cncwhiz Samba Member
Joined: February 28, 2005 Posts: 226 Location: Gardnerville, NV
Posted: Tue Dec 16, 2014 6:19 pm Post subject: When to switch to stroker pistons. |
Do I have to use stroker pistons for a 78mm stroke? |
GTV Samba Member
Posted: Tue Dec 16, 2014 6:19 pm Post subject: |
You don't have to but it will make assembly easier. _________________ EMPI Power Rules! |
raul arrese Samba Member
Joined: July 23, 2006 Posts: 1329 Location: miami florida
Posted: Tue Dec 16, 2014 6:59 pm Post subject: Re: When to switch to stroker pistons. |
cncwhiz wrote: |
I wouldn't build a 78 mm crank without B pistons , use the stroker pistons and keep your motor narrow _________________ " Hot vw feature , may 2014 issue "
" 2013 Bug Jam class winner "
" Bug Jam best motor and best paint "
" 2013 Lakeland Classic Best of Show "
" 2014 Show and Shine , First in class "
Like my facebook https://www.facebook.com/pages/Raul-Arrese-custom-fabrication-and-performance/1832968110262608 |
Posted: Tue Dec 16, 2014 7:47 pm Post subject: Re: When to switch to stroker pistons. |
I recommend switching at 76mm.
74mm w/5.4 or 5.325" rods and A pistons
76-78 w/5.5 rods and B pistons
82 w/5.4" rods and B pistons. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5363 Location: Lefty, CA
modok Samba Member
Joined: October 30, 2009 Posts: 26781 Location: Colorado Springs
Posted: Thu Dec 18, 2014 5:51 pm Post subject: |
78 with stock rods you will have to deck the case zero, .020, .040, or .060 depending on which "B" pistons and cylinders you get. |
Redlines Samba Member
Joined: June 07, 2009 Posts: 168 Location: Fredonia, NY
Posted: Fri Jan 02, 2015 5:09 pm Post subject: |
modok wrote: |
What does that mean? Are some "B" pistons and cylinders longer/shorter than others??????? |
modok Samba Member
hsosa1 Samba Member
Joined: January 17, 2005 Posts: 1897 Location: Fontana
Posted: Thu Jan 15, 2015 10:28 pm Post subject: |
To piggyback going from a 69 to 78crankshaft we cut the barrels down .60 on the 1914 build. Stock rods. alum case so now I would need 5.5 rods? _________________ Just Cruzin Sur Califas VW Car Club est♤1998 |
mark tucker Samba Member
Posted: Fri Jan 16, 2015 12:21 am Post subject: |
78 + b pistons and 5.5 long rods and about a .020-.040" shim under the barrels. better yet just get a 82 stroke crank.
modok Samba Member
Posted: Fri Jan 16, 2015 12:51 am Post subject: |
hsosa1 wrote: |
To piggyback going from a 69 to 78crankshaft we cut the barrels down .60 on the 1914 build. Stock rods. alum case so now I would need 5.5 rods? |
no, 5.4 would be about right. |
Posted: Fri Jan 16, 2015 7:26 am Post subject: |
no 5.4 is too short unless you cut the cylinders/ deck the crap out of the case. |
TinCanFab Samba Member
Joined: April 04, 2006 Posts: 2743 Location: Waterford, California
