Newbugger71 Samba Member
Joined: August 14, 2013 Posts: 12 Location: Manitoba, Canada
Posted: Tue Jan 20, 2015 8:48 pm Post subject: rust repair 71 standard. |
Hello Samba.
The following pictures are from my 71 standard beetle. The pictures are of the passenger front wheel well and fender. It was bought by the original owner to use as a winter car in Manitoba, Canada. Hence the rust issues. I don't think they are too major though...
Anyway I am going to clean the areas as best as I can with wire wheel etc.
Once done that I would like to finish the areas with a quick rattle can paint. Before paint though, what is the best product to use? Is a rustoleum rust primer okay?
Not looking for professional finish, just trying to get rid/stop/slow down the rusting.
Thanks in advance.
beetlenut Samba Member
Posted: Wed Jan 21, 2015 7:56 am Post subject: |
Use some phosphoric acid or Ospho to stop/seal/convert the remaining rust. Master Series Silver primer is a good base primer to use over that, and then regular primer and paint on top should last a while. _________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
CiderGuy Samba Member
Joined: December 23, 2013 Posts: 1351 Location: Bucks County, Pa
Posted: Wed Jan 21, 2015 10:59 pm Post subject: |
Use a wire or flap wheel to remove grind off the rust that you can see ..... before doing anything else. |
Thrasher22 Samba Member
Joined: October 05, 2010 Posts: 858 Location: Calgary, Canada
Posted: Thu Jan 22, 2015 12:22 pm Post subject: |
A knotted wire wheel on a grinder will take off far more rust (and be way faster) than a wire wheel on a drill like most people use.
And as recommended above, acid treat it (rustmort is a common one in Canada, can get it at NAPA) and paint.
If you don't have a heated work space, I'd avoid Rustoleum, it'll take forever to cure if it cures fully at all. _________________ 1975 Westfalia - http://www.thesamba.com/vw/forum/viewtopic.php?t=516701 |
Posted: Thu Jan 22, 2015 5:03 pm Post subject: |
Thanks for the replies. I will see what I can find this weekend. Being in Canada I think my choices are limited.
Any other products/ideas greatly appreciated. Especially anything easily available in Canada.
Just curious...por 15 is not the product to use for this application?
Thanks again. |
