Wiring Harness Purchase
CiderGuy
CiderGuy is offline
PostPosted: Sun Jan 25, 2015 8:46 am    Post subject: Wiring Harness Purchase Reply with quote
I am soon going to need to purchase a wiring harness, and would like to know which in your option is the best one out there and why.
Thanks,
Paul
jpjohns
jpjohns is offline
PostPosted: Sun Jan 25, 2015 9:26 am    Post subject: Reply with quote
I personally like the OEM ones like KGPR and Aircooled has. They have the factory color coding so wiring is easy following the wiring diagram.
However, I've seen some guys on here using the current wiring because they used a newer fuse box and I kind of like those too because they use standard auto fuses, not the old hard to find style and they come with relays and flashers installed.
So I'm still kind of torn.
-Jared
"Scrapyards are for quitters" - Beetlenut (a Samba member)
mcmscott
mcmscott is offline
PostPosted: Sun Jan 25, 2015 10:23 am    Post subject: Reply with quote
I like to build my own.
There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250
CiderGuy
CiderGuy is offline
PostPosted: Sun Jan 25, 2015 12:20 pm    Post subject: Reply with quote
I do like the clean uncluttered look of the newer fuse boxes. Also it seems that there actually may be less that can go wrong that way. I find what some of these wire harness are selling for insane.
Making my own scares the hell out of me ......
heramire
heramire is offline
PostPosted: Sun Jan 25, 2015 3:57 pm    Post subject: Reply with quote
Hi, can you please share more pictures of your wiring job? looks awesome.
Inside? hood, engine?
Thanks.
kiwighia68
kiwighia68 is offline
PostPosted: Sun Jan 25, 2015 4:38 pm    Post subject: Reply with quote
I salvaged my '68's original wiring loom and replaced all the damaged wires with VW original wires or wires that are colour-correct and of the correct gauge. I built a second loom to go down the other side of the car to cater for additional instruments should I decide to install some.
To be honest, if I weren't so obsessive (anal?) about using the car's old parts where I can in this restoration, I would have bought a brand new and modern loom. I like the clean and tidy look of it.
Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015
didget69
didget69 is offline
PostPosted: Sun Jan 25, 2015 9:09 pm    Post subject: Reply with quote
I like the VW harness from Rebel -
http://rebelwire.com/rebel-wire-products.php?cat=Wire%20Kits
bnc
I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door.
Tonyorlo
Tonyorlo is offline
PostPosted: Sun Jan 25, 2015 10:22 pm    Post subject: Reply with quote
Ive been trying to figure out what to do with the harness in my ghia too.
Just came across this,
http://www.ronfrancis.com/prodinfo.asp?number=XP-695
its not cheap, but looks clean.
That rebel harness looks good, and is priced well.
CiderGuy
CiderGuy is offline
PostPosted: Mon Jan 26, 2015 6:47 am    Post subject: Reply with quote
bnc
I sure like the price! But I wonder if everything will work without redesigning the circuits? Will you need to change out the flashers, turn signals ?
CiderGuy
CiderGuy is offline
PostPosted: Mon Jan 26, 2015 6:48 am    Post subject: Reply with quote
This is one of the higher priced wiring harnesses out there.
didget69
didget69 is offline
PostPosted: Mon Jan 26, 2015 9:12 am    Post subject: Reply with quote
bnc
Contact Rebel & speak with Bob Miller. I used one of their harnesses in a buggy install & didn't use any VW switches or other VW bits. Bob was good source of info when I was looking to buy a harness.
But the quality is very good for the money spent on the Rebel harness; excellent quality wire. I work in wire manufacturing, so I know quality wire vs crap wire.
bryan
CiderGuy
CiderGuy is offline
PostPosted: Mon Jan 26, 2015 9:38 am    Post subject: Reply with quote
didget69 wrote:
bnc
bryan
Thanks Bryan, I just sent him an email.
Paul
c21darrel
c21darrel is offline
PostPosted: Mon Jan 26, 2015 11:09 am    Post subject: Reply with quote
Most of the "american style" wire kits are made for american cars with front engines, so you will have several wires too short.
Watsons kit is a little better, i think i only had 1 wire too short. Plus instructions for vw.
http://www.watsons-streetworks.com/custom-vw-modular-wiring-kit?filter_name=vw
Or for traditional vw go right to the source, Bob Nodvack 310.519.8147
GhiaBuild
1967 DC build
CiderGuy
CiderGuy is offline
PostPosted: Mon Jan 26, 2015 11:51 am    Post subject: Reply with quote
The Rebel does offer a VW "Bug" 12 & 16 circuit wiring harness for a vw. The gentlemen I spoke to said it would work fine for the Ghia. They even have wire harnesses for a VW bus.
The Watson harness is about $100 more, but does have more circuits. Its a hard call. I like having a circuit for AC, if I ever want to go that route.
weldvair
weldvair is offline
PostPosted: Tue Jan 27, 2015 9:09 am    Post subject: Reply with quote
I too have been wondering how to fix the rats nest of wires. Yesterday I
bought a chevy tilt steering column($75) that I will have to shorten. I then removed all the wiring from The KG.
I will buy a EZ wiring kit to rewire the car.($150)
If there is any interest I will take pictures of the installation
Don
CiderGuy
CiderGuy is offline
PostPosted: Tue Jan 27, 2015 9:46 am    Post subject: Reply with quote
Don
Don,
I would be very interested in seeing pictures of your install. I didn't see any harnesses for VW at the EZ wiring site, did I miss something?
Paul
weldvair
weldvair is offline
PostPosted: Tue Jan 27, 2015 8:48 pm    Post subject: Reply with quote
CiderGuy.......no/I am installing a gm steering column because
ez wiring connectors will plug in to the column. ie-all the wiring for turn & emergency/power out for the fuse panel/high-low beam connector/wire to starter/safety sw/ign coil..etc. plug in. PLUS a tit wheel.
Simpier to wire & THE WIRE IS MARKED every 5".
Don
weldvair
weldvair is offline
PostPosted: Sat Jan 31, 2015 7:58 am    Post subject: Reply with quote
After reading my post......the EZ wiring kit is for a Chevy/it is plug & play.
It comes with a modern fuse box & the wires are labeled every 5".
To use it you have to replace the Ghia steering column w/a Chevy column
which is pretty easy to do.
Don Smile
CiderGuy
CiderGuy is offline
PostPosted: Sun Feb 01, 2015 12:11 pm    Post subject: Reply with quote
Don Smile
Something I wouldn't care to do. I'll keep looking.
CiderGuy
CiderGuy is offline
PostPosted: Sat Jun 27, 2015 9:19 am    Post subject: Reply with quote
CiderGuy wrote:
didget69 wrote:
bnc
bryan
Paul
After a real lot of research and some soul searching ( wiring a car, scares the hell out of me ) I've decided to go with the rebel wiring harness. It seems to be of the same quality of other harnesses costing much, much more.
Cars Currently Owned:
1970 Karmann Ghia Coupe
1973 Karmann Ghia Coupe - Project car for sale
1970 Karmann Ghia Convertible (Body off restoration)
Timing is everything
