GB2S Samba Member
Posted: Sat Dec 20, 2014 1:51 pm Post subject: If you installed your own headliner please read. |
So I've read all I can find on installing your headliner yourself, and I have a question please.
What is the best adhesive out there. I've watched the video on this site where they use a spray gun and an adhesive. So, are their spray can adhesives that have the same results.
I just do not want to do it twice are be dissatisfied with it over time
I have a 63 ragtop should Ii have somebody else do it?
Thanks Geoff _________________ 1963 Ragtop |
usmc1345 Samba Member
Joined: April 24, 2005 Posts: 307 Location: Belgrade Mt
Posted: Sat Dec 20, 2014 2:15 pm Post subject: |
I did mine on my 63 ragtop came out ok,for awhile. Lol. I used some 3m spray glue in a can then some other can spray glue I found at the local auto parts store. The hardest part of the job for me was tucking in the front ( the area above the front windshield ) I didn't have the proper tools for the job. It held up for 3 years or so, then started to sag in places. I don't know if not using enough glue was the issue. But when I re do it I'm going to use a different glue. _________________ Semper Fidelis |
panicman Samba Member
Joined: December 18, 2011 Posts: 2290 Location: Canby, OR
jpjohns Samba Member
Joined: May 03, 2014 Posts: 882 Location: Harrisonburg, VA
Posted: Mon Dec 22, 2014 10:43 am Post subject: |
Make sure you use enough clips?
[/img] _________________ -Jared
"Scrapyards are for quitters" - Beetlenut (a Samba member) |
fizzbang Samba Member
Joined: September 07, 2003 Posts: 196 Location: Oregon
Posted: Tue Dec 30, 2014 1:27 am Post subject: |
I used the 3M Super 90 on my first bug and it seemed fine at first, but heat/cold and a few months and it will separate in areas.
If you really want it to last forever you need to get the Weld wood Adhesive and a adhesive spray gun for it to last (quick links below, need to look up where I bought mine)
Adhesive:
http://www.yourautotrim.com/noname37.html
Gun:
http://www.yourautotrim.com/aespradspgun.html
There is a difference between the 3M stuff and the Weldwood. Weld wood is forever and will rip the paint off of your car/ destroy your headliner of you try to reposition it after correctly following the instructions and cure times. It's really great stuff, but your prep needs to be good and you need to really have a plan and pre-layout for installing your headliner or whatever your going to glue.
If you go through this gallery, the headliner photos, back/middle kick panels, front wheel well covers and rear luggage area panels are where I used the Weldwood adhesive:
https://www.flickr.com/photos/100427926@N02/sets/72157635119659024/
It's worth it if you are wanting it to last for years in hot and cold weather. After driving the bus a while, there were NO issues with any of the areas where I glued with Weldwood. Stuff is Marine/pro waterproof, illegal in some states good. |
Joined: June 02, 2011 Posts: 1593 Location: Louisville, ky
Posted: Tue Dec 30, 2014 1:37 am Post subject: |
fizzbang wrote: |
If you really want it to last forever you need to get the Weld wood Adhesive and a adhesive spray gun for it to last |
How many years ago did you do this? |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4921 Location: Southern AB
Posted: Tue Dec 30, 2014 10:52 am Post subject: |
solvent based contact cement (lepages, weldwood, etc) is the way I do it. I've done 5 in the last several years and they have all held up well.
pull it tight, keep it warm with a space heater so it's soft for the entire install and use a lot of clamps
the wifes super back in 04
my square 5 years ago
pull it tight front to back, and side to side, then work evenly to the corners
relief cuts
I have a couple hundred clamps around here now, cheap from the dollar store.
work towards each corner
radiant heater
take your time, wait for the glue to set up, and another pair of hands on the opposite side of the roof to pull it snug is real handyto keep it straight and wrinkle free. _________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
Posted: Tue Dec 30, 2014 4:54 pm Post subject: |
Awesome job! _________________ -Jared
