Need help identifing these calipers.
gtrplyr
gtrplyr is offline
PostPosted: Thu Dec 11, 2014 11:11 pm    Post subject: Need help identifing these calipers. Reply with quote
I don't know what these are, i.e., manufacturer.
didget69
didget69 is offline
PostPosted: Fri Dec 12, 2014 8:43 am    Post subject: Reply with quote
They look like a standard Karmann Ghia front caliper...
http://www.bughaus.com/caliper.jpg
bnc
I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door.
manxdavid
Location: David Jones, Anglesey, North Wales, UK. Manxclub #678.
manxdavid is offline
PostPosted: Fri Dec 12, 2014 11:46 am    Post subject: Reply with quote
Not sure but I'd use harder bolts to hold it to the bracket, 12.9s, not 8.8s.
jsturtlebuggy
jsturtlebuggy is offline
PostPosted: Fri Dec 12, 2014 6:29 pm    Post subject: Reply with quote
They look like VW type III front calipers with the 2pins holding pads in place.
Also there are many kits available.
CB Performance sells disc brake kits and parts.
8.8 on bolts equal a Grade 5 rating.
10.9 on bolts equal a Grade 8 rating.
With anything to do with brakes you need be using the highest grade of bolts.
You don't want a bolt shearing in panic stop.
Joseph
Fair Oaks/Orangevale, CA
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960
didget69
didget69 is offline
PostPosted: Sat Dec 13, 2014 4:29 pm    Post subject: Reply with quote
The Type 1 & Type 3 2-pin pad calipers should be same.
bnc
gtrplyr
gtrplyr is offline
PostPosted: Sat Dec 13, 2014 10:32 pm    Post subject: Thanks! Reply with quote
I appreciate the responses and the advice, just put 12.9 bolts on all four corners. This little buggy has a long way to go before it's gonna be driven. Now to get a longer brake line to the rear brakes and we will be rolling!
