vwteckit Samba Member
Joined: August 27, 2014 Posts: 5 Location: suffolk va
Posted: Thu Dec 18, 2014 1:17 am Post subject: breather filters on top of valve covers |
I want to go with a clean look and was wondering if its ok to just run seperate air breathers just put one air filter breather on top of the valve covers need some input on any con's on doing this? |
VWCOOL Samba Member
Joined: June 02, 2006 Posts: 1821 Location: Down under
Posted: Thu Dec 18, 2014 3:51 am Post subject: |
Welcome!
Breathers on valve covers... Maybe not the best idea as it blows the oil up the pushrod tubes, back to the rocker covers |
Aussiebug Samba Member
Joined: June 03, 2002 Posts: 2162 Location: Adelaide Australia
Posted: Thu Dec 18, 2014 5:28 am Post subject: Re: breather filters on top of valve covers |
vwteckit wrote: |
Why do you need breathers on the rocker covers anyway?
If the normal breather at the oil filler neck is connected to the stock air cleaner, you get a combination of a slight vacuum in the air cleaner pulling fumes into the air cleaner and a slight positive pressure from the sprial groove on the crankshaft pulling fresh air into the crankcase through the slots behind the engine pulley - combined they very effectively pull fumes out of the crankcase and back through the engine for re-burning.
If you really need breathers in the rockers covers it might indicate worn pistons rings and excessive blow-by. _________________ Rob
Rob and Dave's aircooled VW pages
Repairs and maintenance for the home mechanic
http://www.vw-resource.com |
Posted: Thu Dec 18, 2014 11:52 am Post subject: |
Thanks for the replay i just see so many engine runing breathers on there covers i have a new 1915cc and just want it to run good and efficiently would it be acceptable if i just run a breather at the oil neck filler and leave it be im running 44 dual webers with filter screens on top of the stacks and i really dont want to change it. |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
Juanito84 Samba Member
Joined: March 17, 2012 Posts: 2436 Location: Colorado Mountains
Posted: Thu Dec 18, 2014 11:12 pm Post subject: |
Most V8's and such with a valve cover breather filter have a PCV valve that draws air through the filter. I'm going to put filtered air to the valve covers too but I will have a small blower on the oil filler tower to suck air through the whole system. _________________ If a water cooled engine cools its water with air, isn't it just an overcomplicated air cooled engine? |
Posted: Fri Dec 19, 2014 12:00 am Post subject: |
Multi69s wrote: |
You really need to hook up some sort of breather. Not just a dangling vent line. Especially since you are just running screens. You will probably have significant blow by in just a short period of time. I forecast a very short engine life for you, probably half of what you should have (if you are lucky). Intake screens are for drag racers or show cars, not for something you are going to drive. But hey, it's your wallet, so to each his own. |
My screens are are double stacked with a filter lining in between:)Yea i was thinking i do need some sort of breather setup |
