rustednuggs Samba Member
Joined: June 29, 2008 Posts: 508 Location: Summerdale
Posted: Sun Jan 25, 2015 9:06 am Post subject: Two part question - 1 forum |
Just a couple of quick questions:
1.) I acquired two good shape rear axles for my 69 SC. I have changed boots and correct gear to put back on and greased up. My question is which end goes tot he tranny and which end goes two the wheel base?
2.) Also on a door. I have a new regulator to put in a door (same vehicle, 69 SC) How the heck doe sit go in? I have a clear path until I get to where the little vent window is inside the door. I cant seem to get the regulator over or past this this area ( where the window little vent comes in to the door)
Thanks in advance
rustednuggs |
Skoolieman Samba Member
Joined: January 31, 2011 Posts: 573 Location: Chattanooga TN
Posted: Sun Jan 25, 2015 10:13 am Post subject: |
1: the axles can go in either way. If there is any wear in the cvs you can swap them but it shouldn't be necessary
2: you need to remove the 10mm nut and use a lever to pry a little bit between the door skin and frame. It will slip in and you'll be all set. _________________ '69 Westfalia Camper~Cassidy
1600dp with H30/31 carb 009 distributor and alternator conversion |
VWDruid Samba Member
Joined: June 14, 2008 Posts: 1192 Location: Boca de Ratones FL
Posted: Sun Jan 25, 2015 10:25 am Post subject: |
1.) cv bearings have a ring indicting what side attaches to the car. you used cv grease?
2.) http://www.thesamba.com/vw/forum/viewtopic.php?t=454316 _________________ 70 Westy, 2027cc "dual DRLA 40 m140 i55 wjdoc a165 p33 v30 "w100 straight cut 040 polished heads 1.25 rockers 1.5 A1sidewinder supertrapp muffler trans 091 coil SUM-850500 CDI universal svda Pertronix
http://www.storyofstuff.com/
It's not the straight cut gears It's the T.A.R.D.I.S. engine.
wanted Chameleon Circuit |
Posted: Sun Jan 25, 2015 11:08 am Post subject: |
Ok cool that's what I have going on. Greased is used. Going to find torque specs now....
Thanks
Rustednuggs |
Posted: Sun Jan 25, 2015 11:27 am Post subject: |
Looks like 33ft lbs.
Rustednuggs |
richparker Samba Member
Joined: November 24, 2011 Posts: 6982 Location: Durango, CO
Posted: Sun Jan 25, 2015 1:07 pm Post subject: |
Rustednuggs. You should start a thread called something like rustednuggs '69 single cab and ask all your questions there. Then everything will be in one place and people searching can find how you solved problems on your SC.
Rich P. _________________ __________
71 Westy build
Adventure thread
65 Deluxe Build
63 Deluxe Build |
Posted: Sun Jan 25, 2015 1:11 pm Post subject: |
That's a great ideal. I'm going to post a Caption of pictures also. |
Tcash Samba Member
Bentley
section 6 subsection 3.2: (25 ft. lb.) |
Posted: Sun Jan 25, 2015 1:59 pm Post subject: |
TY and thats a great ideal. I will start that....
Rustednuggs |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12722 Location: on a bike ride somewhere
Posted: Sun Jan 25, 2015 9:56 pm Post subject: |
rustednuggs wrote: |
The bay torque is 25'/lbs. I like it a few pounds higher:
Wildthings wrote: |
the Vanagon spec is something like 33 or 36 ft*lbs verses the Bay's 24 ft*lbs even though all the parts are essentially the same. |
_________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
Posted: Sat Jan 31, 2015 6:17 pm Post subject: |
The picture below show my new rubber hose that I put in today for the gas tank. I didn't have the original one to measure from. Is this one to long and that's why the kink or bubble up in it is taking place?
Also check this video out:
My bus shifter hit the e brake? I am pretty sure I got the correct one. What recommendations might one have to shorten it? Cut it and tap the top?
http://youtu.be/sI9Q8iNe0Ho
thanks
rustednuggs |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2743 Location: Hamble, Hampshire, UK
Posted: Sun Feb 01, 2015 11:16 am Post subject: |
thanks
rustednuggs |
Looks like trying to get a straight piece of hose to fit where the original was curved.
Your gear linkage is sloppy. _________________ Ancient vehicles and vessels
Posted: Sun Feb 01, 2015 11:50 am Post subject: |
TY.
What is the best way to troubleshoot sloppy linkage? It seems to go in gear, reverse, 1st and 2nd...
rustednuggs |
Tcash Samba Member
Posted: Sun Feb 01, 2015 7:57 pm Post subject: |
Take a look at your bushings.
Shifter parts id |
Brian Samba Moderator
Posted: Sun Feb 01, 2015 8:12 pm Post subject: |
yo man, your filler hose is okay, it wont affect anything unless that thing comes loose.
But if you wanna deal with it now, get Gates Fuel Hose #24718 _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Posted: Wed Feb 04, 2015 5:46 pm Post subject: |
Thanks for this info. Quick question about a headliner. ..I am ordering one from TMI and wanted to know if I should put this in before my front windshield goes in? Or can I just put in the windshield and then come back and do the headliner? No clue...
Thanks in advance
rustednuggs |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51148 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Feb 04, 2015 6:23 pm Post subject: |
Headliner before windshield, impossible later. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed Feb 04, 2015 6:27 pm Post subject: |
Good to know, appreciate it! |
Posted: Sat Feb 07, 2015 5:00 pm Post subject: |
Hello - me again, rustednuggs. So dumb question but as I am turning this large bolt to tight up the bolt within the bearing is turning, making it impossible to tighten. What gives? How do I tighten this up? Picture below.
Thanks in advance
Rustednuggs
Posted: Sat Feb 07, 2015 5:05 pm Post subject: |
Do you have an impact gun? Might help or might make it worse. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
