offline
PostPosted: Tue Feb 10, 2015 4:49 pm    Post subject: Reply with quote
Oh yes that is in the plan, just haven'tgot that far yet. Truth be told Iit will be on the street 99 percent of the time but if i want to go off in the mud it will be ready......I hope!
philthy
philthy is offline
PostPosted: Tue Feb 10, 2015 5:28 pm    Post subject: Reply with quote
I'm curious to see what them 30's look like all around. $10 says you gotta pound the pan lip behind the tires for lockout turning.
warwgn
warwgn is offline
PostPosted: Tue Feb 10, 2015 6:19 pm    Post subject: Reply with quote
You just lost that 10 bucks! I got a plasma cutter and more sheet metal I can clerance that easy if need be, so no pounding. Pay up!
But you may be right it might need some attention.
warwgn
warwgn is offline
PostPosted: Tue Feb 10, 2015 9:29 pm    Post subject: Reply with quote
Had time to assemble the front suspension, added in adjusters and tacked up the hook and rod travel limeters. Tomorrow I have to pull it apart to weld the hook and rods then paint and it will be ready for final assemble of the front suspension. I am confident I will have a full rolling chassis by this weekend.
warwgn
warwgn is offline
PostPosted: Wed Feb 11, 2015 10:10 pm    Post subject: Reply with quote
All done, ready to assemble tomorrow.
sailtexas186548
sailtexas186548 is offline
PostPosted: Wed Feb 11, 2015 10:21 pm    Post subject: Reply with quote
Looking good, You're making a lot of progress!
it's more fun loud and dirty
Arkansauced
Arkansauced is offline
PostPosted: Thu Feb 12, 2015 1:15 pm    Post subject: Reply with quote
Trailing arms and spindles look a lot better than when I sent them!
warwgn
warwgn is offline
PostPosted: Thu Feb 12, 2015 7:09 pm    Post subject: Reply with quote
They work perfect too.
warwgn
warwgn is offline
PostPosted: Thu Feb 12, 2015 7:10 pm    Post subject: Reply with quote
Finally feel like real progress, no more jack stands!!
warwgn
warwgn is offline
PostPosted: Thu Feb 12, 2015 7:27 pm    Post subject: Reply with quote
think someone might owe me $10......
warwgn
warwgn is offline
PostPosted: Thu Feb 12, 2015 8:42 pm    Post subject: Reply with quote
Moved all the junk and cleaned it up for a better look.
philthy
philthy is offline
PostPosted: Fri Feb 13, 2015 6:48 am    Post subject: Reply with quote
Looks damn good and I think you are right lol Smile
warwgn
warwgn is offline
PostPosted: Sun Feb 15, 2015 7:37 am    Post subject: Reply with quote
Starting on the body today, first up cut the hole for the sun roof.
warwgn
warwgn is offline
PostPosted: Sun Feb 15, 2015 6:16 pm    Post subject: Reply with quote
Well did not go as planned, got side tracked patching holes and finishing up the fire wall.
the bottom of the pan is turning out well, still need to finish the rocker panels while it's on the side then will get to the sun roof later in the week.
warwgn
warwgn is offline
PostPosted: Tue Feb 17, 2015 9:02 pm    Post subject: Reply with quote
Templates are made for the driver side to box in the rocker panels. Now just need to turn cardboard into metal and weld it up.
warwgn
warwgn is offline
PostPosted: Sat Feb 21, 2015 9:51 am    Post subject: Reply with quote
Hard to see what's going on but it is coming along good, pics don't do it justice.
Pass side not done yet
Still have more clean up to do
no heater chanel anymore just welded up steel with an air gap inside.
Page 6 of 11
