poorpake Samba Member
Posted: Thu Dec 18, 2014 2:34 pm Post subject: throw out bearing?? |
Hello I hope this is the correct place to post this. First time posting... long time reader.
1985 Vanagon
2.2 L subaru Legacy powerplant (rebuild from CCR)
I purchased and installed Small Car conversion kit purchased from their web page. The system has about 30,000 mi on it at this point. Running very well with just a few idle, vacuum hoses issues to chase down.
Recently;
I am hearing the classic high pitched squeal noise of a bearing (throw out or slave??) when i begin to let the clutch out in 1st gear. The noise goes away once the clutch pedal is is released and the van is moving down the road. Engine and road noise might drown out the noise shifting to 2nd- 3rd- etc.
Sometimes there is no noise and the clutch pedal feels normal through its travel while engaging the flywheel.
When the noise is present, it feels like the clutch engages much sooner in the travel of the pedal.
1) throw out bearing or slave? Is it maybe pilot bearing?
2) @ 30,000 mi it seems early to have a bearing problem. Has anyone seen this in other conversions?
3) Can i get away with swapping out the bearings or do the whole clutch job?
4) advice or questions
b |
'88MoneyPit Samba Member
Joined: August 26, 2013 Posts: 146 Location: California
Posted: Thu Dec 18, 2014 3:35 pm Post subject: |
Could be a throw out bearing and hopefully not a messed up pressure plate. We have a buggy whose throw out fork broke when I went to shift last summer. Bearing exploded and bent the pressure plate. Check your throw out bearing fork for typical VW style wear. If the Clutch and PP are ok, you dont have to replace.
S |
cvbill Samba Member
Joined: May 24, 2007 Posts: 208 Location: Carmel Valley, CA
Posted: Fri Dec 19, 2014 6:00 am Post subject: |
Just had this happen on my '89 Syncro. Noise and pedal travel/ engagement issue just as you describe. Found that the pilot bearing totally shot, rollers and inner race gone, only outer race in flywheel left. Didn't see any debris in bell housing either. Only found the problem when using the temp pilot shaft to center the clutch plate. Replaced throw out bearing, clutch plate, pilot bearing. All VW parts. I am running a 2.2 Subaru setup as supplied by Kennedy Engineered Products. _________________ Ideology trumps Reality - no exceptions |
Syncro Jael Samba Member
Posted: Fri Dec 19, 2014 7:17 am Post subject: |
For me, once the effort was made to pull the engine or tranny, I always replace the entire clutch assembly. It is a good feeling to close things up with all new parts.
But this is just me, and I am very anal about preventative maintenance.
_________________ 1987 Syncro Westfalia Hightop - NAHT
Subaru EJ25 Forged Frankenmotor, Triple Knob.
Jael = (Mountain Goat) |
alaskadan Samba Member
Joined: January 09, 2013 Posts: 1857 Location: anchor pt. alaska
Posted: Fri Dec 19, 2014 7:27 am Post subject: |
Not sure how old your kit is. I have a 2.5 with SC kit that is a year and a half old. Did your kit require putting the spacer in the master cylinder? |
Posted: Sun Dec 21, 2014 3:52 pm Post subject: |
No spacer for my kit. SC didnt have that available at the time.
They did offer to send me a spacer... not %100 sure what it does. When the system was brand new i thought the clutch engaged quite late in its travel. So maybe that is addressed w/ the spacer??
So anyway i will pull it, inspect and likely replace all.
Thanks for the help.
b |
kalispell365 Samba Member
Posted: Mon Dec 22, 2014 4:20 pm Post subject: |
Kalispell365
i have not seen this fix. Is there something about the clutch, pedal, small car housing that causes the TOB to fail?
This looks like a good product. Will likely purchase. Just want to know the specifics of my current set up.
b |
Posted: Mon Dec 22, 2014 4:27 pm Post subject: |
Here is a large thread about this problem. The clutch slave/ throwout bearing is being overextended because of the difference in fluid volume between the stock Vanagon clutch master and the later VW golf/ Jetta/ Beetle internal slave used on your Smallcar setup. The pedal modification by Fred changes the stroke length and will remedy this permanently.
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...;start=160 _________________ 1983 Diesel Vanagon Westfalia chassis with Subaru 2.2l |
