onetuza Samba Member
Joined: June 20, 2012 Posts: 579 Location: Sebastian, FL
Posted: Wed Jan 21, 2015 6:03 am Post subject: More Than a Headlight Problem? *Resolved?* |
When I got my '65, two and a half years ago it had weak headlights so after quite some time, I replaced them with Sylvania H6024ST 65-watt high performance halogen sealed beams. They lasted 10 mos and blew out together. (I should mention here that this is a show car and the headlights only get used maybe a dozen times during the winter here in Florida)
I contacted Sylvania and they sent me a new pair, as they were under the one-year warranty. At the time they told me that if they didn't work for me, they had another model they'd send me. They did say that halogens have a short life, but not that short.
Well, they blew again. both together, I think when I hit the high beam switch. This time I'm over the warranty, but I plan on contacting them.
My question? Is there another factor that could be blowing these lights? The high beam switch, the relay? I'm not too knowledgeable when it comes to electrics.
Is there maybe a better sealed beam headlamp you can recommend? (I don't want blue headlights.) _________________ When I die, I want to go peacefully in my sleep, like my grandfather . . . .
Not screaming, like the other passengers in his car!
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Wed Jan 21, 2015 7:43 am Post subject: |
6 volt or has it been upgraded to 12 volt?
Dim lights are often a symptom of bad grounds. On a show car that might be as simple as paint on the grounding studs. On a "not a show car" that is often from dirt, rust or corrosion on the grounding studs.
Of course poor connections on the positive side of the circuit can also cause dim lights.
It's unusual that both times you mention both lights went at the same time. That's a little fishy and makes me question if you have some sort of voltage spike that may be overloading the bulbs.
Have you taken the bulbs out and used a couple of alligator clips to test them?
And when they blow are you loosing just the low beams or are you using the high beams as well?
Need a few more details! _________________ Mother Nature is a Mean Evil Bitch! |
Posted: Wed Jan 21, 2015 7:59 am Post subject: |
drscope wrote: |
Need a few more details! |
Loosing both low & high.
When you say alligator clips, do you mean attach the light directly to the battery? If so, then no.
I pulled the dead lamps and hooked up the old ones I got with the car and they work, and they never blew, but I hear what you're saying.
Can the high beam switch or relay cause something like this? What could cause a voltage spike?
I'm pretty sure it was when I hit the high beam switch and I'm pretty sure the ground is OK since the halogens seemed way brighter than the originals. _________________ When I die, I want to go peacefully in my sleep, like my grandfather . . . .
Not screaming, like the other passengers in his car! |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34012 Location: Conejo Valley, CA
Posted: Wed Jan 21, 2015 8:27 am Post subject: |
First check the wiring. Make sure the three wires are in the correct pin sockets. They actually can work with them wrong, but draw too much current or seek an alternate ground path.
Another possibility is that your dimmer foot switch is bad, perhaps shorting for a brief moment, or sending current to both high and low at the same time.
A VOM can check both these possibilities out in under an hour. |
Posted: Wed Jan 21, 2015 8:31 am Post subject: |
On a side note, I'm thinking of switching to non-sealed beams so when one blows I don't have to pull the damn bucket apart.
Something like these:
http://www.amazon.com/gp/product/B0002M9QJM/ref=ox...PDKIKX0DER _________________ When I die, I want to go peacefully in my sleep, like my grandfather . . . .
KTPhil Samba Member
Posted: Wed Jan 21, 2015 8:43 am Post subject: |
Those work great. I've used them for about 30 years! Those are the E-code pattern, not the crappy DOT sealed beam type pattern. Easy to get the H4 bulbs still, too, at least in 12V. |
fla2smoker Samba Member
Joined: December 31, 2011 Posts: 574 Location: Parrish, Florida
Posted: Wed Jan 21, 2015 1:16 pm Post subject: |
For the time being I think you need to forget about replacing your headlights and figure out what the problem is! Switching out bulbs isn't going to make the problem go away.
Once you have it figured out and corrected, then go back to thinking about what bulbs to use.
Take your old bulb and look at it. There should be 3 connections on the back. One is ground, one is low beam and one is high beam. the top, or center pin is usually the ground.
use your alligator clips and test wires to your battery. Hook from that top/center connector to ground and then run a hot wire to the other connectors one at a time to see whats working.
To loose high and low on both bulbs at the same time is pretty fishy to me.
Are you running a generator or an alternator? And you didn't answer if you are still 6 volt or upgraded to 12. _________________ Mother Nature is a Mean Evil Bitch! |
Posted: Wed Jan 21, 2015 2:00 pm Post subject: |
drscope wrote: |
Are you running a generator or an alternator? And you didn't answer if you are still 6 volt or upgraded to 12. |
Thanks for the input.
12V with an alternator.
I've been reading various other auto forums and several have said that it's not uncommon and that when a lamp blows it can cause a power surge to the other one an blow it too. _________________ When I die, I want to go peacefully in my sleep, like my grandfather . . . .
Posted: Wed Jan 21, 2015 2:15 pm Post subject: |
KTPhil wrote: |
Does it matter that they say they are flat?
Also they are apparently only legal for off-road use? _________________ When I die, I want to go peacefully in my sleep, like my grandfather . . . .
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Wed Jan 21, 2015 3:38 pm Post subject: |
KTPhil wrote: |
This was my suspect from the start of this thread. Also, establish new grounds for both headlights. _________________
EverettB wrote: |
FU#5 |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Wed Jan 21, 2015 8:41 pm Post subject: Re: More Than a Headlight Problem? |
onetuza wrote: |
My question? Is there another factor that could be blowing these lights? The high beam switch, the relay? I'm not too knowledgeable when it comes to electrics. |
A bad ground or any other voltage drop through a poor connection, weak relay or such will restrict current flow and make the bulb glow dimmer and last longer.
Even if you did power both low and high beam filaments at one time, that should not make both of them blow, so not likely a bad dimmer switch.
High Voltage, as in more than what the bulb is tested to withstand, is what will shorten the life of the bulbs.
Ever notice how many new cars you see with a burned out headlight bulbs? It's because modern cars use 125-150 amp alternators running at a constant 14+ volts in order to provide the needed power for all the electronics and engine management systems.
Keep in mind most all incandescent light bubs are similar whether regular or halogen, as all have a filament of tungsten wire that glows red hot and bright when energized. The fact that the wire is sealed in a vacuum and the different gases surrounding it are what protect the wire from instantly vaporizing/burning out.
Ever notice even WalMart sells head light bulbs? They are a fast mover in the modern world. The so called "Long Life" bulbs that cost more are actually rated for about 15 volts, and are made with a heavier filament wire to give them more durability.
So, do you have a high output alternator on the engine? What is your battery voltage when the car is running? _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
KTPhil Samba Member
Posted: Wed Jan 21, 2015 11:55 pm Post subject: |
onetuza wrote: |
Also they are apparently only legal for off-road use? |
Ignore both "warnings." I say. They are of a design that has been legal on new cars for over 20 years, using the very same bulbs and light patterns. Strictly speaking, these are not legal as a retrofit, but simple logic tells you if you have the same type lights as 80% of the cars on the road, you will not be cited or even noticed. Just aim them carefully-- check the European owners manuals for the pattern directions (though you use the regular USA-manual screw/adjuster locations). "Flat" just means the front glass is nearly flat, not circular like sealed beams. It's just style thing. |
Posted: Thu Jan 22, 2015 6:57 am Post subject: |
One important thing I forgot to mention is that when I originally swapped out the standard lamps for the Sylvania H6024ST 65-watt high performance halogen sealed beams, the low beams were marginally better, but the high beams were exceptional. Would this indicate something wrong with the high/low switch or relay with respect to the low beams? _________________ When I die, I want to go peacefully in my sleep, like my grandfather . . . .
KTPhil Samba Member
Posted: Thu Jan 22, 2015 10:00 am Post subject: |
onetuza wrote: |
One important thing I forgot to mention is that when I originally swapped out the standard lamps for the Sylvania H6024ST 65-watt high performance halogen sealed beams, the low beams were marginally better, but the high beams were exceptional. Would this indicate something wrong with the high/low switch or relay with respect to the low beams? |
Maybe. No substitute for a through test with a VOM to check for continuity, shorts, etc. |
61SNRF Samba Member
Posted: Thu Jan 22, 2015 3:12 pm Post subject: Re: More Than a Headlight Problem? |
61SNRF wrote: |
onetuza wrote: |
Hear me now and believe me later _________________ -Bruce
Posted: Fri Jan 23, 2015 9:42 am Post subject: |
65 converted to 12 volt with an alternator and blowing all 4 filaments in the headlight bulbs.
Did you by chance order your headlight bulbs by year and not by voltage? _________________ Mother Nature is a Mean Evil Bitch! |
Posted: Fri Jan 23, 2015 10:23 am Post subject: |
drscope wrote: |
Did you by chance order your headlight bulbs by year and not by voltage? |
These are them, doesn't say.
http://www.amazon.com/gp/product/B000COCTWG/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1 _________________ When I die, I want to go peacefully in my sleep, like my grandfather . . . .
Posted: Fri Jan 23, 2015 11:28 am Post subject: |
Just found this thread which may be very helpful, especially since my halogen low beams seemed dull to me:
http://www.thesamba.com/vw/forum/viewtopic.php?t=608076 _________________ When I die, I want to go peacefully in my sleep, like my grandfather . . . .
