Golf85 Samba Member
Posted: Sun Dec 07, 2014 7:47 pm Post subject: No Heat from the Heater... |
My 1985 VW Golf is not putting out any heat from the heater. Well, very little heat at best. In a attempt to fix it, I have replaced, the heater hoses, heater core, two main radiator hoses and thermostat at the water pump. Do these things need to be bleeded? The fan works and puts out air, but it is lukewarm at best. I am not sure what to try next. I might pull the return line to make sure the core is not blocked. The hose from the engine to the heater core is hot and hard, but the return is not. And it is a new core. Any ideas? |
rustfree1967bug Samba Member
Joined: November 16, 2006 Posts: 3436 Location: minnesota
Posted: Mon Dec 08, 2014 8:21 pm Post subject: |
I don't have an answer but i am having about the same problem with my '92 jetta. Old heater core blew so put in a new one as well as a new thermostat and new coolant. Anything below 30 degrees outside and it gets cold in the car. I don't understand what it could be _________________ '70 ghia
'69 ghia
'65 singlecab
'66 sunroof beetle
'74 bus
'67 so-42
IDA's...well... they talk dirty -MURZI |
Golf85 Samba Member
Posted: Mon Dec 08, 2014 9:19 pm Post subject: |
I think I found the answer. The foam on the control doors have disintegrated. This leave hole in the doors and bypasses the heater core. I found this video on YouTube. I am going to try just putting some duck tape over the holes. I don't think I am going to the trouble to rework them. Here is the link:
https://www.youtube.com/watch?v=4c1cjA-y7yE |
Posted: Tue Dec 09, 2014 1:02 pm Post subject: |
I should have mentioned that i already redid my doors with new foam. _________________ '70 ghia
'69 ghia
'65 singlecab
'66 sunroof beetle
'74 bus
'67 so-42
