Xivvit Samba Member
Posted: Wed Dec 17, 2014 10:15 am Post subject: Dead Battery?!? |
OK, I swear to god I didn't leave the lights on. Since I live on a hill I tried to compression start it without any luck. I took the battery to O'Reilly's who is charging now. There has been an occasional buzzing under the dash recently. Are they connected? What could draw the battery down overnight?
Thanks! |
toddb_67 Samba Member
Joined: November 28, 2003 Posts: 1313 Location: Hansville, WA
Posted: Wed Dec 17, 2014 12:16 pm Post subject: |
While it's at O'Reilly's have them do a load test on your battery. They probably will anyways since they would love for you to buy a new battery from them. You don't say what year your car is but the buzzing could be your seat belt buzzer? And if was continuously buzzing that could drain your battery overnight with the cold conditions and a weak battery. Otherwise you could use a multimeter and read the resistance without your battery connected and see how much of a load your electrical system is drawing just sitting there without any lights on, radio, etc. If it is an excessive amount then the tricky part is finding what is drawing the load. _________________ 1970 Pastel White Westfalia
1971 Super Beetle Convertible (sold) http://www.thesamba.com/vw/forum/viewtopic.php?t=582365&highlight=
1970 Squareback "Savanna" (sold)
https://www.thesamba.com/vw/forum/viewtopic.php?t=714683
1974 Karmann Ghia- current project, 1967cc engine. https://www.thesamba.com/vw/forum/viewtopic.php?t=775207
“I have never in my life learned anything from any man who agreed with me.” - Dudley Field Malone |
Joined: July 02, 2003 Posts: 593 Location: Florida Space Coast
Posted: Wed Dec 17, 2014 12:22 pm Post subject: |
If there is any draw with it shut-off, than that is too much.
A quick check is with key off remove negative battery cable from battery, then touch it back and look for spark.
And while it is off, clean connections (otherwise gen/alt does not charge battery) _________________ 1974 Standard Beetle to Baja Bug
http://picasaweb.google.com/fvee1234/BajaBug02# |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Wed Dec 17, 2014 9:18 pm Post subject: |
Has your commute changed lately? If you're daily driving is reduced, the battery may not have a chance to recharge the conventional way. _________________
EverettB wrote: |
FU#5 |
