bikesndbugs Samba Member
Joined: January 06, 2015 Posts: 218 Location: san diego
wyattsdad Samba Member
Joined: March 14, 2014 Posts: 79 Location: Coventry CT
Posted: Fri Jan 09, 2015 1:27 pm Post subject: |
i would go with the steel ones, bolt it and a couple good tack welds. |
Brian Samba Moderator
Posted: Fri Jan 09, 2015 5:33 pm Post subject: E |
wyattsdad wrote: |
But will i need a rack and pinion and that requires changing steering right? |
Posted: Fri Jan 09, 2015 5:34 pm Post subject: |
That seems nice if it is cheap ill probobly do that thank you |
dustymojave Samba Member
Posted: Fri Jan 09, 2015 11:35 pm Post subject: |
Considering the constraints listed above, I agree with Brian that would be the best way to go.
Otherwise, I really think that if you NEED the longer travel allowed by the linkpin, you need the front frame tied into the roll cage. _________________ Richard
SoCalBajas Member
Posted: Fri Jan 09, 2015 11:37 pm Post subject: |
Those adapters are just failure points if you're going to be bashing around off-road.
And yea, if you need travel then you should have a sturdy frame. Then if you have a tube frame, you may as well have it tied to the beam. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Mal evolent Samba Member
Joined: March 31, 2009 Posts: 2912 Location: San Antonio, Nuevo Mexico
Posted: Sat Jan 10, 2015 8:26 am Post subject: |
those things move the front forward, add leverage to the frame head junction, relocate the tires forward...
American cars are over engineered. If an American car needs a 9/16" shaft, it gets a 3/4" shaft. American transmissions can typically handle 50% more power. German cars are engineered. If an German car needs a 9/16" shaft, it gets a 9/16" shaft. they don't last long when stressed beyond design limits, you have to compensate for the extra stress
the roll cage is the best way. if you can't do it the best way, use the right part:
http://www.mooreparts.com/3952-701037113G/ _________________ 73 Beetle Baja, Ghia front brakes, Type 3 rear brakes, 2220 ( 94 X 80 ), Weber Progressive, Bosch SVDA, '97 Mustang seats
Baja Bugs for Volkswagen Virgins: Index |
Posted: Sat Jan 10, 2015 10:36 am Post subject: |
Brian wrote: |
And yea, if you need travel then you should have a sturdy frame. Then if you have a tube frame, you may as well have it tied to the beam. |
In the long run it will be caged and probobly have a tubular front end just for now im not ready to do that its a project and im limited on money |
Posted: Thu May 19, 2016 7:02 pm Post subject: Re: ball joint to link pin adapter |
bringing this back up i think im gonna buy this off a friend what do you guys think of this
its got an adapter and everything works |
enjoyther1de Samba Member
Joined: December 19, 2010 Posts: 1279 Location: chino,ca
Posted: Thu May 19, 2016 7:09 pm Post subject: Re: ball joint to link pin adapter |
What exactly are you trying to do? Strengthen the front or get more travel? _________________ HBB took me to BBV. |
Posted: Thu May 19, 2016 7:12 pm Post subject: Re: ball joint to link pin adapter |
this is a friends i have ball joint curently and would like to go to linkpin its stronger and more travel than stock balljoint and then i dont have to lift it as its already lifted. I plan on buying it from him i just wanna know if this seems good or not because the steerering extensions are kinda funky |
Posted: Thu May 19, 2016 9:59 pm Post subject: Re: ball joint to link pin adapter |
The beam looks to be fine. The ball joint to link pin adapters I don't approve of. Apparently it's been used on the street for some time OK. For offroad...Nahh The only adaptation from ball joint to link pin I approve of is Bugzila's conversion beams or using roll cage to support the beam instead of the frame head. If you run cage out to the beam, then the adapters would be OK. I would not trust them on their own. The steering shaft adapter is kinda hokey too. There are better ways to extend the shaft. _________________ Richard
SoCalBajas Member
Posted: Thu May 19, 2016 10:06 pm Post subject: Re: ball joint to link pin adapter |
Ya that's what I was thinking this is gonna be temporary and it will be braced to the cage someday and ill prob change the steering extension |
Posted: Fri May 20, 2016 6:20 am Post subject: Re: ball joint to link pin adapter |
You'll be surprised what a ball joint beam will handle. I'd run the bj till the time comes to cage the car. _________________ HBB took me to BBV. |
Posted: Fri May 20, 2016 7:32 am Post subject: Re: ball joint to link pin adapter |
enjoyther1de wrote: |
You'll be surprised what a ball joint beam will handle. I'd run the bj till the time comes to cage the car. |
i need to replace ball joints on my beam because they are all going out already so i figured it would be easier to just put the linkpin on and its not gonna be doing anything hard on it or any offroad at all till it has a cage |
