clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Sun Jan 25, 2015 9:02 pm Post subject: Test Results from my Turbo install |
I have been messing with a turbo on this buggy for 4 years now.
I have tried blow through carb and now EFI and I have to say this has been the most successful run I have done yet.
I still have a set of 40X37.5mm heads to put on.
This is the 3rd Subaru turbo I have installed.
I have only put about 10 miles on it since installing but so far I am quite impressed.
It's putting out 20 plus lbs. boost with Water/Alcohol injection and there is no detonation.
Here are the engine specs.
1679cc
35.5X32mm stock heads
Engle W-100 cam
Solid Rockers
Single HD springs
Megasquirt 2 EFI and crankfired ignition
This one is a Subaru TD04L-13T turbo from a 2002 WRX.
Here is a short video of it going through the gears.
Edit...embedded the youtube video. Had to take a class on how to do it....
I have another video of an Iphone dyno run on my build at STF that gives the hp results and 1/4 mile. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936
wythac Samba Member
Posted: Mon Jan 26, 2015 3:57 pm Post subject: |
Nice. Now you need a speedometer that "goes to 11"..... |
andygere Samba Member
Joined: January 31, 2014 Posts: 600 Location: Central Coast, CA
Posted: Mon Jan 26, 2015 10:45 pm Post subject: |
Wow, that thing moves out! |
