tide Samba Member
Posted: Tue Jan 20, 2015 4:32 pm Post subject: 74 Ghia - Going wider (sanity check) |
I'm about to drop about 2k on some nice 5x130 real chrome rims and want to have a little sanity check here on my math. I'd be going from the stock 4.5" to 5.5j x 15 (Porsche pattern 5x130). Seems tight, but within reason.
Thanks
scottmc Samba Member
Joined: January 10, 2014 Posts: 197 Location: patchogue ny
Posted: Tue Jan 20, 2015 8:19 pm Post subject: |
for 2k you could get some Porsche wheels and the rest of the parts to fit them. |
NJ John Samba Member
Joined: September 21, 2007 Posts: 2225 Location: HdG, MD & NJ
Posted: Wed Jan 21, 2015 3:32 pm Post subject: |
Looks like they'll fit. Do you have at least 14mm of fender clearance, now?
What rim/tire website is that? _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
rockerarm Samba Member
Joined: December 16, 2009 Posts: 3552 Location: Los Angeles
Posted: Mon Mar 09, 2015 8:06 pm Post subject: |
Just a thought, but have you considered the 914 steel wheel which is 1" wider on the inboard side? I have a friend with a '69 ghia and installed a pair of these 914 wheels with some 195/65 15's and the fit is nice and look cool from the rear! That size tire is readily available.
Now as far as the 5x130 wheel, have your own made at I'm sure a noticeable savings. I am going over to a wheel maker here in the Los Angeles area and get his latest contact data plus a question answered for a fellow sambanista on widening some early wheels to 7". I'm thinking core centers are plentiful as 5 lug Porsche wheels were used on many models. I guess the wheel dimensions should be determined after the body work is done and the ride height is finalized.
Hope this helps, Bill. |
didget69 Samba Member
Joined: July 22, 2004 Posts: 4927 Location: Raleigh, North Carolina
Posted: Thu Jul 16, 2015 9:27 am Post subject: |
What rim? And - realize that no two Ghia rear fenders are the same regarding clearances...
bnc _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
Fiatdude Samba Member
Joined: April 20, 2009 Posts: 1218 Location: now in MO.
Posted: Thu Jul 16, 2015 10:55 am Post subject: |
I think you will be OK -- just get under your car and look at the clearance between the tire and the torsion arm -- that is the major clearance issue I've had -- Then take you pointy finger and run it between your current tire and the fender (that's about 1/2") -- If it slides through there you should be golden
It is always easier going out than in -- I went over to Porsche 5x130 with disc brakes all around.... Then found some 16" phone dials on craigslist for $200 about 5 miles from the house -- ended up spending another $80 for some custom 13mm spacers to that I could center some 225's on the rear -- took a little fender rolling, but I think it looks nice now
REMEMBER -- -- If you can slide a piece of paper in there,,,, you have enough clearance LOL
. _________________ Remember, as you travel the highway of life,
For every mile of road, there is 2 miles of ditch |
911pickup Samba Member
Joined: March 06, 2004 Posts: 625 Location: Near Goats on the Roof
Posted: Thu Jul 16, 2015 3:55 pm Post subject: |
Do you have the 0.6" of fender clearance needed to mount your new tires/wheels? |
