runamoc Samba Member
Joined: June 19, 2006 Posts: 5593 Location: 37.5N 77.1W
Posted: Tue Jan 20, 2015 7:20 pm Post subject: Cable Routing For Rear Disc Brakes |
I've searched for pictures on how to route the emergency brake cables on a CB Performance rear disc brake conversion for an IRS Ghia. No luck. I've tried different ways..even upside down. Looks good except the bleeder is below the brake line. Any help??
_________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
trbugman Samba Member
Posted: Tue Jan 20, 2015 9:00 pm Post subject: |
Mine routed nicely in front of the bump stop on top of the control arm, if I remember correctly. I'll have to take a look/picture tomorrow.
Upside down doesn't look to bad, but I would be concerned about the cable possibly getting snagged on something. Unlikely to happen, but a possibility none the less. _________________ 2333(103x70) Type 4 DTM MS3+X on 73 Karmann Ghia ignition only with LS2 truck coils firing in sequential, fuel next. |
Posted: Thu Jan 22, 2015 8:03 am Post subject: |
Here they are mounted according to the directions. The directions from CB Performance makes no mention on routing the e/brake cable. I can't believe this is right.
CiderGuy Samba Member
Joined: December 23, 2013 Posts: 1351 Location: Bucks County, Pa
Posted: Thu Jan 22, 2015 9:07 am Post subject: |
I would contact CB Performance with these pictures and see what they have to say. |
Posted: Tue Feb 10, 2015 8:46 am Post subject: |
CiderGuy wrote: |
I did. They pretty much told me it's not much they could do. So I made it work. The routing looks good, imo. Also, made the hard brake line to rubber line joint secure.
