jdcool4 Samba Member
Joined: September 19, 2010 Posts: 98 Location: Temperance MI
Posted: Wed Jan 21, 2015 6:54 am Post subject: 1996 jetta radiator vs golf mk1 or mk2 radiator |
I have a couple of questions on the older golf radiators. I am trying to use one as a radiator on my Ecotec swap on my sand rail. I need both fittings to be on the left so I plan to mount a VW radiator up side down to the rear of the engine . I got a radiator from a junk yard out of a 1996 VW JETTA with a manual trans so it has no other fittings to worry about also got the fan assembly to go with it. It may be a little taller then I want also harder to mount then I think the aluminum radiator would be.
So my question is is the golf radiators the same other then side no hose fittings and pins on the bottom I have been looking at the pictures on Ebay and its hard to tell.
Some thing like this what is that pin on the bottom left or is it a nipple
http://www.ebay.com/itm/ALUMINUM-ALLOY-RADIATOR-VW...mp;vxp=mtr |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Wed Jan 21, 2015 3:49 pm Post subject: |
Those are pins it looks like and that one appears to be up-side down. As the Fan switch is normally in the lower left when looking from the motor side. |
kamzcab86 Samba Moderator
Posted: Fri Jan 23, 2015 8:35 pm Post subject: Re: 1996 jetta radiator vs golf mk1 or mk2 radiator |
Mk1/Mk2 radiator components:
_________________ ~Kamz
2016 Golf GTI S
Posted: Fri Jan 23, 2015 11:30 pm Post subject: |
Thank you that helps a lot . I throught that might be a nipple for a overflow tank . I can just plug that off i plan to mount it just like in the picture. Do you see any problems with this cooling a 2.4 ecotec mounted on the rear of the sand rail |
