akear Samba Member
Joined: August 18, 2013 Posts: 359 Location: Los Angeles
Posted: Fri Dec 19, 2014 3:14 pm Post subject: Which pre heat (stove pipe) do I need? |
I have a NOS muffler to install on a 1600sp, which has the heat riser return pipe on the left (driver) side. For this muffler, which stove pipe in the photo is correct? I think upper works for heat riser return on either side, and lower is left side only, correct? Also, if either works is one preferable?
bikelash Samba Member
Joined: January 19, 2013 Posts: 370 Location: Monument, Colorado
Posted: Fri Dec 19, 2014 3:56 pm Post subject: |
The upper is the only type I have used on all of my late models. Use whichever fits best with your tin. I have never seen then lower so someone else will have to chime in about it. _________________ Ace
64 baja sold
72 sb wrecked
69 baja sold
69 std sold
72 sb sold
54 std sold
74 sb-ongoing
88 westy-ongoing |
akear Samba Member
Posted: Fri Dec 19, 2014 4:22 pm Post subject: |
I should have clarified that I don't have this piece and need to buy. The photo is from the classifieds and depicts the 2 different styles that seem to be available. |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12721 Location: on a bike ride somewhere
Posted: Fri Dec 19, 2014 4:35 pm Post subject: |
x2 on never seeing the bottom one. Are you SURE you want to install that NOS muffler? I would be happy to purchase it from you....
www.airschooled.com |
D/A/N Samba Member
Posted: Fri Dec 19, 2014 4:57 pm Post subject: Re: Which pre heat (stove pipe) do I need? |
akear wrote: |
Those have no relation to the positioning of the heat riser on the muffler. They'll mount beneath the passenger side of the tin. Just follow the large hose from the oil bath down to the tin in this pic from the gallery....that hose connects to the pre-heat pipe under the tin
akear Samba Member
Posted: Fri Dec 19, 2014 5:34 pm Post subject: |
Thanks for the help. I should have searched a little more thoroughly as I also found this in another thread, which explains the differences:
glutamodo wrote: |
There were two different styles of those stove pipes, one mounted via on tin screw and one exhaust stud. The the other via just two tin screws. In the past I speculated that they changed the design because the exhaust stud tab was prone to failure but I recently read the 1972 Technical Improvements presentation in the Technical archives here and found this regarding them trying out a "right pipe" manifold preheat muffler.... excerpt:
Anyway, the 1972 "mini-manual" that VW sold to go along with their dumbed-down 1972 owner's manual mentions installing the old style "carburetor pre-heat adapter" here:
gt1953 Samba Member
Posted: Sat Dec 20, 2014 7:44 am Post subject: |
I am just glad that you want to do it correctly. Good for you. Did you add the thermostat and flaps also? _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
akear Samba Member
Posted: Sat Dec 20, 2014 11:41 am Post subject: |
Thermostat is on the list; flaps might be in there I’m not sure. Meanwhile I’m trying to sort things out as I go. This is a very stock KG, except for abuse from the previous owner’s mechanic. She said she had a new exhaust put on, and since then it stayed loud and the heat never worked again. Well it was loud because the mechanic put on an Empi GT exhaust and the heat didn’t work because they threw out the heater boxes and put in J tubes. I suspect that’s when the thermostat and stovepipe and probably a few other original pieces went into the trash. |
diablosandwich Samba Member
Joined: January 15, 2012 Posts: 469 Location: Illinois
