JeffRobenolt Samba Member
Joined: February 25, 2007 Posts: 1513 Location: Wisconsin
Posted: Sat Dec 20, 2014 4:40 pm Post subject: Waxoyl, waxoil, wax oil 25% DISCOUNT CODE |
I'll start by saying I don't work for Roversnorth or have any affiliation with them.
Mods if this post is against forum rules, sorry and please remove.
Most of use by now have heard of waxoyl and its uses for rust prevention.
The problem I had was finding it in the US. I found a Land Rover place that is the dealer in the US. I ordered a kit and spent some time talking 4x4's (Syncros) with him.
http://www.roversnorth.com/Manufacturers/19
I told him the VW crowd would be pretty excited about the products.
So he said he would give us guys a discount, 25%!!!
The code is SAMBA.
*****he said they couldn't get it to work with the already discounted kit so the pieces need to be put in the shopping cart separate*******
So its more like 20% of the kit price.
I am impressed with the quality of the guns and wands. The guns are made in Germany.
I also bought the wand for the hard wax not included in the kit.
Here are some pics
Here is a video
_________________ --------------------------------------------------------
jfats808 wrote: |
Most, some, few is not all. You can always learn something from everyone , even the fool. |
Last edited by JeffRobenolt on Sat Dec 20, 2014 6:35 pm; edited 2 times in total |
Posted: Sat Dec 20, 2014 4:42 pm Post subject: |
Here is another video of the hard wax.
jfats808 wrote: |
Posted: Sat Dec 20, 2014 4:43 pm Post subject: |
This is the post that made me start looking for the waxoyl
http://www.thesamba.com/vw/forum/viewtopic.php?t=479448&highlight=rust _________________ --------------------------------------------------------
jfats808 wrote: |
Posted: Sat Dec 20, 2014 4:45 pm Post subject: |
I'm not sure how long h will let us use the code. I don't think it will be forever.
Jeff _________________ --------------------------------------------------------
jfats808 wrote: |
adv rider Samba Member
Joined: September 09, 2012 Posts: 288 Location: Everett,wa
Posted: Sun Dec 21, 2014 12:26 am Post subject: Re: Waxoyl, waxoil, wax oil 25% DISCOUNT CODE |
The code is SAMBA.
Here are some pics
Here is a video
[/quote]
What is the minimum air pressure needed? to use the air gun, and be able to coat my van? _________________ 86' Wolfsburg weekender 2.1, 4spd, , merian brown
insyncro Banned
Posted: Sun Dec 21, 2014 1:59 am Post subject: |
The PRO gun with wands is $300.
I bought it years ago...very good quality. |
westylife Samba Member
Joined: October 28, 2007 Posts: 409 Location: Anchorage, Alaska
Posted: Sun Dec 21, 2014 8:12 am Post subject: Re: Waxoyl, waxoil, wax oil 25% DISCOUNT CODE |
jrobewesty wrote: |
The code is SAMBA. |
Awesome! now, can somebody make a video of them treating a Vanagon?
Westylife _________________ 1983.5 Westfalia Bostig RG1 |
Posted: Sun Dec 21, 2014 8:15 am Post subject: Re: Waxoyl, waxoil, wax oil 25% DISCOUNT CODE |
adv rider wrote: |
What is the minimum I need to have a gun, and be able to coat my van? what it going to cost? |
When I look at the videos I see that each gun and wand has its own purpose.
It all would depends on how good of a job you want to do.
I am hoping 1 gallon of the hard wax will be enough to cover the floor, frame rails and suspension pieces but not sure till I do my van. If the interior is out I would think definitely another gallon would be needed.
For the fogging, I would think the gallon is more than enough. _________________ --------------------------------------------------------
jfats808 wrote: |
insyncro Banned
Posted: Sun Dec 21, 2014 9:33 am Post subject: |
Waxing works best as a yearly application, my opinion, so buying more than you initially need is a none issue as it will be used the following year.
The products do not go bad and store well.
Just warm them to apply and watch them wick. |
Posted: Sun Dec 21, 2014 9:57 am Post subject: |
insyncro wrote: |
That's for the underbody, right? I would assume interior and cavity applications would be permanent?? _________________ --------------------------------------------------------
jfats808 wrote: |
insyncro Banned
Posted: Sun Dec 21, 2014 10:08 am Post subject: |
Depending upon what else is has been sprayed on interior panels.
I opt for sprayable barriers on the inside now instead of wax...sound, thermal and moisture barriers.
I coat the exterior/under yearly and spray Fluid Film over the entire undercarriage and suspension just before big storms when I will be driving in the worst of it.
The FF will protect the waxes and any dings or abrasions from use.
FF will wash off over time or with Simple Green and hot water.
Just make sure ALL rust has been dealt with first.
Spraying anything over untreated rust will be a HUGE disappointment in very short amounts of time....even with the vehicle stored during the winter months.
I changed the wording thanks to a pmail.
Hope it helps
ultra_rnr Samba Member
Joined: September 19, 2014 Posts: 32 Location: Sacramento, CA
Posted: Sun Dec 21, 2014 10:49 am Post subject: |
The little video says light surface rust is ok, to just brush it all off and then do a thorough clean. InSyncro do you mean that it needs to be truly rust free, i.e. like new, or are you referring more to deeper rust? And how about over old undercoating that has started to flake, take it all down and paint then waxoyl?
Any thoughts on what it is like to work on parts that have been coated before? Is it messy the next year? Do you end up with a bunch of built up wax after a few years of application? |
insyncro Banned
Posted: Sun Dec 21, 2014 11:15 am Post subject: |
I do not recommend spraying anything over rust.
It must be dealt with properly and throughly, or it will return, with a vengeance, my opinion, backed up by 20 years of experimenting with most available products and tools to apply them.
Sure, I just spray away on my winter vans, but they are decreasing in value with every mile.
The complete restorations I have done and continue to do have a focus on dealing with any rust.
Waxes work amazingly well to preserve unrusted and properly treated rusted areas.
This is a great thread and a chance for many to save some money.
What I am not saying is just coat every inch of your van and forget about it, the rust is still alive and now driven deeper into the chassis to destroy structural members that you can't see from the outside or underside.
Most waxes can be removed with solvents...I use kerosene after manually scraping the wax with a plastic scraper.
At my shop I submerge suspension parts that have been waxed in a solvent tank and than use a Hotsy power washer with detergent to clean the metal completely.
After that wet sandblasting will prep the metal for powder or coating.
After that I wax the entire part, let it dry and cure, than install.
I use a brush with the hard wax to touch up any spots I rubbed during the install.
Many Left coasters have found out how messy waxes and undercoatings can be.
Long sleeves, nitrile gloves and a respirator should be used when (spray) waxing. |
Microbusdeluxe Samba Member
Joined: July 26, 2003 Posts: 977 Location: Bellingham, WA
Posted: Sun Dec 21, 2014 1:05 pm Post subject: |
insyncro wrote: "Depending upon what else is has been sprayed on interior panels. I opt for sprayable barriers on the inside now over wax...sound, thermal and moisture barriers."
I'm going to soundproof/rustproof my syncro this spring. My plan is to use a sprayable sound barrier like Lizard skin for a seamless sound barrier & corrosion protection with closed cell mats over it for the thermal insulation topped by soft Waxol to weep in any cracks.
Are you saying that I should do the Waxoyl soft wax BEFORE the Lizard skin? I was assuming the Lizard skin might not adhere to wax.
Thanks _________________ '69 Squareback RIP
'65 21 window deluxe sold before the price spike, damn it.
'70 rhd bay now a taxi in South Sudan
'81 Westy sold
'89 hightop Westy Joker syncro 16" now with Bostig! |
insyncro Banned
Posted: Sun Dec 21, 2014 1:21 pm Post subject: |
I do not recommend spraying/applying any "wax" product below or over top of barriers as I describe them.
The solvents used to help the waxes flow will hinder adhesion of these barriers.
I do wax inside pillars with barriers in place.
My experience has me and my restorations moving away from waxes inside the vehicle and using much more specific types of sprayable barriers.
Waxing of the undercarriage, all suspension parts and engine compartment parts really helps keep oxidation and rust at bay.
Using more modern materials inside the vehicle makes way more sense for what I am trying to achieve.
Not everyone needs barriers, but they work very well.
If you are planning to use them and underbody products...test to see how the react to eachother first.
AND if ANY bodywork or paint is in your vans future...wait for that work to be completed before applying waxes.
Hope this helps. |
insyncro Banned
Posted: Sun Dec 21, 2014 2:38 pm Post subject: |
jrobewesty wrote: |
insyncro wrote: |
That's for the underbody, right? I would assume interior and cavity applications would be permanent?? |
No wax is permanent in my experience.
It is in constant motion, moving further inward into any area it can creep into.
This is why I continuously reapply the same product.
Temperature changes are what have the largest impact upon movement of these products...so heating them and applying them in the summer heat is best.
Or heat the vehicle and work area to around 75 degrees for better results. |
squeegee_boy Samba Member
Joined: April 27, 2008 Posts: 758 Location: Langley, BC, Canada
Posted: Sun Dec 21, 2014 3:21 pm Post subject: |
Thanks, I've been meaning to order some more.
Robyn _________________ 1984 FrankenSyncro Westy. EJ25 RMW kit
1971 Super Beetle with an EJ22. Oh yes. Daily driver |
Posted: Sun Dec 21, 2014 6:27 pm Post subject: |
Ok insyncro, that sounds good. Another question. On the underside there are a lot of rubber plugs. Which of these scenarios is the best.
1. Remove plugs, spray soft waxoyl, reinsert plugs.
2. Remove plugs, clean out hollows with a jet of h2o, wax, replug.
3. Remove plugs, clean out hollows, allow to dry and/or speed up drying with hot air, wax, replug.
4. Keep your mitts off the plugs!
All of these would then be followed with a hard wax undercoating on the outside of the suspension parts & floor panels.
And yes, I echo Westylife that it would be cool to see a video of someone undercoating/panel waxing a vanagon. _________________ '69 Squareback RIP
'81 Westy sold
insyncro Banned
Posted: Sun Dec 21, 2014 6:34 pm Post subject: |
1,2 or 3.
Any area where I see rust or oxidation gets rust encapsulating paint products.
Inner areas of a van that will see winter use...I than spray a zinc fortified product, than after dried and cured...wax of choice.
No need for the zinc if you store your van and only drive on sunny days. |
Posted: Mon Dec 22, 2014 4:26 pm Post subject: |
I was asked if the discount code was only good if all items of the kit were purchased.
I put 1 gallon of hard wax in the shopping cart and applied the discount and it worked.
So I will assume it will work on anything purchased.
jfats808 wrote: |
