shermanator Samba Member
Joined: October 06, 2014 Posts: 19 Location: rogersville tn
Posted: Sat Jan 17, 2015 2:19 pm Post subject: De-chroming and powdercoating |
Has anuone ever attempted to dis-assemble, sandblast (in order to de-chrome) then painted or powder coated a set of NEW stock door handles or deck lid latches? ANY and ALL feedback is greatly appreciated......wanting to have black door handles, deck lid latch, bumpers (purchased new and primered already) and possibly chrome/aluminum around rear pop out windows ALL black! |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Sat Jan 17, 2015 4:40 pm Post subject: |
I tried to sandblast chrome wheels & my pressure sand blaster wouldn't blast the chrome off of them! _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
EverettB Administrator
Joined: April 11, 2000 Posts: 69823 Location: Phoenix Metro
a.wilson Samba Member
Joined: January 11, 2007 Posts: 2033 Location: Georgia
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21519 Location: Oklahoma City
Posted: Sun Jan 18, 2015 9:05 am Post subject: |
As for the high cost of chemically stripping chrome.....its almost always higher than what you think.
It also depends upon what state the chrome stripper is located in.
The cost of getting rid of the stripping vat chemicals is astronomical in many places. Typically in can be in the neighborhood of $850-$2000 a drum.
The two most popular chemical methods being hydrochloric acid dip or reverse electroplate using Chromic acid, Sulfuric acid and water with electricity.
Both of those methods produce waste you cannot just pour down the drain.
And no...you cannot just use baking soda or caustic soda to neutralize the hydrochloric acid and then pour it down the drain.
You and I can do that at our house (the EPA has a household exemption on treatments like that...but your local water department may not extend this exemption so be careful)
However....ANY business that does this without and EPA permit for treatment of industrial effluent along with the requisite State and Federal EPA monitoring system, equipment, treatment tanks ....yada, yada, yada...is risking a fine that I can guarantee you would shut most businesses down permanently in less than 5 minutes. If they want to stick it to you....the fine could be close to 6 figures. They dont deal anymore.
.....you can in most areas do basic natural state PH neutralization (like acid with baking soda mentioned above)....but that does not get rid of the metallic ions and silt in this solution.
The only way to drop that level is by adding a ton of water after you neutralize the acid....and that is the point where you have just broken the law. Dilution is listed as treatment. You cannot do that unless you are a licensed treatment facility
This is why its expensive to chemically strip chrome. They have to balance the profit and cost with what it requires to get rid of the chemicals when they are spent. Ray |
