MMMVW Samba Member
Posted: Wed Dec 17, 2014 8:02 pm Post subject: Will using rattle can gloss screw up my pro paint job plans? |
I am working on a '63 bug and pretty much have the car covered in primer but would like to cover it with rattle can spray to help protect the primer and also to identify any imperfections in the bodywork. it's going to take a few months before I can arrange to get it painted professionally. Rattle can is my short term solution but I don't want it to mess up the body when the professional paint job is performed. Any thoughts with this approach?
Thanks for the comments. |
kman Samba Member
Joined: November 04, 2005 Posts: 739 Location: Michigan
Posted: Thu Dec 18, 2014 5:39 am Post subject: |
Don't do it. Assuming you used a 2 part primer, there is a decent amount of protection there. You will need to rescuff the primer right before painting to get a fresh surface and not paint over weathering/oxidation. Rattle can paints can lift especially at edges when applying new paint. The solvent of new paint can dissolve it and cause problems. Plus it will be your weakest layer of paint over the long run.
A professional painter will curse your name when seeing the rattle can paint. Some will insist that it all be sanded off. |
eyetzr Samba Member
Joined: October 09, 2013 Posts: 1425 Location: Toronto, Ontario. Canada
Posted: Thu Dec 18, 2014 6:26 am Post subject: |
If you want to use the rattle can paint as a guide coat & YOU WILL remove it all, go ahead. I have done this & it works OK. Normally if you have sprayed primer & primer surfacer on, you would continue to prep & then paint. As the previous stated you can leave the prime as is if you used a quality 2 part primer surfacer. _________________ I think he meant "rare", as in "not well-done" |
MMMVW Samba Member
Posted: Fri Dec 19, 2014 6:53 pm Post subject: |
Good info. I will stick with the primer only option. Thanks. |
panicman Samba Member
Joined: December 18, 2011 Posts: 2290 Location: Canby, OR
Posted: Sun Dec 21, 2014 1:27 am Post subject: |
I had to remove ALL spray can primer and paint from the body prior to priming and painting. It was not worth the hassle. _________________ Plate of shrimp |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Sun Dec 21, 2014 9:27 am Post subject: |
I just roughed numerous coats of thin red oxide rattle can/body work primer and did not sand it All off. I've never had it peel/lift. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
modok Samba Member
Joined: October 30, 2009 Posts: 26785 Location: Colorado Springs
Posted: Thu Dec 25, 2014 3:40 pm Post subject: |
You can leave the car in urethane sanding primer for years no problem. It is porous but if you put on a coat of primer/sealer under like your supposed to do it then it won't rust at all. |
