kielbasa Samba Member
Joined: November 28, 2007 Posts: 1443 Location: Garbage Grove, CA
Posted: Sat Dec 20, 2014 4:04 pm Post subject: pitman arm issue |
When the steering box is bolted up and tie rods aren't hooked up. Would the pitman arm hit the frame head? Because that's what's happening to me. Trying to figure out how much to cut tie rods for the narrowed.
Also the pitman arm is funky. Me nor some of my friends have seen one with ears like mine. Which the ear is the first place that hits. If the ear wasn't there it looks like the arm is real close to the edge of the frame head.
_________________ Gotta give my props to:
Wolfsburg Motorsports
Dubbers Toy Box
Jeff's VW Speed and Fab
4inbore.com
Kielbasa Industries |
Posted: Sun Dec 21, 2014 12:03 pm Post subject: |
Nobody knows what this funny looking pitman arm is from? _________________ Gotta give my props to:
Dubbers Toy Box
4inbore.com
Abscate Samba Member
Posted: Sun Dec 21, 2014 3:06 pm Post subject: |
I'm not sure the Pitman arm limits the steering on any Beetle....it might be the stop on the front wheels that determines the steering lock. _________________ .ssS! |
Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Sun Dec 21, 2014 3:22 pm Post subject: |
Yes, it will hit the frame head with no tie rods. The steering stop is built into the link/king pin carrier (knuckle). There's a spot on the carrier that hits a spindle bolt. _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
TheLadyBug Samba Member
Joined: August 17, 2014 Posts: 639 Location: Saskatoon, Saskatchewan, Canada
Posted: Fri Dec 26, 2014 7:10 pm Post subject: |
My pitman arm is the same with the knobs.
_________________ Charmaine
1954 Beetle - because I can
2016 Golf highline - hubby’s daily
2016 Golf R - my daily |
slalombuggy Samba Member
Posted: Sat Dec 27, 2014 6:06 pm Post subject: |
The steering box is also limited by the worm and roller in the box. I have never had one hit the tunnel though, but your travel is limited by the spindles. Did you have to move the box over when you narrowed the beam 8 inches?
brad |
Bobmagneto Samba Member
Joined: January 04, 2009 Posts: 54 Location: Bloomingburg, Ny
Posted: Tue Jun 06, 2017 3:39 pm Post subject: Re: pitman arm issue |
I'd be more concerned with the crack running through your frame head. Do that first then worry about bolt on parts. |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Tue Jun 06, 2017 5:52 pm Post subject: Re: pitman arm issue |
As said above, the pitman arm WILL hit the frame head without the tie-rods installed on early king/link pin front ends. Later model (68-77?) ball joint front ends have a stop built into the pitman arm |
maskinmester Samba Member
Posted: Sat Jun 10, 2017 1:49 pm Post subject: Re: pitman arm issue |
My pitman arm is the same (july 1954) with "ears" and as wrote before - the limitation are at the wheels. _________________ 1954 Beetle - running - Went to HO 17
1961 Beetle in the workshop
1960 Beetle waiting for repair
1956 Unimog 411
30 old farm tractors and stationary engines
1999 Golf - daily driver |
Zwitterkafer Samba Member
Joined: November 17, 2007 Posts: 879 Location: Lanark County, Ontario, Canada
Posted: Sun Jun 11, 2017 12:49 pm Post subject: Re: pitman arm issue |
Those "lugs" on the Pitman arm were dropped on 8 Feb 1955. In Progressive Refinements, they are called "lifting cams". Their function was to provide a point of leverage for a tie rod end removal tool. _________________ "Criticism comes easier than Craftsmanship"
- Zeuxius, 400 BC |
