16CVs Samba Member
Joined: February 22, 2004 Posts: 4015 Location: Redwood City, California
Posted: Mon Jul 20, 2015 11:48 pm Post subject: |
So after a day with my new harness, no real difference except my dash lights all work.
My initial issue with the turn signals was a loose connector in the factory plug. it took a few minutes to diagnose, but nothing more than a small pull with a paper clip brought it into position and all is well.
A nice upgrade which was well executed.
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32367 Location: Reading Pennsylvania
CampWesty Samba Member
Joined: September 05, 2012 Posts: 70 Location: North Carolina
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Wed Jun 15, 2016 9:55 pm Post subject: Re: GW Instrument foil replacement, NEW design |
Does anyone know if the Gowesty kit have a new dynamic oil pressure warning system or does it just interface to the original dynamic warning system?
I have a 1985 which does not have dynamic oil pressure warning, but if the Gowesty kit has this I would like to use it. I understand that all I would need to do is add a second oil pressure switch and run two new wires from the engine bay - one from the new pressure switch to give a low oil pressure signal and one from the coil to give the engine speed signal. _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
Posted: Wed Jun 15, 2016 10:07 pm Post subject: Re: GW Instrument foil replacement, NEW design |
Partially answering my own question, I found this under Tech Notes on the Gowesty web site: "The main circuit board includes a new GoWesty-designed dual oil pressure monitoring circuit with audible alarm. This replaces the stock (and aging) dual oil pressure monitoring circuit located in the speedometer housing."
But there are two versions of the kit - one for the analogue clock cluster and one for the tachometer cluster which is $30 extra. I ordered the analogue clock version so not sure if this includes the dynamic oil monitoring. _________________ 1962 Karmann Ghia
Altoona Samba Member
Posted: Thu Jun 16, 2016 8:41 am Post subject: Re: GW Instrument foil replacement, NEW design |
Mellow Yellow 74 wrote: |
But there are two versions of the kit - one for the analogue clock cluster and one for the tachometer cluster which is $30 extra. I ordered the analogue clock version so not sure if this includes the dynamic oil monitoring. |
Yes, all of the versions have dynamic oil pressure system as it is built into the main board, there is a little micro switch on the board that you turn off if you have an engine without this system.
However, since you don't have the dual sensor system in your van, you can't use dynamic oil pressure monitoring anyway. |
oceanair Samba Member
Joined: June 09, 2013 Posts: 720 Location: Victoria, BC
Posted: Thu Jun 16, 2016 10:06 am Post subject: Re: GW Instrument foil replacement, NEW design |
Quote: |
Just wanted to chime in and let everyone know there is another solution to this that's roughly $100 cheaper and it's easier to install. It's a "plug n' play" setup. Zero modifications are needed; kits come fully assembled. You literally swap out the blue foil with the new kit, that's it.
Cluster Master from South Africa has been making kits for a few years now, and I'm now importing them here to the USA on a regular basis, sold through www.vanagon.org.
Here's the product link: http://www.vanagon.org/instrument-cluster-foil-repair-kit/
Here's the instructions: http://www.vanagon.org/instrument-cluster-foil-repair/
_________________ |
Has anyone tried this kit or have any comments on it? Looks promising. _________________ 84 Vanagon Pop Top Conversion from Tin Top, 1970 Ghia - all sweet rides! Love em!
Previous: Green 72 Tin Top, White 72 Westy, Blue 64 Beetle, Yellow 71 Squareback, 2014 Jetta TDI Wagon - wish I could have them all back! |
Merian Samba Member
Posted: Thu Jun 16, 2016 11:38 am Post subject: Re: GW Instrument foil replacement, NEW design |
I am also interested in the same question - so... bump _________________ .... |
Posted: Thu Jun 16, 2016 11:59 am Post subject: Re: GW Instrument foil replacement, NEW design |
Altoona wrote: |
I have installed an oil pressure send relocation manifold so now have high and low oil pressure switches - just need to install wiring.
oceanair wrote: |
Has anyone tried this kit or have any comments on it? Looks promising. |
It does look good and it is much cheaper than the Gowesty kit. FWIW, it uses the original dynamic oil pressure circuit in the speedo so can't be used to retrofit this like I am planning to do. _________________ 1962 Karmann Ghia
B-bear604 Samba Member
Joined: August 16, 2014 Posts: 118 Location: Delta BC
Posted: Mon Jun 20, 2016 7:27 pm Post subject: Re: GW Instrument foil replacement, NEW design |
I put one of Erics wiring kits from www.vanagon.org in my van and was simple and quick. Gave me nice bright lights and I was able to easily add a tach I had picked up out of the clasiffied ads and a small VDO clock which I installed under the warning lights. yes the wiring is that straight forward. Highly recommend this product especially if you are having any issues.
Also recommend T-3's plasma gauges, another great product that really improves night time driving _________________ Brent H
1991 Westfalia Multivan "Vicki"
1986 Westfalia "Wolfsburg Edition" Lowered, RIP😭
2005 Jetta Wagon TDI
1985 Mercedes 380sl |
Posted: Thu Jun 23, 2016 4:02 am Post subject: Re: GW Instrument foil replacement, NEW design |
I have installed an oil pressure send relocation manifold so now have high and low oil pressure switches - just need to install wiring. |
I am trying to find the terminals that go inside the white instrument harness plug in the van that the Gowesty harness plugs into. The terminals crimp onto the wires have two little "fingers" that are the contacts inside the plug but I can't find anywhere that sells them (in Australia) because I don't know what they are called. Can anyone help? _________________ 1962 Karmann Ghia
Posted: Fri Jun 24, 2016 2:25 am Post subject: Re: GW Instrument foil replacement, NEW design |
I no longer need this because I have decided to cut off the original white plug and the plug on the Gowesty harness and solder the wires together. The Gowesty plug does not give a great connection because I had to wiggle the wires to get all the LED's to work properly.
The Go Westy instructions describe doing this as the "optional cluster reliability connection" if your white plug is damaged or corroded - my plug is in good condition but it is still not a reliable connection. You can still remove the instrument cluster by unplugging the harness where it connects to the PC board. _________________ 1962 Karmann Ghia
Last edited by Mellow Yellow 74 on Fri Jun 24, 2016 1:53 pm; edited 1 time in total |
RCB Samba Member
Joined: September 05, 2005 Posts: 4143 Location: San Francisco-Bay Area
Posted: Fri Jun 24, 2016 6:09 am Post subject: Re: GW Instrument foil replacement, NEW design |
Had the Go Westy kit installed a few days ago.The foil on my 82 Westy was falling apart. John at Freds Garage had tried a few repairs to it but with loosing the dash light function and having the battery charging light failing, it became time to permanently fix it.
Once installed I noticed right away the replacement LED's are much brighter, all the lights are now working, and for me it was important to know the charging system was operating properly. |
Nikkoleto Samba Member
Posted: Mon Jul 18, 2016 10:25 am Post subject: Re: GW Instrument foil replacement, NEW design |
I was hoping someone could help me out with this problem. When I installed GoWestys Printed Circuit Replacement Kit my Temperature Gauge and Gas Gauge no longer works. What did I do wrong?
Thanks in Advance _________________ 1987 Vanagon GL |
Posted: Mon Jul 18, 2016 10:30 am Post subject: Re: GW Instrument foil replacement, NEW design |
Nikkoleto wrote: |
Thanks in Advance |
Probably something to do with the voltage regulator. |
Posted: Mon Jul 18, 2016 1:06 pm Post subject: Re: GW Instrument foil replacement, NEW design |
Altoona
Thanks for the tip you were right. I installed and now my Speedometer doesn't work!!!! Does this kit have anything to do with the speedometer? or didn't I get the speedometer cable in right? [which I think its in right] _________________ 1987 Vanagon GL |
Posted: Mon Jul 18, 2016 1:11 pm Post subject: Re: GW Instrument foil replacement, NEW design |
Nikkoleto wrote: |
Altoona
Thanks for the tip you were right. I installed and now my Speedometer doesn't work!!!! Does this kit have anything to do with the speedometer? or didn't I get the speedometer cable in right? [which I think its in right] |
Nothing to do with the speedo, probably need to seat the cable better. |
Posted: Mon Jul 18, 2016 1:12 pm Post subject: Re: GW Instrument foil replacement, NEW design |
Thanks I was hoping that was the problem _________________ 1987 Vanagon GL |
Slimvest Samba Member
Joined: March 20, 2014 Posts: 431 Location: Portland, OR
Posted: Mon Jul 18, 2016 2:16 pm Post subject: Re: GW Instrument foil replacement, NEW design |
Too bad buying direct from SA isn't an option. $80!
_________________ '87 GL w/ Reimo top |
