Iguana Samba Member
Posted: Wed Apr 22, 2015 5:15 pm Post subject: |
wythac wrote: |
Are you going to wrap the exhaust as it passes near the air cleaner? Seems like it might melt being that close.
I am now rethinking mounting my identical air cleaner up high on my cage....I'll wait until after you make your "little run" to La Paz and see how it holds up where you put it.
Good luck with finishing your build in time, and best of luck for your race as well. |
NO NO NO .. I never wrap exhausts as it tends to create more issues than solutions.
The Air Cleaner had no issues on the test run but it has a few small tweaks to be done before we do the final run. |
Iguana Samba Member
Posted: Wed Apr 22, 2015 5:16 pm Post subject: |
dbsmith wrote: |
Brad
Where do you mount the battery? |
Battery is under the rear parcel tray area. The DS has a battery box setup there |
wythac Samba Member
Posted: Wed Apr 22, 2015 6:07 pm Post subject: |
I'll be watching. I have my airbox already but not crazy about my options for ducting to two carburetors to an overhead mounting location. Much simpler with your single intake and lower mount. I'll start looking for spots on my engine cage that might work.
Clock is ticking man,quit screwing around reading posts! |
Iguana Samba Member
Posted: Mon May 04, 2015 7:33 pm Post subject: |
Buggy is Done, race was run, We finished with a few small issue but nothing to do with design or function. We learnt a lot and doing 1000 plus race miles was never enough so after the race we took a day off in Cabao, re-fueled and then drove the 1200 odd miles back to Valley Center, now that's a cool DualSports !!
Big thanks to everyone who helped out full report to follow.
ellobo Samba Member
Joined: December 18, 2004 Posts: 286 Location: O.C. California
Posted: Mon May 04, 2015 7:43 pm Post subject: |
Great going Brad. I've been following you thru the entire journey and jealous with envy. Again.. Congrats to you and your team of supporters... |
andygere Samba Member
Joined: January 31, 2014 Posts: 600 Location: Central Coast, CA
Posted: Mon May 04, 2015 8:08 pm Post subject: |
Cool build thread and great story. You guys make it look easy. |
Iguana Samba Member
Posted: Tue May 05, 2015 5:50 pm Post subject: |
wythac Samba Member
Posted: Tue May 05, 2015 11:06 pm Post subject: |
Well done. Looks like the build and the drive were all you were shootin' for!
What's next? |
neohic Samba Member
Joined: June 30, 2012 Posts: 190 Location: Colorado Springs, CO
Posted: Wed May 06, 2015 5:46 am Post subject: |
Outstanding, sir! A huge tin of the cap! _________________ -Ben
I like to build stuff... |
Iguana Samba Member
Posted: Sun May 10, 2015 5:30 pm Post subject: |
We had a LOT of people tells us we would never make it, had no idea, where stupid for trying etc. Funnily enough many of them have never raced shit and have no IDEA WTF they are talking about. It was only through the support of our Sponsors and awesome input from our Team Members that we succeeded where many thought we would fail.
I can not emphasis enough the need to use quality parts and skilled labor when you try such things. The only parts we had on the cars that let us down where from EMPI and another Chinese supplier. The majority of our Drivers where novice and did a great job of keeping it together. The suspension setup from Sonny at DownSouth Motorsports was thanked more than once as we his some pretty gnarly stuff at speed.
Anyway thanks again to everyone who gave us support and if you want any feedback on the products we used please ask. I will be doing up full reviews and posting as we go and I am VERY HAPPY to say that with the exception of those items mentioned above I will be using the same suppliers in all future builds without change.
A quick List of what we ended up with
Body - Meyers Manx DualSport Kit (MeyersManx.com)
Chassis - Meyers Manx Baja Edition Chassis
Front Suspension 4" over 1 3/4" Arms, King Kong Spindles Foddrill Motorsports (http://foddrillmotorsports.com/)
Rear Suspension 3 x 3 UpYerBug Micro's (UpYerBug.com)
Brakes - Jamar Performance Pro X and 14" Hanging Pedals, Turning Brake, 4 Pot Calipers, 2 Pot e-Brake, Micro Stubs rear (http://www.jamarperformance.com/)
Shocks - DownSouth Motorsports Custom 2.5" Fox Piggy Backs ( 10 up front 12" out back) (http://downsouthmotorsports.com/)
Engine - Subaru EJ 25 SOHC with stock ECU built by Chris at SubiWorks (http://www.subieworks.com)
Transmission - SubiWorks Built SubaruGears R&P Offroad Spec 4.86: 1 (subarugears.com)
Wheels - Method Race Wheels - 15 x 4.5 front, 15 x 7" BeadLock rear (http://www.methodracewheels.com/)
Seats - PRP Seats Baja Edition Suspension Seats with Lumbar Supports (prpseats.com)
Electrics - Pro Wires Material - Custom Loom and Install (prowireusa.com)
Comms - Rugged Radios in Car Comms with Rugged Radios VHF Car to Car (ruggedradios.com)
Headlights - JW Speaker 7" Projector from HeadLight Revolution (headlightrevolution.com)
Design - 202 Solution BendTech / Arclight CNC Production (http://www.bend-tech.com/) & (ArcLightCNC.com)
Fabrication - SteelArt Creations Brendale QLD - Paul did an awesome job, no cracks, no stress, no issues (steelart.com.au) |
Iguana Samba Member
Posted: Sun May 10, 2015 8:37 pm Post subject: |
Ok so I have had a few people ask what it took to get it done and even suggest we may have had smoke and mirrors. Now luckily I am a better fabricator than video editor but I thought I would smash out a bit of a time lapse to show it all unfold from when my mad Aussie Mates got here till completion. Taking just over 12 minutes you would never guess we worked from 8.00 am most days till 2 or 3 am then next day for pretty much 3 weeks straight. I say pretty much as we skipped a few days worth of sleep when we needed to make time lines.
Anyway pictures are worth a thousand words so excusing my awesome editing hopefully it will put a smile on some peoples faces.
I must again iterate though if the parts we used were not up to task we would have failed cause our time line sure as hell didn't have time in it to chase suppliers or get stuff fixed.
Enjoy ..
Glamis Addict Samba Member
Joined: March 21, 2010 Posts: 99 Location: Riverside,Ca.
Posted: Thu May 14, 2015 10:11 pm Post subject: |
Iguana wrote: |
Enjoy ..
Smoke and mirrors?Lol.
I had to go back and review my text messages to see what day it was I was at your shop.It was Jan 23.
I'm witness to the fact that on that day this car we see was not much more than a plan.You had taken delivery of the wheels that day.
Folks,Brad and apparently his fab team is the real deal.I saw the diner car the engine was sourced from,saw the pan they had initially intended to use,the big ass pile of wire loom that needed to be chopped and reassembled,saw the extra body hanging from the hoist as a mock tool.
Honestly I had to question if this project could be completed within the time line when i started reading this thread.After meeting Brad,I had no question he and his team would make their goal.
The car looks great,Brad.Sounds like it performed well.
I want one! _________________ AKA RDP's Gelcoater |
Iguana Samba Member
Posted: Thu May 14, 2015 10:41 pm Post subject: |
Hey, thanks for the comments I still wish we could have made the gel coat porn work out your worked looked sweet and the ease at which your layed down the lines on the body made me appreciate what a talent you have.
Hopefully we will have them in production in the not to distant future, the wheels are turning, the costing's are being done. |
Iguana Samba Member
Posted: Sun May 17, 2015 11:40 pm Post subject: |
Well the dust has begun to settle and the car has been cleaned. It will get some TLC over the coming weeks and have the RacePak removed and rear seat etc put in to put it back on family duties.
impaleale Samba Member
Posted: Mon May 18, 2015 9:06 am Post subject: |
I'm dying to see your time! That car and your team is very impressive! I felt like I was reading the prequal to Dust To Glory. Thanks for keeping the thread going. |
