P!ugUg!y Samba Member
Joined: January 22, 2015 Posts: 36 Location: Orange County
Posted: Tue Jan 27, 2015 10:59 am Post subject: |
Erik G wrote: |
no, only pay attention to the first 3 digits. if it's a 67, first 3 will be 367, 36 being squareback, 7 being 1967. The rest is sequential
It doesnt look 67 to me. I think 68-69, so 368 or 369 vin number |
36717xxxx |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13270 Location: Tejas!
Posted: Tue Jan 27, 2015 11:02 am Post subject: |
P!ugUg!y wrote: |
Erik G wrote: |
36717xxxx |
Where on the car is that number? it's got a gas flap fender and 68-69 turn signals, which could just be from other cars I guess. _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Posted: Tue Jan 27, 2015 11:04 am Post subject: |
Erik G wrote: |
P!ugUg!y wrote: |
Erik G wrote: |
36717xxxx |
Where on the car is that number? it's got a gas flap fender and 68-69 turn signals, which could just be from other cars I guess. |
i'll double check it in a minute. but yeah, im sure some of these parts were sourced. |
Erik G Samba Member
Posted: Tue Jan 27, 2015 11:11 am Post subject: |
P!ugUg!y wrote: |
Erik G wrote: |
P!ugUg!y wrote: |
Erik G wrote: |
36717xxxx |
I'm sure. Take a pic under the hood, 67 would have had to open the hood to fill the gas. I suppose a whole later front clip could have been used _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Posted: Tue Jan 27, 2015 11:25 am Post subject: |
Erik G wrote: |
I'm sure. Take a pic under the hood, 67 would have had to open the hood to fill the gas. I suppose a whole later front clip could have been used |
ill look at the inner fender |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22410 Location: Kimball, Mi
Posted: Tue Jan 27, 2015 11:32 am Post subject: |
Erik G wrote: |
That was my thought. A pic will tells us the story. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Tue Jan 27, 2015 11:35 am Post subject: |
Could also be a pan swap. |
type3nut64 Samba Member
Joined: September 25, 2000 Posts: 347 Location: Yucaipa Ca.
Posted: Tue Jan 27, 2015 12:27 pm Post subject: |
it looked like it had a early front apron ( horn grills in apron) with later front fenders. its a 67 with a bunch of parts to make it cool i mean complete. haha |
Posted: Tue Jan 27, 2015 2:42 pm Post subject: |
just arrived at my yard. |
Posted: Tue Jan 27, 2015 4:44 pm Post subject: |
um so thats really weird. why does it have 68/69 clip then early apron?
see this pic look at the apron.
Posted: Tue Jan 27, 2015 4:55 pm Post subject: |
haha, well i guess i know what to call this thing. I'm dubbing this project
"Clustertruck" |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22711 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Tue Jan 27, 2015 5:18 pm Post subject: |
P!ugUg!y wrote: |
"Clustertruck" |
Very punny! _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Tue Jan 27, 2015 5:48 pm Post subject: |
I am all for useing what you can to fix them up. mine was a 63 with 68 rear sunroof clip added on. i made it work. came out just fine.
i still think a bright blue color with 2.0 liter wheels would be bitchen. yes i said bitchen! |
Posted: Tue Jan 27, 2015 6:21 pm Post subject: |
so ive spotted a few sources, but the first thing i need to do is a new wiring harness for this thing. two questions: one is, if i were planning to put a type 4 motor in eventually, would i need a specific harness. and two, any suggestions based on experience in where to find/buy a harness? |
dc Samba Member
Joined: April 03, 2004 Posts: 1426 Location: Kitsap Peninsula
Posted: Tue Jan 27, 2015 9:59 pm Post subject: |
I used a "Rebel Wire" VW kit/harness- universal for Bug and type 3- all wires are long enough except maybe the group that runs over the top of the fuel tank (not tight - but would be in the way when removing the tank)-- easy to hook up (so aid my mechanic - I hate electrical) and uses color coded/labeled wires and modern blade fuses. _________________ 1963 Karmann Ghia |
Posted: Wed Jan 28, 2015 10:48 am Post subject: |
This pic is a major conflict. It shows both the early (67 and earlier) front wall with a hole for the fuel filler neck, and the 68-69 inner right fender with a fuel filler neck installed.
What I'm guessing, is that someone replaced the entire inner right fender sheet metal with 1 off of a 68 or 69 type 3 (might have had an accident in that area). They might have been done it, so they didn't have to lift the front hood to fuel the car, or just because it was available. Don't know which though. Either way, you have a 67 and or earlier body shell. The chassis VIN on the tunnel is the number you want to use.
Should be a cool project though.
As for the wiring harness, it getting a t-4 engine won't make a difference, as you'll still need to add/lengthen a couple of wires in the engine bay to do the engine conversion. Nobody makes a new harness just for that conversion either, so you basically start with the stock harness, and adjust from there. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
notchback Insensitive Jerk
Joined: December 16, 2003 Posts: 7024 Location: Behind the Zion Curtain
Posted: Wed Jan 28, 2015 2:39 pm Post subject: |
Mike Fisher wrote: |
I think this late model truck is still sitting in Coburg.
I like that one a lot, but are you sure it's a late model? I see 5 lug and no fuel door. Maybe it's just another "here's a pile of parts, let's see what i can make out of it" car. _________________
zeen wrote: |
Arguing with johnnypan is like mud-wrestling a pig. After a while you realize he just enjoys playing in the mud, winning the contest is not the point. |
FU#3 |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17968 Location: Eugene, OR
Posted: Wed Jan 28, 2015 3:55 pm Post subject: |
That is strange, as I do see a fuel door! I like the looks of it too as a baja pickup. You want me to go get you a price for it?
_________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Wed Jan 28, 2015 9:43 pm Post subject: |
I can see the fuel door now. I'd love to have a price on it, but right now I have no money. Maybe it's a late body on an early pan. _________________
zeen wrote: |
FU#3 |
Posted: Thu Jan 29, 2015 12:36 pm Post subject: |
ive tried to do a couple searches with spotty results, can anyone link a couple threads on pushing a little more power out of a 1600? im not totally sure if im gonna build the one i have or go for the type 4 motor. also does a type 2 auto work with a type 3 or 4 motor? |
