shoatx Samba Member
Joined: March 21, 2009 Posts: 197 Location: North East Nevada
Posted: Fri Jan 16, 2015 8:37 pm Post subject: Heater channel question |
Hello, I found some rusted thru spots on the bottom side of both heater channels. Other than those few spots they are in really good shape. I found this at Wolfsburg West, they call it a side member bottom plate and it looks exactly like what i need. What i want to know is if anyone has just replaced this piece instead of the whole heater channel, and is it spot welded on or what? The original channels look like that they are all one piece and i cant see any seams where the heater channel and this bottom plate are welded together. Thanks for any help or advise on this.
Randy
_________________ 1957 Beetle Currently under restoration.
1974 std. Beetle
Sand rail buggy. |
Lidpainter Samba Anti-Hero
Joined: January 21, 2004 Posts: 2045 Location: 41.77 | -83.56
Posted: Fri Jan 16, 2015 8:45 pm Post subject: |
Sand or grind along the outside edges and you'll see hundreds of spot welds. Might be hard to see if they're really rusty. _________________
EverettB wrote: |
Thanks, time to bulk up on meat! |
shoatx Samba Member
Posted: Sat Jan 17, 2015 11:55 am Post subject: |
Thank you sir, i will try that. _________________ 1957 Beetle Currently under restoration.
1974 std. Beetle
Sand rail buggy. |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3776 Location: Twin Cities, MN
shoatx Samba Member
Posted: Sat Jan 17, 2015 4:39 pm Post subject: |
Well, while wire brushing off the gunk to look for the spot welds i found a lot of rusted thru spots on the sides so i have to replace the complete drivers side heater channel. The ones i see advertised are mostly for 58 to 68, will those fit a 57? What are the differences between those and the ones for 57?
Some of the ads say 48 to 68 so now i am really not sure what i need...
Thanks _________________ 1957 Beetle Currently under restoration.
1974 std. Beetle
Sand rail buggy. |
splitjunkie Samba Member
Posted: Sat Jan 17, 2015 5:30 pm Post subject: |
Klassic Fab (gerson) makes great split and early oval heater channels. _________________ Chris
jason Samba Member
Posted: Sun Jan 18, 2015 11:01 am Post subject: |
I'd take the bottoms off first. I did mine and just cut the rusted sections out, easier than the whole channel. I bought mine from Gerson, the bottoms. There is a spot weld about every inch. The major difference is the heater outlet and the stampings on the bottom. Sedan can be seen if you look under, vert is hidden by support rail. |
shoatx Samba Member
Posted: Sun Jan 18, 2015 3:39 pm Post subject: |
jason wrote: |
Thats what im going to do on the right side, but the left is too far gone _________________ 1957 Beetle Currently under restoration.
1974 std. Beetle
Sand rail buggy. |
