Lucatero Samba Member
Posted: Sun Dec 14, 2014 6:47 pm Post subject: Kadron Modification |
I recently acquired a set a Kadrons at a very good price. I started to take them apart, and noticed a funky modification. Does anyone know why someone would want to insert these copper tubes? _________________ 64 Beetle Type 1/Totaled
64 Beetle Type 1/Totaled after owning 5day!
71 Beetle Type 1
70 Karmann Ghia |
RailBoy Samba Member
Joined: March 10, 2008 Posts: 2904 Location: Virginia
Posted: Sun Dec 14, 2014 6:50 pm Post subject: |
Float Bowl Venting... They could have been on an off road car and used, this is a Mod that like Kaddie Shack does but better. For street use it is not needed.. So they say...
I will say this, looks cheesy, get some brake line the same matching diameter and make some new ones, they are pressed in... But yea, they let the float bowl ventalate..... RB _________________ [quote="smitty24"]"HELP, I ported my own heads and now have fire coming out my ass" .[/quote]
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76760 Location: Sneaking up behind you
Posted: Sun Dec 14, 2014 7:02 pm Post subject: |
Thanks for the reply. This makes sense, as they were on a Manx. I agree, it is done very cheesy. I'm planning on sending them to get jetted and rebuilt for my application. _________________ 64 Beetle Type 1/Totaled
71 Beetle Type 1
70 Karmann Ghia |
youngnstudly Samba Member
Joined: October 21, 2005 Posts: 833 Location: Whine Country (SF Bay area)
Posted: Sun Dec 14, 2014 7:56 pm Post subject: |
The method of fastening those tubes is certainly cheesy, but they are a good idea, IMO. I like the fact it makes filling the float bowl easy with carbs that are dry. After buying the "vent kit" from Lowbugget 10 years ago and trying to install it on my Kadrons, I opted to make my own kit using steel tubing so I could tack weld the tubes to the A/C support stud. The one from LB wasn't all that great after I got it in my hands.
I started seeing others perform this mod in the same fashion, so apparently I wasn't the only one that thought that tube needed to be secured better than the loctite method that Lowbugget suggested. FYI, I believe Kaddie Shack welds their "Vent kit" tubes in place as well. AJ from LB was never fond of leaving the support stud in place (hinders airflow), hence the reason he never offered his kit in a welded version.
Andy _________________ The economy is in a state of disaster, we have NO time for common sense! |
bugguy076 Samba Member
Joined: December 11, 2007 Posts: 1068 Location: Dover, PA.
Posted: Mon Dec 15, 2014 5:45 pm Post subject: |
I have an older set of Kads. Maybe 20 years old. They have tubes that protrude at an angle half way across the carb opening. Look to be factory installed. I left them installed so the fuel won't slosh out of bowl in hard cornering. _________________ Grubby Fingers Racing
1976 Drag Bug
1967 Street Bug |
