OMT Samba Member
Posted: Wed Dec 10, 2014 2:03 am Post subject: Number 3 main oil feed |
Hello Everyone, hope your Holidays are very merry.
This is an 1956 case that has been line-bored 1.0mm(.040"). The oil feed to the bearing looks very restricted. The number 3 main bearing does not line up with the oil galley feed hole and relies on the saddle groove to supply oil to the main bearing and rods. This is how the engine was made. View the picture of an scrap number 3 bearing in position.
Can I open up some conversation about this and experiences?
Happy Holidays,
Al |
Mr. Motorhead Mad Scientist
Joined: January 06, 2004 Posts: 717 Location: Practitioner of 36hp alchemy
Posted: Wed Dec 10, 2014 3:08 pm Post subject: |
That's what makes .040" over about the most you can go on a 36hp case........The last .040" case I built about seven years ago is still going strong at 40k miles (a customers car). I had the same concerns so I cut a .020 groove on the outside of the bearing that matched the groove in the case to make myself feel better. _________________ 30 years experience in the sales of new and used auto parts!
36 horsepower parts for sale at http://www.aircooledresearch.com/
Or the new site at http://www.bugparts.com
Check out the Bonneville project:
http://aircooledresearch.com/docs/thebonnevilleproject.html#
"All limitations are self imposed."
Some Chinese guy |
OMT Samba Member
Posted: Thu Dec 11, 2014 12:16 am Post subject: Number 3 main |
Hello Mr. Motorhead,
Thank You for the reply.
Great idea to groove the main bearing.
Merry Christmas,
Al |
henry roberts Samba Member
Joined: February 24, 2003 Posts: 1275 Location: australia
Posted: Thu Dec 11, 2014 1:04 am Post subject: |
I don't have the full details, but believe Isaac (ritalin boy) who built the turbo 36hp seen here: http://www.thesamba.com/vw/forum/viewtopic.php?t=598127&start=0 added an extra gallery linking the main oil feed gallery in the LH case half into the gallery running between no 3 and 4 mains.
while we are on the topic, would there be any benefit to adding a groove similar to that on no. 3 main onto no. 1 main (offset towards the pulley to clear the stud) to add an extra oiling hole directly opposite to the existing one? |
OMT Samba Member
Posted: Tue Dec 16, 2014 12:48 am Post subject: Repco main bearings |
Repco number 3 main bearing has an groove cut in the center for oil feed.
Repco is the only maker i know of that grooves number 3 for oil feed.
The number 1 main is already grooved for oil feed.
Merry Christmas all! |
OMT Samba Member
Posted: Tue Dec 16, 2014 1:11 am Post subject: 912 main bearings |
912 main bearings, number 2 and 3 bearing saddles will need to be grooved for oil feed and retention slots machined. "Huge" oil feed holes, I wonder if this will effect oil pressure in the whole system? |
