NWGhiaGuy Samba Member
Joined: March 16, 2005 Posts: 700 Location: Bellingham, WA
Posted: Mon Mar 02, 2015 9:56 am Post subject: |
semipixel wrote: |
Been a while since the last update...
Been a while?!? You've done more in the last 60 days than a lot of us get done in a year or more!
Nice job. Certainly an inspiration |
semipixel Samba Member
Joined: July 22, 2014 Posts: 56 Location: Nova Scotia
Posted: Sun May 17, 2015 2:55 pm Post subject: |
Getting the torsion plates at the correct angle. I was going for a 2 inch drop (~1 spline), and for some reason decided the add 8 degrees to the stock angle rather than subtracting it, not sure what I was thinking. Realized it after I had it all back together:
Switching from the wrap around signals to bullet style ones to go with the earlier style bumpers:
Seeing what the nose looks like under the paint... a lot of bondo. Once I got through it I wasn't really sure why they had used so much, didn't take a lot work to get the metal to where it should have been:
Cutting the rest out of the bottom of the nose. Not much left. Old bumper mounts roughly cut out at this point as well:
Test fitting the new bumpers before I start patching it back up since it's easier to access where the new mounts will go:
Patches tacked in:
and after a little grinding this is where I'm at. Bearings went in it so I called it a day:
Posted: Sun Dec 13, 2015 6:47 am Post subject: Re: '74 Ghia Project |
Long time since an update. I ran short on time and neglected posting, I'll see if I can get back on track. I'll fast forward through the last few months to get up to date:
bobnorman Samba Newfoundlander
Joined: August 09, 2010 Posts: 1389 Location: Newfoundland
BadStorms Samba Member
Joined: August 12, 2013 Posts: 22 Location: Bay Area, CA
Posted: Wed Feb 10, 2016 3:42 pm Post subject: Re: '74 Ghia Project |
Amazing progress- you do great work! _________________ https://www.youtube.com/user/stigstorms/videos
1974 Karmann Ghia
2005 Mercedes C55 AMG
2001 Suzuki SV650
1973 Honda CB350 Four |
Posted: Wed Dec 21, 2016 3:43 pm Post subject: Re: '74 Ghia Project |
Fell off the update wagon... Car's on the road, just in time to be put away for winter. Have a few cosmetic things to work on until spring, but it's nice to know it's ready to go.
Here's a few photos since last time:
Wet sanding in progress
After 2000 a bit of shine is coming back.
First stage of compound, nice to see it coming back to life.
New SS bumpers on, not such a fat chick anymore.
Painted dash and new wheel. The wheel didn't end up clearing the signal and washer stocks, but I managed to heat them up and bend them out of the way.
Headliner, used the old one as a template. Not a bad project with a bit of heat.
First sample of the new seat covers, again using the old as template, but putting my own twist on it.
Getting ready to put the engine in.
New door panels
Back window in, used the soap and string method. Front actually went in easier than the back.
Seats in. Front carpet isn't in yet, waiting till I'm 100% done in an attempt to keep it clean.
As is sits now
motorhead364 Samba Member
Joined: November 04, 2008 Posts: 715 Location: Amarillo Texas
Posted: Wed Dec 21, 2016 7:38 pm Post subject: Re: '74 Ghia Project |
_________________ 63 ghia coupe |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3916 Location: In Molinya Orbit
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13958 Location: Southampton U.K.
Posted: Thu Dec 22, 2016 6:27 am Post subject: Re: '74 Ghia Project |
Thanks guys!
I have a EMPI Trigger Shifter and wanted to find a shift knob to match the wheel. Because the trigger slides up into the knob there's not many options, so I started putting one together.
I turned this on the lathe out of birch, and made a recess to fit a 1974 German coin in the top:
Next step is to find a stain to match, and then I plan on covering it with epoxy resin and buffing it out. |
myghiarocks Samba Member
Joined: June 02, 2009 Posts: 143 Location: DFW area Texas
Posted: Thu Dec 22, 2016 8:05 am Post subject: Re: '74 Ghia Project |
car looks fantastic. Nice job. |
kgj Samba Member
Joined: February 25, 2013 Posts: 418 Location: Uk, Cornwall
Posted: Thu Dec 22, 2016 3:52 pm Post subject: Re: '74 Ghia Project |
Nice.
I really like the colour, and the red calipers, and the brake fluid reservoir......
And to quote 63vwnotch, " looks like another one ready for the scrap heap" 👍 _________________ 1958 coupe |
SwappedGhia Samba Member
Joined: December 29, 2016 Posts: 6 Location: Greenville, SC
Posted: Mon Jan 02, 2017 12:42 pm Post subject: Re: '74 Ghia Project |
Beautiful. Great job! |
74GhiaConvertible Samba Member
Posted: Mon Jan 02, 2017 5:29 pm Post subject: Re: '74 Ghia Project |
That's a lot of work! You did great. |
