LoveMyThing Samba Member
Joined: October 05, 2008 Posts: 89 Location: Los Angeles
Posted: Sat Jan 03, 2015 3:48 pm Post subject: |
Thank you for your respnses. Makes perfect sense. |
videoguy009 Samba Member
Joined: March 31, 2008 Posts: 711 Location: Saint John N.B. Canada
Posted: Tue Jan 06, 2015 10:13 am Post subject: |
How much did the exhaust cost?Can you get it without the heat risers.What diameter is the piping.Could you give me a contact info? _________________ 1971 Super Beetle |
Jzsquared Samba Member
Joined: August 16, 2014 Posts: 218 Location: West of Chicago, IL
mikeyj007 Samba Member
Posted: Fri Jan 09, 2015 4:45 am Post subject: |
Thanks Mickey for looking into this for me.Is this exhaust fairly quiet?It looks awesome! _________________ 1971 Super Beetle |
Posted: Fri Jan 09, 2015 4:59 am Post subject: |
I had a ceramic coated tri mil that looked similar to
this and it was garbage.Loud and the coating did not hold up. _________________ 1971 Super Beetle |
Posted: Fri Jan 09, 2015 6:22 am Post subject: |
videoguy009 wrote: |
Thanks Mickey for looking into this for me.Is this exhaust fairly quiet?It looks awesome! |
I have not had a chance to run it yet so not sure how loud it is. I'm still waiting on a few misc parts before I fire my rebuild up for the first time, so it will be awhile sorry. Temps dropped here this week and we are in single digit temps so I'm going to wait a bit as well, don't want to do my first startup in 0 degrees |
Posted: Sat Jan 17, 2015 2:23 pm Post subject: |
All right I finally finished putting my little 1835 together and started it up for the first time. The exhaust is nice and quiet just how I like it.
I'm breaking in the cam so it's running at 2k rpm in them video and I do rev it up once or twice. For those of you that look close yes the final pipes that normally go through the bumper are on backwards so the exhaust goes out the garage door. I have my heater running in the garage so it helps push out the exhaust.
This will be the only video for a bit because I have 2 oil leaks that need fixing before I run it again, one leaky Jaycee pushrod tube & all the full flow connections leak. It's my first build so I guess hoping for no leaks was silly but I'll fix it. Still cold in Chicago so I have plenty of time. All in all I'm very happy with the exhaust
GI Joe Samba Member
Joined: April 28, 2005 Posts: 2012 Location: Athens, TN
Posted: Mon Jan 19, 2015 12:52 pm Post subject: |
Looks and sounds good.You get what you pay for I guess.Must put one on my shopping list!Good luck fixing your oil leaks. _________________ 1971 Super Beetle |
oasis Samba Member
Posted: Wed Jan 21, 2015 6:58 am Post subject: |
I'm reading this thread with a lot of interest. The exhaust I currently have is very nice but I am told not too suitable if I plan on enlarging the displacement.
Since this is suitable for an 1835cc, I assume this would be suitable for a 1776cc. Would it be suitable for a 2110cc?
Secondly, since I have a '74, I don't have the gas heater. I would like to have heat, however. Is there a non-J-tube option? _________________ Now: 2003 New Beetle Turbo S / 1990 Single Cab Transporter / 2014 Tiguan R-Line 4motion / 2013 Tiguan S / 2002 Golf GLS TDI
Past: 1974 Thing Acapulco / 2009 Eos Komfort / 1997 Jetta GT / 2002 Cabrio GLX / 2002 Passat GLS / 1971 Super Beetle / 1993 EuroVan MV Westfalia / 1981 Pickup LX / 1985 Vanagon / 1986 Jetta GLI |
Posted: Wed Jan 21, 2015 7:06 am Post subject: |
Email Kevin at Vintage Speed and he will give you all of the info. _________________ 1971 Super Beetle |
oasis Samba Member
Posted: Wed Jan 21, 2015 7:10 am Post subject: |
Email Kevin at Vintage Speed and he will give you all of the info. |
Obviously, you think highly of Kevin (and Vintage Speed) to be mentioning him by first name. I take that as a positive. I'm usually reluctant to contact a seller with a question if I don't know them as I have to evaluate them as a straight shooter or a bull shooter. Thanks. _________________ Now: 2003 New Beetle Turbo S / 1990 Single Cab Transporter / 2014 Tiguan R-Line 4motion / 2013 Tiguan S / 2002 Golf GLS TDI
Posted: Wed Jan 21, 2015 7:15 am Post subject: |
Straight shooter.Answered all of my questions. _________________ 1971 Super Beetle |
Posted: Wed Jan 21, 2015 7:20 am Post subject: |
They do sell j-tubes in stainless if you don't want the heater boxes. I believe my set up is good up to 125 HP but vintage speed can verify.
I delt with MT at vintage speed and he was very helpful |
oasis Samba Member
Posted: Thu Jan 22, 2015 10:13 am Post subject: |
Jzsquared wrote: |
That should be more than plenty if true (although my mind started wandering into the realm of Type IV engines again).
Although I am still scouting for my January top down day, I needz me warmth most of the time as a life long warm weather person. _________________ Now: 2003 New Beetle Turbo S / 1990 Single Cab Transporter / 2014 Tiguan R-Line 4motion / 2013 Tiguan S / 2002 Golf GLS TDI
Posted: Sat Jan 24, 2015 9:17 am Post subject: |
Not to self Jaycee pushrods leak, I have tried 3 times to get these things to seal and no luck. I replaced the seals twice with the ones Jaycees sells then tried the empi silicon ones people seam to like. I will keep one or two for an in case of emergency situation and pitch the rest. I have the heads back off now and am going to the windage style.
I did run the engine again and am very pleased with how quiet the engine runs. The loudest part is the air being drawn in when I rev it up. When I have it in the car with the oil bath back on I assume it will be even quieter. Not what the hotrodders wanna hear but I like it |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4856 Location: sanger ca
Posted: Sat Jan 24, 2015 10:51 am Post subject: |
That is a very quality part, however a true 4 into 1 collector will pick up about 10 horses on that engine. Kinda the price you pay for a stock style exhaust. Like the fiberglass buggy guys that run a split "duel cannon" exhaust, they are loosing 7-10 horses over a stock exhaust. But they look cool _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
jmf337 Samba Member
Joined: August 27, 2009 Posts: 44 Location: Orlando, FL.
Posted: Tue Mar 24, 2015 4:09 pm Post subject: |
You will be happy with the quality
It's in but I have more FI work to do before I put the bumper and the top tubes back on |
