ToughBug Samba Member
Joined: July 22, 2014 Posts: 354 Location: Carlisle, Pennsylvania
Posted: Tue Jan 13, 2015 4:47 pm Post subject: Rusty east-coast car support group |
Have an east coast car? Got rust? Do you buy PB Blaster, rust oleum, and sheet metal in bulk? Me too.
This week I found three new areas of rust and sheared off 3 of 6 spindle bolts and 2 of 6 bolts holding the engine chrome on. My new torquemeister didn't even budge the rear wheel nut. Actually broke a craftsman socketwrench on that one! And ran out of rust converter. The FedEx guy asked "so what is POR15 anyway? It's heavy." Gotta laugh.
Thought it might be helpful to share general strategies for beating the rust. Tools you really need. Strategies for finding and killing the rust, breaking things loose without, you know, actually breaking things. Even when to say when, and get professional help (in any sense of the word) or go shopping for a better chassis, body, etc.
What's your favorite tool against rust? Media blaster? Grinder? Sander? Acid? Base?
Bonus points for photos of your "most rusty" part. _________________ 1973 chassis + 1974 body = super beetle saved |
miller0358 Samba Member
Joined: November 07, 2007 Posts: 1200 Location: northford,ct
Posted: Tue Jan 13, 2015 6:19 pm Post subject: rust |
I always have the best luck on rusty bolts with PB Blaster and heat. If you take your time, works every time. Jeff |
toddb_67 Samba Member
Joined: November 28, 2003 Posts: 1313 Location: Hansville, WA
76VDubya Samba Member
Posted: Tue Jan 13, 2015 6:41 pm Post subject: |
A torch and penetrating oil work great for breaking things loose, as well a sharp tap with a hammer.
For cleaning surfaces and removing scale, a wire wheel, or roloc disc works great.
Rustoleum Rust Performer works great for converting and neutralizing rust.
Evapo-Rust is great for completely de-rusting parts. |
beetlenut Samba Member
Posted: Wed Jan 14, 2015 7:24 pm Post subject: |
Some light surface rust on the tunnel bottom
Typical rust in the forward rear wheel well/package tray area
Some slight C-pillar "Death Foam" rust
PB Blaster and a torch if you can get it apart, cutting it out and replacing with solid steel if you can't. _________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
far rider Samba Member
Joined: August 30, 2005 Posts: 773 Location: Rutland, VT
Posted: Wed Jan 14, 2015 9:25 pm Post subject: |
Ditto on just about everything said.
I'm not a fan of POR15. hasn't worked for me in the past. Ive been using Masterseries and prefer it
Cutting = mostly use a 4" grinder w/ metal cutting disc. A Dremel is very handy when fitting replacement pieces into place.
For frozen hinge pins I've had luck just soaking the area for a week or two. Give it a squirt of PB blaster and/or home brew of acetone and automatic transmission fluid several times a day (Im in no rush and I know my project has a while to go).
But of course heat and air hammer work well too.
Rust just brings another dimension of time, money and work to a restoration. It sucks.
Several years a go when bugs and buses were scattered all over the place I found a bug from Alabama. No rust. what a pleasure to turn every nut and bolt on that car with no issues. _________________ 67 zenith blue sunroof
Contentment; when what you have is what you want. |
DWP Samba Member
Posted: Thu Jan 15, 2015 6:14 am Post subject: |
For getting bolts off get a set of these
Craftsman 10 pc. Impact Grade Bolt-Out™ Damaged Bolt/Nut Remover
22 ReviewsDescriptionSpecifications
Description Item # 00952165000P Model # 52165
DWP |
Posted: Thu Jan 15, 2015 1:07 pm Post subject: |
Ya'll are restoring my faith in my restoration! My rusty parts look just like yours. This really helps me in getting the right tools and products. Keep them coming! _________________ 1973 chassis + 1974 body = super beetle saved |
Weezle Samba Member
Joined: February 07, 2014 Posts: 685 Location: ORLANDO
67 Sunroof Samba Member
Joined: February 22, 2014 Posts: 1836 Location: Salisbury, MD
Posted: Fri Jan 30, 2015 10:01 pm Post subject: |
Agreed. Looking at your pictures makes me feel much better about my bug.
Your post came along at a great time.
Gives me encouragement which I really needed!! |
toms64 Samba Member
Joined: August 26, 2014 Posts: 11 Location: central pa
Posted: Thu Feb 12, 2015 4:26 pm Post subject: |
Rust is the east coast "patina" Well I see I'm in good company! Tried the acetone tranny fluid mix on some 44 jeep parts. Works good but be patient....pb blaster is still the best I've used but I just couldn't stand the smell anymore when working indoors! Is it me or does that stuff smell like liquid mothballs??!! Has anyone tried the small panel saws like HF sells? My 64 bug is gonna need a front nose job and the panel saw looked good for that ..... |
Posted: Sun Feb 15, 2015 6:05 am Post subject: |
Weezle wrote: |
Whose got a list of links to builds that required heater channel replavement? That's next on my list. |
If you haven't already, Just do a search in this forum for "heater channel replacement", there's plenty.
I would suggest 1. Take plenty of measurements 2. Weld in temporary reinforcements before removing original channels _________________ 67 zenith blue sunroof
Posted: Fri Feb 27, 2015 11:51 pm Post subject: |
toms64 wrote: |
pb blaster is still the best I've used but I just couldn't stand the smell anymore when working indoors! Is it me or does that stuff smell like liquid mothballs??!! |
That stuff is messy, and has a strong odor, but it works pretty good. Liquid Wrench (penetrating oil) smells almost exactly the same. Both give me a headache after using them. |
Fahrbomb Samba Member
theKbStockpiler Samba Member
Joined: July 07, 2012 Posts: 2316 Location: Rust Belt
Posted: Tue Mar 03, 2015 10:09 am Post subject: |
Whisky and denial work for me. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask. |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Tue Mar 03, 2015 12:32 pm Post subject: |
Don't take the body off the pan, at least for now. A wire wheel & a spot sand blaster will get it clean enough to see what needs patching. A grinder & sawzall will handle all the cutting/grinding. Make your own patches when possible. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Wed Mar 04, 2015 9:25 am Post subject: |
Thanks for the info Mike Fisher. |
Dr OnHolliday Samba Member
Joined: May 11, 2012 Posts: 1215 Location: was Escondido now San Berdoo
Posted: Thu Mar 05, 2015 8:31 am Post subject: |
Pick the response that is most useful to you:
1. Is this a 12-step group?
2. Why are you destroying the patina?
3. Why has no one advocated wadded newspaper and bondo?
(That's supposed to be humor. You'll some form of humor as you proceed)
I suppose you all know about Eastwood Co. As it turns out, the tools they sell are available from the actual manufacturers (or maybe Harbor Fright)...but if you are starting sheetmetal work may be educational to peruse their website. Its actually very inspiring to see what can be accomplished with a sandbag and mallets, or a shrinking disc...
Best of luck to you all. _________________ 1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust |
