55samba Samba Member
Joined: June 21, 2002 Posts: 805 Location: CA Bay Area
Posted: Sun Dec 14, 2014 9:09 pm Post subject: What years will a replacement fit? |
Mine was cut, I could patch it but I am wondering what year buses would have the same replacement part? The circled piece that the shifter, e-brake, and throttle lever attach to. My bus is a July 1962 built bus. Thanks
easy e Samba Member
Joined: May 28, 2008 Posts: 3930 Location: 1 hr north of Santa Barbara
Posted: Mon Dec 15, 2014 11:32 am Post subject: |
mid'59 (1959 Bus starting at chassis # 501707) - 1967 |
Krustybus Samba Member
Joined: February 16, 2004 Posts: 442 Location: SE Michigan
Posted: Mon Dec 15, 2014 12:31 pm Post subject: |
A 66-67 donor piece would require a matching front shift rod. It would be perfectly functional, but if you want stock, use a piece up to 65 _________________ Tim |
Posted: Mon Dec 15, 2014 1:34 pm Post subject: |
Thanks guys! |
EmpiGT Samba Member
Posted: Mon Dec 15, 2014 2:28 pm Post subject: |
Krustybus wrote: |
A 66-67 donor piece would require a matching front shift rod. It would be perfectly functional |
And shift better. I was surprised how nice a 66-67 shifts compared to earlier busses. |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19670 Location: Land of Whine and Phonies
Posted: Mon Dec 15, 2014 2:53 pm Post subject: |
Are the floor stampings actually different or is it the shift rod carrier/shifter that is? Just curious. _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
EmpiGT Samba Member
Posted: Mon Dec 15, 2014 11:53 pm Post subject: |
crofty wrote: |
Are the floor stampings actually different or is it the shift rod carrier/shifter that is? Just curious. |
Just the shift rod carrier. 66-67 has a pin for the rod to pivot on. |
Posted: Tue Dec 16, 2014 8:13 am Post subject: |
EmpiGT wrote: |
crofty wrote: |
That's what I thought. _________________ Your Vanagon sucks, Stop waving at me.
Clara Samba Member
Posted: Tue Dec 16, 2014 8:55 am Post subject: |
EmpiGT wrote: |
Krustybus wrote: |
I have not noticed this. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69733 Location: Phoenix Metro
Posted: Tue Dec 16, 2014 9:10 am Post subject: |
Clara wrote: |
EmpiGT wrote: |
Krustybus wrote: |
Hmmm, I don't remember my '66 shifting better.
My friend's '61 Bus shifts NICE. He replaced almost everything with brand new stuff and re-welded and reshaped the actual shift circle on the shifter to reduce all wear. It is super tight, I assume like it was when new. _________________ How to Post Photos
Posted: Tue Dec 16, 2014 9:24 am Post subject: |
Anyone have one of these sections pictured above? |
EmpiGT Samba Member
Posted: Tue Dec 16, 2014 5:05 pm Post subject: |
EverettB wrote: |
Clara wrote: |
EmpiGT wrote: |
Krustybus wrote: |
My friend's '61 Bus shifts NICE. He replaced almost everything with brand new stuff and re-welded and reshaped the actual shift circle on the shifter to reduce all wear. It is super tight, I assume like it was when new. |
In a 67 with all good bushings you can really tell a difference, easier to get in reverse and just feels less sloppy. that or all the earlier busses have had a bad bushing somewhere, But I know of one early I replaced all of the couplers and guide bushings and it was still not as good as a 67 I had with with unknown age couplers and bushings. |
Clara Samba Member
Posted: Wed Dec 17, 2014 8:42 am Post subject: |
I have noticed a big difference between a bus with sloppy bushings and after it was serviced with new bushings and polished & lubed tube, but not between 66/67 and other years.
As Everett said, even the condition of the shift stick comes into play. When that is worn enough, you can even shift into reverse w/o pressing down.
And the condition of the nose cone bushings.
And the wear of the pieces in the shift selector area of the transmission.
And whether the front shift rod has been messed up by someone who was unskilled at removing the front shift coupler.
It must have just been that the other pieces were in good order in your 66/67, and the pre 66 bus you are thinking of had worn pieces.
Sometimes I have taken the shift rod out to replace bushings and found not so much wear.
And sometimes it is really worn. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14216 Location: Casa de Oro, California
Posted: Wed Dec 17, 2014 4:28 pm Post subject: |
If I can add on opinion, here,
I have a '65 that's all refreshed and a '67 that I just refreshed. The '67 with the pin and the shorter throw feels a lot better than the '65 style but both are very clean feeling. This is including the trans axles having great syncros, detents, bushings, and all tight mounts and couplers.
In other words, the way VW built them when new is very decent but I feel that the '67 style was a marked improvement. |
EmpiGT Samba Member
Posted: Wed Dec 17, 2014 4:54 pm Post subject: |
Thanks for the 2nd opinion in favor of 66-67 shifter. To me it almost feels like it has a short throw shifter kit on it compared to early busses. |
Posted: Thu Dec 18, 2014 11:41 am Post subject: |
EmpiGT wrote: |
Kinda makes sense. The shifter is slightly longer below the floor than earlier ones.
http://www.thesamba.com/vw/forum/viewtopic.php?t=190619 _________________ Tim |
BarryL Samba Member
Posted: Thu Dec 18, 2014 12:07 pm Post subject: |
Krustybus wrote: |
Kinda makes sense. The shifter is slightly longer below the floor than earlier ones. |
And it doesn't have that anti-chatter plastic ring with the spring clip compressing it around the shift rod (which is an excellent system improvement from the "M" spring style). |
brettsvw Samba Member
Joined: November 22, 2007 Posts: 2145 Location: Florida
