tko123 Samba Member
Posted: Thu Jan 08, 2015 11:41 pm Post subject: Fuel overflow hose diameter |
What diameter is the fuel overflow hose? I have a '72 sb.
Thanks _________________ '90 Vanagon
'72 Squareback
'66 Bug
VSC706 |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22410 Location: Kimball, Mi
Posted: Fri Jan 09, 2015 6:27 am Post subject: Re: Fuel overflow hose diameter |
tko123 wrote: |
Thanks |
You might want to contact Jim Adney ( [email protected] ), as he offers a kit to replace that hose with something far superior. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
tko123 Samba Member
Posted: Fri Jan 09, 2015 8:28 am Post subject: |
Yep, it's on my list. Any idea on that diameter? _________________ '90 Vanagon
'72 Squareback
'66 Bug
VSC706 |
andybla Samba Member
Posted: Fri Jan 09, 2015 11:43 am Post subject: |
I can measure for you tomorrow, but what hose is this? picture? |
tko123 Samba Member
Posted: Fri Jan 09, 2015 5:16 pm Post subject: |
Unfortunately I'm limited on photos because the tank is out of the car for cleaning and the remaining/related hoses and lines are all removed. Everything was cracked, damaged, or missing.
I'm looking for the diameter of the hose that goes from the tank to the right fender and then to the overflow divert on the filler neck. I realize there is a kit to solve this but I'm curious about the hose diameter. Bentley is no help. _________________ '90 Vanagon
'72 Squareback
'66 Bug
VSC706 |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34002 Location: Conejo Valley, CA
Posted: Fri Jan 09, 2015 5:34 pm Post subject: |
This hose?
http://www.vwispwest.com/311201179B.html?page=1
The "grommet" you see is actually cast into this part, not a separate part.
Do you want the ID or OD?
If you need the ID, someone could also measure a filler neck overflow nipple OD:
tko123 Samba Member
Posted: Fri Jan 09, 2015 9:14 pm Post subject: |
Ok I got it. I think I figured it out. Not to buy the JA kit.
'72 Squareback
'66 Bug
VSC706 |
tko123 Samba Member
Posted: Fri Jan 09, 2015 9:15 pm Post subject: |
Now to buy the kit- errrrr. _________________ '90 Vanagon
'72 Squareback
'66 Bug
VSC706 |
tko123 Samba Member
Posted: Sun Jan 25, 2015 4:39 pm Post subject: |
Yep Jim's amazing. He supplied the overflow kit plus an assortment of vent lines as mine were destroyed or removed. It's all installed and good to go. _________________ '90 Vanagon
'72 Squareback
'66 Bug
VSC706 |
