Seanlithman Samba Member
Posted: Sun Jan 04, 2015 3:23 pm Post subject: Rusted and rotten vintage speed exhaust gaskets poor fit |
Noticed my vintage speed exhaust was blowing only been in 18 months and the gaskets are compleatly rotten the flanges don't mate together very well but I've seen that you have to use sealent. Anyone else had similar experience? |
MacLeod Willy Samba Member
Joined: February 18, 2014 Posts: 933 Location: Ontario Canada
Posted: Sun Jan 04, 2015 3:30 pm Post subject: |
Can you file the flanges flat and try not to over torque the nuts |
vwjim Samba Member
Joined: November 14, 2003 Posts: 135 Location: Hampshire, UK
blitzkrieg59 Samba Member
Joined: July 04, 2001 Posts: 873 Location: Davenport, Iowa
Posted: Mon Jul 06, 2020 1:50 pm Post subject: Re: Rusted and rotten vintage speed exhaust gaskets poor fit |
I'm dealing with this stuff right now. @vwjim, any sources for those reusable copper gaskets? Also, what torque specs are we looking for on these gaskets? _________________ SST X, XI, XII
'65 Riviera Camper |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7212 Location: Videbaek Denmark
vwjim Samba Member
Posted: Mon Jul 06, 2020 3:44 pm Post subject: Re: Rusted and rotten vintage speed exhaust gaskets poor fit |
Yep, all the hardware supplied with them is mild steel so rots away far too quickly.
In the past I tack welded SS studs in place then fitted brass nuts & locking tab washers |
vwjim Samba Member
Posted: Mon Jul 06, 2020 3:46 pm Post subject: Re: Rusted and rotten vintage speed exhaust gaskets poor fit |
blitzkrieg59 wrote: |
I'm dealing with this stuff right now. @vwjim, any sources for those reusable copper gaskets? Also, what torque specs are we looking for on these gaskets? |
I made a few sets of copper gaskets, but then found that the Vintage Speed flanges warped out of shape. So the gaskets worked fine on a brand new exhaust but if you tried to fit them on a used exhaust there'd be large gaps.
I now use the CB compression gaskets as they can handle the gaps caused by banana shaped flanges. |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Tue Jul 14, 2020 5:00 pm Post subject: Re: Rusted and rotten vintage speed exhaust gaskets poor fit |
One thing that helps with copper gaskets is to heat them red hot or close to it to anneal them when you reuse them.
I used to make them on the water jet machine when I was running it on my last job, I miss that machine.
eQ _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
vwjim Samba Member
Posted: Mon Jul 20, 2020 9:45 am Post subject: Re: Rusted and rotten vintage speed exhaust gaskets poor fit |
earthquake wrote: |
eQ |
Even with annealed copper the flange gaps were too much and they leaked badly. |
