kielbasa Samba Member
Joined: November 28, 2007 Posts: 1443 Location: Garbage Grove, CA
Posted: Wed Dec 17, 2014 2:00 pm Post subject: mag seat lug nuts |
Anyone know where to find or if they even make a longer mag seat lug nut with a short Shank? The only studs that will work with my setup is too long by ~1/2". I looked all over online snd could only find longer ones with the shank being the longer.
If not I'll just end up making a jig to chunk the studs up on a lathe and cut them down . _________________ Gotta give my props to:
Wolfsburg Motorsports
Dubbers Toy Box
Jeff's VW Speed and Fab
4inbore.com
Kielbasa Industries |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Wed Dec 17, 2014 2:46 pm Post subject: |
How much time are you gonna waste looking for extra short lug bolts before you just cut some down? If you looked closer you'd probably realize you could use the longer ones without hitting anything? _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Wed Dec 17, 2014 3:40 pm Post subject: |
Already bought the shortest set available from Dorman with the correct knurl.
And I'm no idiot. Of course they are too long I wouldn't just assume.....
I don't work on this car everyday and my buddies machine shop is an hour away from me. So I have time to dick around looking for things that could work before I head over to machine a jig and then machine the studs.
I typically don't post until I come up empty handed from my fair share of research. _________________ Gotta give my props to:
Dubbers Toy Box
4inbore.com
Posted: Wed Dec 17, 2014 3:52 pm Post subject: |
Okay, but usually lug bolts go through the wheel/drum or rotor into open space for 1" at least? I still say you can grind them off and taper the snout a little with your grinder yourself. _________________ https://imgur.com/user/FisherSquareback/posts
Posted: Wed Dec 17, 2014 4:30 pm Post subject: |
I'm not using lug bolts. _________________ Gotta give my props to:
Dubbers Toy Box
4inbore.com
Posted: Wed Dec 17, 2014 4:58 pm Post subject: |
Yeah, you never show us any pics of what you have and are trying to accomplish? _________________ https://imgur.com/user/FisherSquareback/posts
Posted: Wed Dec 17, 2014 5:14 pm Post subject: |
I figured a stud and a mag seat lug nut where obvious... not sure how someone can get lug bolt from that?
Sorry _________________ Gotta give my props to:
Dubbers Toy Box
4inbore.com
Posted: Wed Dec 17, 2014 9:02 pm Post subject: |
Here are the 14mm studs which are too fat and long for my wheels. I need a shorty 12mm stud. So I bought the shortest ones they make and will have to cut them down unless I can find myself a longer nut.
Dubbers Toy Box
4inbore.com
