gatorwyatt Samba Member
Joined: April 24, 2002 Posts: 1867 Location: Clearwater Fl.
Posted: Tue Dec 30, 2014 3:13 pm Post subject: Barndoor beam torsion slats |
So like most, upon disassembly of my front beam four of the eight slats are cracked. I really prefer not to modify to a later arm and slat if I can help it. Does any one have any info on someone that has successfully sourced the proper material to remake these? Not trying to turn it to a WTB ad either so if someone has some please just PM me the info.
_________________ www.blastserv.com
wanted:
RHD Barndoor floor mat..reproduction is fine |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Tue Dec 30, 2014 8:36 pm Post subject: |
is this a difficult material to get? seems like it is used so much that you should be able to find it anywhere? _________________ regards
Uli
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
Merlin Samba Member
Joined: August 19, 2004 Posts: 2103 Location: South Africa
Posted: Tue Dec 30, 2014 11:39 pm Post subject: |
I have one broken blade in my stacks.
I've contacted every major spring place in my country and none of them have any clue as to where else I may look nor how to help me.
According to, well, all of them, this thickness of spring steel hasn't been used in a very long time. The new standard is double. As it is spring steel, they can't guillotine it or mess with the temper of the metal.
I've been told of a place in Germany that can supply new stacks, but I cannot find the infernal email with the name in it...
I too, would be interested in a source. _________________ the3rdrock.com - …musings, discoveries and postulating, by a restless itinerant in search of enlightenment.
iowegian wrote: |
People who are allowed to have signature lines annoy me. |
Rusting Hulk Samba Member
Joined: August 20, 2002 Posts: 646 Location: Malvern UK
Posted: Thu Jan 01, 2015 4:03 am Post subject: |
One thing I found when i changed mine is that type 22,24 and 27 have 5 blades top and bottom and all the others have a mixture 5 blades in the bottom and 4 in the top. _________________ 64 356 C Coupe |
Posted: Fri Jan 02, 2015 6:57 am Post subject: |
Yes... I stand corrected after I recounted.
5 blades in bottom and 4 in top... I have broken slats in both. _________________ www.blastserv.com
wanted:
BulletBus Samba Member
Joined: August 17, 2005 Posts: 1276 Location: Panama City Beach
Posted: Fri Jan 02, 2015 7:42 am Post subject: |
I would try maybe Gerson. It's not something he reproduces, but may have some on the self from the buses he's parted. _________________ 53 Hatch Barndoor
If it's not a bus, it's bus money waiting to happen. |
Tistlo Samba Member
Joined: July 14, 2008 Posts: 80 Location: Voss, Norway
Posted: Fri Jan 09, 2015 12:21 pm Post subject: |
i have never measured the dimensions for bd beams, but in the catalog of one of the steel-distributors here in norway i see the smallest flat springsteel is 5x25mm next is 5x50. any of you have the measurements?
it is pretty easy to cut it ("guillotine") it with using a BIG sheet cutter and set the values for a heavier plate. we have used some springsteel in different projects at work. welding it is a whole 'notter story. would not recomand welding it for the beam unless you know exatly what your doing. |
Posted: Sat Jan 17, 2015 2:21 pm Post subject: |
So after reviewing the parts list all panel, kombi and truck models used a combo of 4 slats in top and 5 in bottom. All others used 5 and 5.
The slate measurements are
Stacks of 4 5.625mm x 22.50
Stacks of 5 4.50mm x 22.50 _________________ www.blastserv.com
wanted:
Clara Samba Member
Posted: Thu Jan 22, 2015 10:01 am Post subject: |
Can you use some of the middle width slats from a later bus? _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Posted: Thu Jan 22, 2015 1:21 pm Post subject: |
I suppose it is possible...the difference will be wether you have enough thickness to build to the needed dimension of the originals. Maybe between a combination of old and new it is possible.
Anyone have a upper Barndoor torsion arm? I could use one. _________________ www.blastserv.com
wanted:
