bluebus86 Banned
Posted: Fri Jan 23, 2015 8:24 pm Post subject: |
I learned to drive with a stick shift, and frankly I think driving with one makes a better driver. Seen too many automatic drivers fry their brakes by going down long steep grades in Over Drive gear. These folks don't have a clue about shifting, they only use, park, reverse and Drive (or Over Drive). a person that drives a stick has some understanding of engine braking and down shifting, and is thus more intuned with the gearing issues that many automatic drivers don't understand, cause they never had to understand them.
Three cheers for a Bug as a first car. I am second generation Bug driver, did my Dad well, did well by me.
as far as the non roll up windows, my thought is this car was modified, reason unknown, but maybe the mechanism failed and prior owner decided to do away with them. Before purchase I would have the interior door panel removed and inspect what is under it, is the mechanism present? has the door been cut up inside? You want to be sure you can put the wind up windows back in (At least I would) but if the mechanism is missing or the inside of door cut up, you will need to purchase parts and or maybe have to replace a cut up door. Since I think you cant look at the car from where you are at, have the seller pull off the interior trim panel to expose the inside of the door and have seller send you some photos of the inside of the door, just so you can see condition of door and mechanism. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
offroad. Samba Member
Joined: January 01, 2009 Posts: 211 Location: llanelli, s wales
Posted: Sat Jan 24, 2015 1:41 am Post subject: |
Good advise guys and thanks for the help. 61SNRF. That is the car. Top detective work. 👍 |
Posted: Sat Jan 24, 2015 1:57 am Post subject: |
Bloody cheap too 😮 |
grandpa pete Samba Member
Posted: Sat Jan 24, 2015 10:07 am Post subject: |
Dash cams must be factory standard in Russia[/quote]
I read that Russian police are so corrupt that a dash cam is a good way to keep from getting blamed in an accident .
I drive trucks with a video witness dashcam ( go pro ). I'm not getting blamed for the idiot in the cars mistake . _________________ 63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery |
bugmandave Samba Member
Joined: December 30, 2005 Posts: 642 Location: Illinois
Posted: Sat Jan 24, 2015 10:43 am Post subject: |
maybe it had power windows installed when they updated the interior. switches could be mounted somewhere out of the view in the picture. _________________ '63 Karmann Cabriolet L456 Rubin (Ruby Red)
'71 Westfalia campmobile tourist delivery
January '59 SWR panel
'63 Karmann Cabriolet L54 Poppy Red |
65VOLLA Samba Member
Joined: October 21, 2007 Posts: 15 Location: SOUTH AFRICA
Posted: Sun Jan 25, 2015 12:06 pm Post subject: my 58 |
[/img] |
Posted: Sun Jan 25, 2015 2:02 pm Post subject: |
Thing is it's need advertised as stock and original. Which it seems it's not. That said it could still be a good car. Hoping to have someone local to it give it the once over for me before I drive to see it.
Thanks for your input guys. Lee |
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Mon Jan 26, 2015 11:42 am Post subject: |
Just seems really screwy with the windows. If the windows aren't intended to go up and down why would it have what appears to be inner and outer scrapers?
My suspicion is the regulators were removed or axed up and the new door panels made to cover the holes. Just seems weird.
I'm also not able to think of any other car that was manufactured without some sort of opening window. A lot of early cars had sliding windows, but this isn't a sliding window set up. _________________ Mother Nature is a Mean Evil Bitch! |
