Henrik_K Samba Member
Joined: November 17, 2013 Posts: 181 Location: Denmark
Posted: Sat Dec 20, 2014 1:20 pm Post subject: Help Id O-rings in gasketset - Type4 - AP1800 engine. |
Just opened my new German gasket kit today.
Found 3 O-rings that I'm not really sure where should go. Can someone please give me some pointers?
Thanks... |
busdaddy Samba Member
Posted: Sat Dec 20, 2014 1:29 pm Post subject: |
L to R+ oil pump, taco plate and the third looks like the sump plate, is it stiff fiber or a rubber ring? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Dec 20, 2014 2:09 pm Post subject: |
Somewhere in the package you should have a flywheel o-ring. The white one if it is an o-ring looks a bit thick for the flywheel and the flywheel ones I have seen have always been black with a graphite coat when new, but don't know what else your white one would be.
Tcash Samba Member
Posted: Sat Dec 20, 2014 2:18 pm Post subject: |
Open the plastic bag up and Lay out and number the gaskets. If you want to know where they go. |
timvw7476 Samba Member
Posted: Sat Dec 20, 2014 2:25 pm Post subject: Help ld O-rings in gasketset - Type4 - AP 1800 engine |
It looks like the flywheel O-ring is teflon.(white)
Nothing else in the gasket bag comes close.
Usually it's graphite colored.
Time marches on. |
SGKent Samba Member
Posted: Sun Dec 21, 2014 1:44 am Post subject: |
Thanks guys,
My engine was partly disassembled before I've gotten it. Normally I'll take pics before tore down..
There should be an O-ring around/near the flywheel seal. This was removed on my engine. Where should it go precisely?
I have Haynes - but can't find anypics of this.
My engine is a Type4 - AP 1800
Thanks... |
Posted: Sun Dec 21, 2014 2:33 am Post subject: Help ld O-rings in gasketset - Type4 - AP 1800 engine |
The O-ring fits into a recess of the flywheel itself, the working surface is
the inner diameter of the O-ring, yours may be smashed so flat you
can't make it out, but it's there, near the crankshaft bolt holes.
Use a pick to start it. |
Tcash Samba Member
Posted: Sun Dec 21, 2014 8:04 am Post subject: |
Number 19.
Posted: Sun Dec 21, 2014 10:26 am Post subject: |
Thanks,
Excellent pic.
I can see that #4 and #23 - were not present when I took it a part. Should both be present in a std. gasket kit?
Thanks again,
appreciate.... |
Tcash Samba Member
Posted: Sun Dec 21, 2014 1:26 pm Post subject: |
Henrik_K wrote: |
Thanks,
Excellent pic.
Thanks again,
appreciate.... |
Mayor Ratwell list what gaskets are.
(Not Included)
http://www.ratwell.com/technical/GasketSet.html |
MacLeod Willy Samba Member
Joined: February 18, 2014 Posts: 933 Location: Ontario Canada
Posted: Sun Dec 21, 2014 2:24 pm Post subject: oring |
The flywheel oring is 19, 23 is pilot brg seal |
