roymartian Samba Member
Posted: Thu Jan 15, 2015 4:30 am Post subject: Oval to split hood conversion |
Hi Guys,
Just finished adding third captive nut and stay to oval donor hood.
I have the triangle plate from Mika but am unsure on position to fit;
1. Should I align to top two slotted holes (when I do this I have a gap to reinforcement panel)
2. Should I butt against reinforcement panel and re-instate all 4 slotted holes
Appreciate any advice pictures to follow...
Thanks,
R |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Fri Jan 16, 2015 5:58 am Post subject: |
Nice - so can i ask;
1. Is triangle plate isometric triangle ?
2. Should it tuck under reinforce or not ?
3. Does it have radius ends on all 3 corners ?
Thanks,
R |
caleb0101 Samba Member
Joined: August 26, 2014 Posts: 524 Location: Bristol Connecticut
Posted: Fri Jan 16, 2015 1:31 pm Post subject: |
By looking closely at the picture it looks like all 3 corners are rounded |
Porsche904 Samba Member
Posted: Fri Jan 16, 2015 2:07 pm Post subject: |
caleb0101 wrote: |
Yes, can confirm this |
GermanRust52 Samba Member
Posted: Sun Jan 18, 2015 7:47 am Post subject: |
Posted: Mon Jan 19, 2015 1:26 am Post subject: |
Great picture - thanks!
See my issue below, Mika sending me a new plate
Posted: Mon Jan 19, 2015 1:28 am Post subject: |
GermanRust52 - if possible would be keen to understand dims from reinforce to top of triangle please - thanks |
Posted: Mon Jan 19, 2015 7:56 am Post subject: |
I made my own plate
Posted: Mon Jan 19, 2015 7:58 am Post subject: |
usariemen Samba Member
Joined: August 28, 2004 Posts: 1745 Location: Germany
Posted: Mon Jan 19, 2015 10:55 am Post subject: |
GermanRust52 wrote: |
I made my own plate.
That is good to hear. I did not understand why the other guy has to get a little flat metal part sended from Finland to Australia. Everyone who restores a car should be able to make such one himself.
But.
The signs have the same size.
But the fixing tabs are differend located.
If you keep using the two slots as they are in the oval hood the enblem will sit more to the rear when you use a split one.
You should cut all three slots new in the correct poosition.
_________________ Master of my domain! |
Posted: Mon Jan 19, 2015 12:51 pm Post subject: |
usariemen wrote: |
But.
WOW good to know that but for me is too late,I already spot weld the plate.Thanks |
Posted: Mon Jan 19, 2015 1:24 pm Post subject: |
Posted: Mon Jan 19, 2015 3:22 pm Post subject: |
Yes, thatīs too late now.
Well, not dramatic. Just the gap between the enblem and the trim will be about half an inch wider. _________________ Master of my domain! |
Posted: Tue Jan 20, 2015 3:35 am Post subject: |
Thanks guys for your help with this I had "my little plate sended from Finland to Australia" as part of a bigger shipment from Mika.
I think I now have info needed. |
Posted: Fri Jan 23, 2015 9:03 pm Post subject: |
Thanks Mika for all your help with plate, dimensions and position
splitjunkie Samba Member
Posted: Sat Jan 24, 2015 6:10 am Post subject: |
those are great. Could you measure the size of the holes on the plate? _________________ Chris
virtanen Samba Member
Joined: January 08, 2006 Posts: 1462 Location: Finland
Posted: Sat Jan 24, 2015 10:01 am Post subject: |
Awesome. Thanks. _________________ Chris
Posted: Sun Jan 25, 2015 5:34 am Post subject: |
Nice one Mika - excitedly waiting for post! |
