ronbug73 Samba Member
Posted: Mon Dec 22, 2014 6:16 am Post subject: Body vibration - fasty 71 help |
i have a body vibration when driving end when idle its like a beez
we think its from the main fan.
can a fan gat out of alighn?
1. does a fan of a 1500 is the same as a 1600?
2. does a fan of a 6 v is the same as a 12v [i know that fan hose is differnt]
3. mybe you can help with another idea what can it be?
thank you
Ron |
grandpa pete Samba Member
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34018 Location: Conejo Valley, CA
Posted: Mon Dec 22, 2014 9:47 am Post subject: |
I've never had a fan fail, though it's possible. I'd check everything else first... valve gap, compression, timing, plugs and plug wires... a tune-up often shows faults that cure poor-running ills.
chink13 Samba Member
Joined: May 07, 2009 Posts: 143 Location: Ocean Springs, MS
Posted: Mon Dec 22, 2014 10:07 am Post subject: |
I have a vibration at idle too but mines when its in drive I think mine is the fact my idle is a hair too low!! but I had a vibration before when it was in neutral turns out it was one of the carbs held open slightly!! but I would check plugs wires compression and all the tune up things 1st!!
come to think about it I have a buzzing coming from my fan too it didn't do it on my old engine but does on this loaner I have hmmm if I figure it out ill post back!! |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22425 Location: Kimball, Mi
Posted: Mon Dec 22, 2014 10:43 am Post subject: Re: body vibration- fasty 71 help |
ronbug73 wrote: |
thank you
Ron |
Fans are the same from 64 on.
Remove the fan belt, and see IF you still have the vibration. If that eliminated the vibration, then it's generator bearings going bad.
If it didn't, then I'd double check the torque on the fan bolt, before going any further. It should be torqued to 95 to 103 ftlbs. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
JeeJeeJason Samba Member
Joined: May 23, 2014 Posts: 234 Location: Bay area, CA
Posted: Mon Dec 22, 2014 11:31 am Post subject: |
KTPhil wrote: |
I've never had a fan fail, though it's possible. I'd check everything else first... valve gap, compression, timing, plugs and plug wires... a tune-up often shows faults that cure poor-running ills. |
For what it's worth, I had a similar issue with my last squareback and after doing a complete tune up it ran fine with the vibration gone. |
Posted: Sat Jan 03, 2015 1:18 pm Post subject: my be its the fan |
we inspected the fan end the holes for taking it out where not elighn
so there is freedom
so this week we will replaice the fan/ end i will update
ron |
Posted: Sun Jan 11, 2015 1:40 pm Post subject: update |
hi
today we change the main fan.
but my fasty still have vibration
game on. |
Posted: Sat Feb 07, 2015 9:57 pm Post subject: vibration |
we cahnge the fan end we check the flywheel end clutch still vibration!
if a muffler is broken from inside it can vibraite?
thank you
Ron |
Brent Samba Member
Joined: April 28, 2010 Posts: 1614 Location: San Tan Valley, AZ
Posted: Sun Feb 08, 2015 11:36 am Post subject: brent |
hi brent
yes we pull the belt
we even start the engine withaout the fan |
Brent Samba Member
Posted: Mon Feb 09, 2015 2:44 am Post subject: Re: brent |
ronbug73 wrote: |
hi brent
There is a picture somewhere here of a stock muffler cut open. There are equal lengths of exhaust pipes on the inside.
A long screwdriver held to your ear can really help find that kind of stuff while the motor is running. _________________ 69 Fastback Build
Berg5 Build |
KTPhil Samba Member
Posted: Mon Feb 09, 2015 10:30 am Post subject: |
Posted: Tue Feb 10, 2015 11:51 am Post subject: thank you |
its not the mufler
today my machanic drop the engine again he thinks its the flaywhell
im waiting
thank you |
Posted: Tue Feb 10, 2015 11:55 am Post subject: Re: brent |
ronbug73 wrote: |
hi brent
If you still had the vibration with the belt off, and then with the fan off, the problem lies elsewhere.
This could be as simple as a clutch/pressure plate, or even the flywheel. You're going to have to do some digging to find it. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Tue Feb 10, 2015 12:35 pm Post subject: bob |
we will do it end i will update
thank you
Ron |
Posted: Thu Feb 12, 2015 12:17 pm Post subject: clutch |
update
today we fix new flywhell new clutch new pressuer plate
but nothing change. a big noise end vibration
we even tighten the coling tin around the engine |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22728 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Thu Feb 12, 2015 12:23 pm Post subject: Re: clutch |
ronbug73 wrote: |
update
but nothing change. a big noise end vibration |
How are the rubber engine mounts?
Is anything metal from the engine, transmission, or shift linkage contacting the body? _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
